A/C Question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by DesertRatR, Jun 19, 2025 at 6:08 PM.
  1. Jun 19, 2025 at 6:08 PM
    DesertRatR
    DesertRatR [OP] My favorite dog is what I got.
    Southern AZ
    2019 TRD 4WD Off-Road
    Taco is 2019 with 83K miles
    How often should the compressor shut off, and for how long should it stay off? Humidity here in AZ is as low as it gets so evaporator shouldn't freeze.
  2. Jun 19, 2025 at 6:23 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I’m not an hvac expert but all I can say is that as long as the ac is on, the ac clutch should be spinning all the time but there is an exception on certain vehicles in which the ac compressor builds enough pressure to keep the Freon circulating so the clutch stops and restarts when pressure needs to build up again to recirculate the Freon.
  3. Jun 19, 2025 at 6:37 PM
    2021SR5V64WD
    2021SR5V64WD Well-Known Member
    2021 SR5 V6 4WD ACCESS CAB
    You're using the A/C already. Heck fire it was only 116 today man-up.
    Phlogiston likes this.
  4. Jun 19, 2025 at 6:56 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Not sure what you mean, the compressor will cycle off as needed to prevent the evaporator from freezing up and/or if the compressor discharge pressure rises too high.
    There's a ton of factors that would influence how often it cycles.
    It's not like a home HVAC system that cycles on and off based on the temperature it's set at.
    Chew likes this.
  5. Jun 19, 2025 at 7:06 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Are you asking because the clutch seems to be cycling fast(er)?
    That can be a sign of a slightly undercharged system
    t0p_d0g likes this.
  6. Jun 19, 2025 at 8:33 PM
    DesertRatR
    Southern AZ
    I've never paid attention to cycle rate. A/C is one of those items I forget about as long as its working. It seems to be working properly. My question was just curiosity. I was assuming A/C cycles on a fixed schedule to ensure evaporator doesn't freeze.
  7. Jun 19, 2025 at 9:16 PM
    Dm93
    Texas
    2014 DC OR 6spd 4x4
    It uses a temperature sensor probe in the evaporator to prevent freezup not a timer, most systems cycle off around 34-36F and back on around 37-40F evaporator temp.
    Chew likes this.
