A/C randomly stopped working
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Rogelio22, Jul 9, 2017.
  1. Jul 9, 2017 at 6:53 AM
    Rogelio22
    Rogelio22 [OP] Get him a body bag! [TTC #030]
    Roger
    Sioux City, IA
    2018 Chevy Silverado 1500 Z71 Texas Edition
    Blank slate, ready to start
    Ok so question for fellow 2nd Gen Owners. Have you ever had the A/C randomly just cut out and lose power and then blow out smoke? I drive a 2015 V6 TRD Offroad and I was going down the highway here in San Antonio when this happened. Put my foot down to speed up and get around a slow driver holding up traffic and when the engine revved up, my A/C lost most of its power and the indicator light for the A/C started blinking. I shut off the A/C and then turned it back on and it started blowing out smoke from the vents. Took it to the dealership since its under warranty but, they couldn't find anything wrong with it. Anybody got any ideas as to what is wrong with the A/C?
  2. Jul 9, 2017 at 7:38 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    This happened to me when I first got my 2010. Truck had less than 100 miles on it. Smoke, blinking a/c light, not cooling. I turned it off and back on, and the past 7 year hasn't happened again. Never figured out what caused it.
    Rogelio22[OP] likes this.
  3. Jul 9, 2017 at 7:51 AM
    Rogelio22
    Roger
    Sioux City, IA
    glad to know I'm not the only one this happened to. Time will tell I guess
  4. Jul 9, 2017 at 1:59 PM
    CurtB
    CurtB Old Timer knowitall
    Curt
    Kansas
    2010 Tacoma SR5
    When you put your foot down, was it WOT? That will cause the ECU to shut off the AC compressor.
    Did the 'smoke' smell like smoke, or was it just water vapor?
  5. Jul 9, 2017 at 2:13 PM
    Rogelio22
    Roger
    Sioux City, IA
    WOT? Sorry not too good with the acronyms of TW yet, and not too sure, should have checked but as soon as it started I shut it off and opened the windows.
  6. Jul 9, 2017 at 3:47 PM
    AKHawkeye
    AKHawkeye Well-Known Member
    Anchorage, AK
    15 AC Sport 4x4 6 Spd
    Locked as stock
    WOT = Wide Open Throttle
    Was your foot smashing the skinny pedal all the way to the floor?
  7. Jul 9, 2017 at 3:53 PM
    Rogelio22
    Roger
    Sioux City, IA
    Gotcha, and no not all the way, I was between 2500-3000 rpms. I was going about 45ish and was got up to 60ish
  8. Jul 9, 2017 at 4:13 PM
    Lester Lugnut
    Lester Lugnut Well-Known Member
    N of Mex-S of Canada-E of LA-W of NC
    '15 Tacoma PreRunner V6 SR5 Auto
    Which SA dealer told you they could not find anything wrong with it?
  9. Jul 9, 2017 at 4:14 PM
    Rogelio22
    Roger
    Sioux City, IA
    Cavender Toyota, it's where I bought the truck
  10. Jul 9, 2017 at 4:16 PM
    cliffyk
    cliffyk Well-Known Member
    Cliff
    Saint Augustine, FL
    2009 DCSB SR5 TRD Sport 145k miles
    The refrigerant charge is low. This causes the system to "supercool" and the evaporator coil freezes up with accumulated (and frozen) condensation. The "smoke" is fog caused when humid air that does make it through the evaporator is released into warmer air in the cab--like when you open the freezer in your home.
    The greater issue is why the charge in your 2-year-old system is low?
    All that said however I have seen this happen in properly charged systems when the ambient humidity is especially high--my '03 Mustang would do it sometimes, shut the AC off for a bit to let the evaporator defrost and all would be well 'til next time the humidity was very high. Running in "recirculation" mode may help...
    Tex-Tac, 2.7taco and Rogelio22[OP] like this.
  11. Jul 9, 2017 at 4:23 PM
    Rogelio22
    Roger
    Sioux City, IA
    Very much appreciated friend. I will look into recharging it and there's no telling why it's low on charge. I've got less than 40K on it and it's pretty humid here in San Antonio so that might be it. Also I pretty much always run it recirculation mode.
  12. Jul 9, 2017 at 4:30 PM
    2.7taco
    2.7taco Well-Known Member
    Texas
    2005 Tan Tacoma Base 5 LUG: Beaten , abused and still running strong.
    Fat Bobs 2.75 lift and level with short AAL, 16x8 Level 8 Guardian Wheels, 245/75R16 Toyo Open Country ATII, custom trans shift kit(home made), Trans temp. and Vac gauge, URD fuel pump upgrade(going back to stock soon).
    Do not only recharge. Have the system fully evacuated and run a vacuum pump on the AC system for 5 mins to pull it down to 28 inches of vacuum and lock it in and shut the pump off. The vacuum should hold at 28 inches for 30 min. If it leaks down then there is a leak. Snoops will find gross leaks and an electronic sniffer will find tiny ones.
    I'm seeing a trend with Toyota techs these days and it's not good.
  13. Jul 9, 2017 at 4:30 PM
    cliffyk
    Cliff
    Saint Augustine, FL
    In very humid situations it does not take a "lot" of undercharge to cause to the symptom you describe, in fact production tolerances could account for it. If you do not have a gauge set and/or the ability to add a bit bring it to an auto AC specialist--NOT a Toyota dealer. The guys that do nothing but AC all day will know much more about the specifics of your environment.
  14. Jul 9, 2017 at 4:32 PM
    2.7taco
    Texas
    Agreed.
  15. Jul 9, 2017 at 4:34 PM
    Rogelio22
    Roger
    Sioux City, IA
    Well alright man, thanks for the advice. I'll have to wait till Thursday as I work till Wednesday doing 12 HR shifts
    cliffyk[QUOTED] likes this.
  16. Jul 9, 2017 at 4:36 PM
    Lester Lugnut
    I have a 2015 PreRunner - also purchased from them. Trying to get an issue resolved as well. Have been told they must bring in a "Toyota Field Technical Specialist" to resolve. Been waiting over 2 weeks for this "specialist" to arrive.
    Take it back and ask to speak to the Fixed Operations Director - a glorified term for the guy who manages parts and service. His name is Dan Warshawer.
    Rogelio22[QUOTED][OP] likes this.
  17. Jul 9, 2017 at 4:57 PM
    Rogelio22
    Roger
    Sioux City, IA
    Looks like I will have a busy Thursday ahead of me. I haven't had any issues since but I will be reaching out to Dan then, thanks for the info!
