A/C Triggered Screeching noise
Discussion in '1st Gen. Tacomas (1995-2004)' started by cfree5119, Jul 10, 2013.
  1. Jul 10, 2013 at 7:37 PM
    cfree5119
    cfree5119 [OP] Well-Known Member
    Last summer I changed all the belts on my 03 Tacoma 2.7... In the fall, I had this awful screech noise come from under my hood. It only triggers when my A/C is on and will last only a second or two before going back to a normal sounding taco.
    I cannot get the noise to repeat or even happen while idling. That being said, I can drive around all day without the A/C and hear no screeching from underneath the hood. WHen I drive around with the A/C on, I will get sporadic screeching lasting only 1-3 seconds and then back to normal. My truck will slightly lurch and I mean slightly when the noise happens.
    Is it a compressor issue, belt issue, or what? WHere do I start? Thanks.
  2. Jul 10, 2013 at 7:46 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Is the belt tensioned correctly? Might have broken in and need to be tightened
  3. Jul 10, 2013 at 10:07 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    if belts are new , could be tensioner or worst case , compressor is on its way to a lock up
  4. Jul 10, 2013 at 10:09 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    ^^^^ What he said.
  5. Jul 10, 2013 at 10:14 PM
    acdronin
    acdronin Well-Known Member
    There's a squirrel trapped in your engine bay, you should probably let him out.
  6. Jul 10, 2013 at 11:01 PM
    Rich91710
    Rich
    Los Angeles
    08 Base
    ^^^^ Not what he said.
  7. Jul 11, 2013 at 5:06 PM
    cfree5119
    If it doesn't do it under idling conditions but is under load when I am in the middle of the gear does that detail which one it might be? Thanks.
  8. Jul 21, 2013 at 10:49 AM
    cfree5119
    And its very random... I can't pick up when it actually happens. I went 3 days with no screech and then it happened at the top of 2nd gear before I shifted to 3rd.
  9. Aug 15, 2013 at 5:10 AM
    cfree5119
    Any more thoughts?
  10. Aug 15, 2013 at 7:31 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    Have you followed thru on any of the above advice?
    If so, what have you learned?
  11. Aug 24, 2013 at 1:16 PM
    cfree5119
    I tightened up the ac tensioner today... Stay tuned
  12. Aug 27, 2013 at 8:12 PM
    cfree5119
    No screeching this far
  13. Sep 8, 2013 at 7:39 PM
    cfree5119
    Issue is resolved... thankful it was the ac unit.
  14. Sep 8, 2013 at 9:48 PM
    x2468
    x2468 Well-Known Member
    '02 TRD 4wd V6 Xcab Sr5
    If the A/C compressor was going, it would sound atrocious. Mine is going and it sounds like a cross between a diesel and a tea kettle.
    It could just be the clutch bearing on the A/C pulley.
    In case the screeching comes back.
