A/C unit not cool
Discussion in '1st Gen. Tacomas (1995-2004)' started by Chillyone, May 25, 2011.
  1. May 25, 2011 at 11:00 AM
    Chillyone
    Chillyone [OP] Member
    1996 Tacoma 4 x 4
    Have a '96 Taco V6 5VZ engine very happy all these years!
    My air conditioning unit is not cooling. First problem ever w/ AC unit. never been charged before. All else is working with unit it seems. can I buy a can of freon and recharge the system? How do I do that? is there a sm black cap on one of the lines I remove?
    Also is there inferior freon products to stay away from?
    Much appreciation all you Tacoheads!
    Have great Memorial Weekend!
    Chillyone :)
  2. May 25, 2011 at 11:08 AM
    Firetech
    Firetech Well-Known Member
    Ralph
    Maryland
    2010 SR5 Off Road
    Have you checked your fuse? Try this first, if not used for a long period of time it may be stiff and blow a fuse. If not a fuse look for a sticker under the hood saying what type of refrigerant you need. You can get a recharge kit from any good Auto parts store. Just follow the directions closely.
  3. May 25, 2011 at 11:12 AM
    03coma
    03coma Well-Known Member
    New Jersey
    2015 DCSB TRD, SR5
    Toyota TRD Pro Grille, Skid Plate, ARE Series II Lid,
    is it blowing hot air or cool? You might have a bad o ring, causing a leak. Your truck should take R134a ref.
  4. May 25, 2011 at 1:38 PM
    skytower
    skytower Well-Known Member
    Dave
    virginia
    08 Tacoma 4x4
    Hitch and wiring, aux back-up light, rear strobe lights, radio and underseat sub.
    R12 or r134a? R12 you're f'd. R134a: First thing you need to do is put a set of gauges on it. That will tell you what's wrong and what to do next. Anything else is just guessing.
    No gauges? Take it to a shop to diagnose.
    Here's a short list of possible problems to look for: leak in system, compressor degrading and losing parts(clogging the expansion valve), bad pressure switch, moisture in the system. This assumes the compressor is still engauging.
  5. May 25, 2011 at 4:27 PM
    Chillyone
    1996 Tacoma 4 x 4
    Thanks you gentleman for your replies. Have a great Memorial weekend!
    Chillyone
  6. May 25, 2011 at 4:46 PM
    wildjerseyfirefighter
    wildjerseyfirefighter I sell fishing and fishing accessories
    Joe
    NJ
    05 Tacoma TRD Sport
    stock, for now
    I was in the same boat as you..I have now replaced the Evap(under the glove box), hardlines going to it,the pressure switch and rebuilt the stems that you charge the AC thru..Im getting it charged tomorrow, and hope it holds this time.
