A/C Vent on Drivers Left - Always on?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OdiN1701, Feb 27, 2017.
  1. Feb 27, 2017 at 7:06 AM
    OdiN1701
    OdiN1701 [OP] Well-Known Member
    Colorado
    2017 Quicksand TRD OR DC SB
    So no matter what mode I have the A/C in (foot only, foot + defrost, defrost, etc.), there is always a good flow of air coming out of the drivers left vent. Does anyone else have this? Other vents have a tiny bit of air coming out but this one has a lot even when it's not on a mode that would have the upper vents active.
  2. Feb 27, 2017 at 7:15 AM
    c4lvinnn
    c4lvinnn Well-Known Member
    '17 TRD Off Road DCSB
    Turn on your recirculate button.
  3. Feb 27, 2017 at 7:16 AM
    Kirk5370
    Kirk5370 Well-Known Member
    Toronto, Ontario
    2017 DCLB TRD Sport +
    Clazzio, Weatherbeaters, Softopper
  4. Feb 27, 2017 at 7:16 AM
    OdiN1701
    Colorado
    That doesn't really answer my question.
    And besides, you can't recirculate when you're using the defrost.
  5. Feb 27, 2017 at 7:19 AM
    OdiN1701
    Colorado
    Thanks, so it's not just mine then. I thought maybe a connection was screwy or something.
  6. Feb 27, 2017 at 7:20 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    I believe its setup that way so as to defog the driver side window.
    nv529 likes this.
  7. Feb 27, 2017 at 7:20 AM
    c4lvinnn
    When the AC is off, if your recirculate button is off, fresh air will continue to flow into the cabin while driving. It may also be pointing air to the driver side window for safety reasons. I probably misread your OP. It's still early.
  8. Feb 27, 2017 at 7:20 AM
    CudaRavage
    CudaRavage Well-Known Member
    Parma, Ohio
    2017 SR 4x4
    I love it. Even when the defrost is going on a cold day my hand gets a little warm breeze. Next best thing to a heated steering wheel.
  9. Feb 27, 2017 at 7:21 AM
    Kirk5370
    Toronto, Ontario
    Not likely an electrical connection by any means. All air comes from a central HVAC unit. If it -was- abnormal, just a faulty actuator within the venting.
  10. Feb 27, 2017 at 7:21 AM
    OdiN1701
    Colorado
    But there is already a vent pointed at the drivers side window for defrost.
    The vent I'm talking about is the round adjustable one.
  11. Feb 27, 2017 at 7:23 AM
    OdiN1701
    Colorado
    But it does this when I'm stopped as well.
  12. Feb 27, 2017 at 7:23 AM
    OdiN1701
    Colorado
    Yeah I meant something with the ducting or something, not electrical.
  13. Feb 27, 2017 at 7:24 AM
    OdiN1701
    Colorado
    I don't like it. Because it's pretty hot so it gets my hand too hot. I pointed it down for now. I like cold air from there in the summer, but mostly I use feet/defrost combo in the winter.
    CudaRavage[QUOTED] likes this.
  14. Feb 27, 2017 at 7:28 AM
    c4lvinnn
    First world problems lol
  15. Feb 27, 2017 at 7:29 AM
    OdiN1701
    Colorado
    lol...I can just point it away - I just wanted to make sure others also did this and it wasn't some messed up ducting connection or a flapper that's not working or something.
  16. Feb 27, 2017 at 7:29 AM
    Blktre
    Blktre Well-Known Member
    Land of Oz....
    16 Super White DCLB TRDOR: The White Goat
    I just shut that vent when using defrost if I need too. It is strange tho. I guess the normal side window defrost vents need some help.
  17. Feb 27, 2017 at 7:33 AM
    c4lvinnn
    I never noticed it flowing air when I'm stopped with the AC and recirc off. Multiple cars of mine prior were the same way turning the recirc on if the AC was off so I didn't think anything of it. Nor have I noticed any air flow coming from vents they shouldn't be when on different modes.
  18. Feb 27, 2017 at 7:36 AM
    OdiN1701
    Colorado
    Okay, so hopefully I can get some feedback from others to see what they notice. It's just odd as this isn't the way any of my other vehicles have been.
  19. Feb 27, 2017 at 7:42 AM
    sureshot
    sureshot Well-Known Member
    Middle TN
    2016 TRD Sport
    Nothing yet...
    I'm sure it's another poor QA instance here... mine does it too. If I have heat on in the floor, I have to shut that vent too keep my hand from burning up.
  20. Feb 27, 2017 at 7:44 AM
    Cheers007
    Cheers007 Well-Known Member
    DFW
    2017 Tacoma Limited
    This is normal for Japanese cars (and most Korean cars as well). I'm not sure if American cars follow suite.
    But yes, this is normal.
