A/C stopped working after sitting a few months
Discussion in '1st Gen. Tacomas (1995-2004)' started by rob feature, Jun 23, 2015.
  1. Jun 23, 2015 at 11:02 AM
    rob feature
    rob feature [OP] Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    Howdy folks. As the weather here is generally pretty tolerable, I don't have the occasion to use the A/C in my 2003 X-cab V6 very often, but as we just had a hot spell I'm taking notice.
    The problem started over the Winter. I have, or had, 2 vehicles and put the Taco away for the Winter. It sat for probably 6 months without turning on the A/C although I did start the truck and let it idle a few times during that period. Seems I should have turned on the A/C because the next time I tried it again, it decided it was on strike. The compressor still kicks on, but it does not cool the air.
    It seems like I read somewhere a while back about this being a problem, but can't seem to find the thread. I'd kinda like to fix as much of this myself as I can, but don't really know where to start. As this seems like a known issue after letting the truck sit for a while, I thought I'd ask here first.
    Thanks in advance!
  2. Jun 23, 2015 at 11:09 AM
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    you said the compressor kicks on, do the pipes that go into the cab get cold?
  3. Jun 23, 2015 at 11:12 AM
    keakar
    keakar Well-Known Member
    karl
    louisiana
    if the compressor is kicking on then it has Freon and should be cooling.
    I bet your problem is the heater valve is bad and the heater is running at the same time. its a very common problem that happens all the time.
    open the hood and feel the large line coming out of the firewall, it should be cold, (the small line is hot) if it is then the a/c is working and you need to look at the heater valve. if you are feeling around near the compressor, be careful, the small line there will burn you.
  4. Jun 23, 2015 at 11:24 AM
    rob feature
    Colorado
    Well, now the compressor won't come on. It came on the last time I tried it - last week, but not today. I double-checked both fuse locations and nothing blown in there.
  5. Jun 23, 2015 at 12:03 PM
    bubbabud
    bubbabud Well-Known Member
    Bob
    Tonopah AZ
    13 tacoma TRD Off road.ARE shell no rust anywhere period.
    2 in spacer lift front 2, in AAL rear [tundra leaf] , flip up tow mirrors, ARE shell electric brake controller and cooper ATP 265/r70x16 tires on stock TRD wheels
    You could have slowly lost the refrigerant charge and the low pressure cut switch wont allow the compressor to run or will cause it to start and stop [cycle] rapidly. Solution measure low side pressure and recharge if low. simple to use service kits are available at most parts store's for around $30
  6. Jun 23, 2015 at 1:40 PM
    rob feature
    Colorado
    Maybe I need to have a look there. I was thinking there was some sort of sight glass check for that too...I'll look into it.
    Thanks!
