A/C suddenly blows hot air
Discussion in '1st Gen. Tacomas (1995-2004)' started by 2003Tacoma2020, Apr 28, 2023.
  1. Apr 28, 2023 at 10:59 AM
    2003Tacoma2020
    2003Tacoma2020 [OP] Member
    2003 Tacoma 2.4
    The A/C on my 2003 Tacoma works fine but suddenly starts blowing hot air. I can turn the dial to full hot then back to full cold and it starts blowing cold air again. It might stay cold OR it might go to blowing hot air again. Any ideas what the fix is? Thanks
  2. Apr 28, 2023 at 11:26 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    throw the manifold gauges on see what your dealing with pressure wise.
    It sounds like the outside of the Evap coil is freezing shutting the system off allows it to melt .
    HondaGM likes this.
  3. Apr 28, 2023 at 12:09 PM
    CrustyTaco
    CrustyTaco Well-Known Member
    Todd
    Louisville, KY
    04 Ext Cab V6 5MT 4X4 185k
    881/5100/Dakars 4R wheels / TBU / New frame
  4. Apr 29, 2023 at 6:30 AM
    sdk1968
    sdk1968 Well-Known Member
    03 Taco TRD
    yep. ive got the exact same thing going on, so do several other people. still wating to see if this is my problem when it comes back to me from the shop.
    the other big suggestion im getting on this comes from here at TW as well & is teh expansion valve.
  5. May 4, 2023 at 12:11 PM
    sdk1968
    03 Taco TRD
    any update?
  6. May 4, 2023 at 1:58 PM
    ThunderOne
    ThunderOne Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    sounds like a blend door issue to me.
  7. May 19, 2023 at 10:27 AM
    sdk1968
    03 Taco TRD
    Check out my thread... Mines fixed. So far.
    HondaGM likes this.
  8. May 19, 2023 at 1:06 PM
    Dan71
    Dan71 Well-Known Member
    Dan
    1996 Tacoma
    Bone Stock
    i need to get someone to throw some gauges on mine now that I think about it.
  9. Feb 6, 2024 at 1:59 PM
    2003Tacoma2020
    2003 Tacoma 2.4
    The blend door actuator has been replaced but did not fix the problem.
  10. Feb 6, 2024 at 2:17 PM
    sdk1968
    03 Taco TRD
    Did you check out my thread on this other issue a lot of people have?
