A/C re-circulation ?
Discussion in 'Technical Chat' started by CQB 1911, Nov 7, 2011.
  1. Nov 7, 2011 at 6:41 AM
    CQB 1911
    CQB 1911 [OP] Well-Known Member
    Jesse
    AZ.
    2010 TRD OR AC
    On my way to work this morning my A/C re-circulation button turned off by itself about every 2-4 minutes allowing fresh air in. I didn't have the air or heat on. I had the recirc button lit and about every 3 min the light would go off and allow fresh air in. My Maint Req light has been on for a day or so but I doubt that has anything to do with this.
    Any ideas?
  2. Nov 7, 2011 at 9:46 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    If it was for the Defrost setting, I belive the a/c switches itself from "fresh" to "recirc" every so often.
  3. Nov 7, 2011 at 9:50 AM
    Fink
    Fink Motorboatin' SOB
    Orlando, FL
    2013 Regular Cab 4x4
    WeatherTechs, 265/75-16 DuraTracs, ATX Mojave Teflon Wheels, ARE V-Series Shell
    Wow, I feel retarded. I've had two 2nd gens and I didn't know this.
    Fink
  4. Nov 7, 2011 at 9:53 AM
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Really?? :confused: I did not know that
  5. Nov 7, 2011 at 9:53 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I think only the newer ones do this. Mines an '07, and it doesnt. I think it started on the '09's and up.
  6. Nov 7, 2011 at 9:56 AM
    Fink
    Orlando, FL
    Oh ok - I haven't used defrost on my 2011 so that's why I haven't noticed. My other 2nd gen was a 2007...makes sense.
    What is this "mannyouwell" you speak of?!
    Fink
  7. Nov 7, 2011 at 9:59 AM
    Opihiman10
    Opihiman10 Active Member
    Honolulu, Hawaii
    2011 double cab 4x4 TRD SR5
    Nerf bars
    Didn't know that either....
    What is the need to allow freash air in with the use of the Defrost....I always felt the defrost worked better without the recirc. ?
    OPI
  8. Nov 7, 2011 at 6:12 PM
    CQB 1911
    Jesse
    AZ.
    2010 TRD OR AC
    Humm... I didn't have it on defrost. Fan switch was in the off position - temp dial was on cool - directional set to face with the "recirc" button lit. Also, the back sliding window was open.
    I've been driving to work like this for the past week or so and this is the first time I've noticed the "recirc" button switch to "fresh" by itself.
  9. Nov 7, 2011 at 6:56 PM
    woods247
    woods247 Well-Known Member
    back yonder
    09 TRD Sport Double Cab 4x4
    SAWs front, Fox resi rear, Total Chaos UCAs, 17" BBS RD-Truck FJ Rims with 255 BFG KM2s, TRD exhaust/intake, OME Springs, All-Pro flip kit, Timbren rear bumpstops, custom spare carrier, All-Pro skids, Beefed Sliders, All-Pro front bumper, Warn M8000 w/Synth MasterPull line, Procomp 30" LED lightbar, Bestop Soft topper, Safari Snorkel, CBI Bushmaster (custom), Baja Racks Utility rack, All Pro custom bed rack, Leer 100XQ
    You can hold the recirculation button down for 2-3 seconds to disable the auto off. However it enables itself everytime you restart the engine so you'll need to hold it down again if you want it to remain on.
  10. Nov 7, 2011 at 9:20 PM
    CQB 1911
    Jesse
    AZ.
    2010 TRD OR AC
    Thanks guys. Call me lazy - but it's easier asking you guys then climbing up and down 3 flights of stairs to get to the manual in my truck.
  11. Nov 7, 2011 at 9:44 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    You're gonna do both ?
  12. Nov 8, 2011 at 11:25 AM
    jassco
    jassco Well-Known Member
    NH
    2023 TRD Offroad
    As a side note - This function is also related to why you cannot swap older overhead consoles with 09+ vehicles without an additional temp sensor wired in. Two steps forward one step back. It does work well though.
  13. Nov 8, 2011 at 11:28 AM
    CQB 1911
    Jesse
    AZ.
    2010 TRD OR AC
    It worked as you described. Thanks!
  14. Jan 25, 2012 at 8:32 PM
    JRFlyboy
    JRFlyboy Member
    Orange County
    09 Sport Double Cab Longbed
    What a pain in the butt to have to do this every time you drive your truck. I hate it when it decides to open the vent when behind some stinky diesel at an intersection.
  15. Jan 26, 2012 at 7:41 AM
    JaSkynyrd
    JaSkynyrd Ron F. Swanson
    Chattanooga, TN
    2001 XtraCab 4x4 V6 SR5
    LOL nice catch
  16. Jan 26, 2012 at 7:54 AM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    if you have it on recirc and the outside temp drops below 50 degrees it will automatically switch itself to fresh...if you push the recirc button and hold it for 3 seconds it will stay on recirc....but you have to do it everytime you turn the switch off.
