a/c unit inside leaking
Discussion in 'Garage / Workshop' started by lopezoscar03, Jul 9, 2011.
  1. Jul 9, 2011 at 2:59 AM
    lopezoscar03
    lopezoscar03 [OP] Well-Known Member
    lopezoscar03@gmail.com
    hey whats up everyone. i live in miami, fl and my a/c unit is leaking water from two corners. i went ahead and cleaned the drain pipe with a liquid i purchased at home depot and then cleaned the outside unit as well. i followed the directions on the bottle to disconnect the drain pipe and turn the a/c off for 25m and allow liquid to flow threw pipe. well this morning when i get up to go to work, there is still water in the bowl i have down there. the leak is on the oposite side of the drain pipe. basically if your looking at my a/c unit in the closet... the drain pipe is on the left and the two leaks on the right front and rear corner. please all suggestions welcome. thanks guys
