A/C Vent smell....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 10TRDOFFROAD, Jun 17, 2011.
  1. Jun 17, 2011 at 4:08 PM
    10TRDOFFROAD
    10TRDOFFROAD [OP] Well-Known Member
    Jamf
    Las Vegas
    10 TRDOFFROAD Quad 4x4
    Ok,heres the deal. When running the A/C. If i open the vent to the outside. It smells moldy for while...? Ive never seen condensation dripping out from under the frame.....Is there a drain? Thanks in advance..
  2. Jun 17, 2011 at 7:18 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    There is a drain. If the drain becomes clogged, then your ac will start to smell like mold. Either you can find the drain and blow it out with compressed air, or your mechanic/garage can do it. This happens to lots of vehicles.
  3. Jun 18, 2011 at 3:03 AM
    808TUNDA
    808TUNDA Well-Known Member
    D
    Oahu, Hawaii
    so that's the smell. At least now I know what to have checked out on my next service visit.
  4. Jun 18, 2011 at 3:08 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    Also, if you run your ac a lot on recirculate, be sure to change the vent setting to "fresh air" bafore you turn off the truck. This way, when your vents get condensation in them, it will have a place to go and will evaporate out of the vehicle. Otherwise, the condensation has nowhere to go and can get moldy. Then, check your ac drain. We see a lot of spider webs in them or road debris. It should be a small rubber tube below the vehicle on the front pass side. There are bombs you can set off in the truck that circulate thru the ac system and kill molds and fungi too. Also, check the cabin filter.
  5. Jun 18, 2011 at 3:22 AM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Check this... especially post 36. Use Lysol. Make sure AC is on, but NOT on recirc (you want it pulling air in from the outside vents). Vents are outside, center bottom of windshield. You only need to do a couple of sprays. Also pay attention to the posts that tell you to turn off the AC the last couple minutes before you stop. Helps dry out the coils.
    http://www.tacomaworld.com/forum/2nd-gen-tacomas/87458-best-way-get-rid-ac-stink.html
  6. Jun 18, 2011 at 5:21 AM
    Old Soul
    Old Soul Well-Known Member
    NC
    09 AC V6 SR5 2WD SWB
    not to many, love it the way it is
    ^ yep, a few minutes before you reach your destination shut down the ac and just run fresh air through the system to dry out the a/c airways
  7. Jun 18, 2011 at 2:50 PM
    10TRDOFFROAD
    Jamf
    Las Vegas
    Thanks for all the advice. I still havent ever seen codensation coming from the tube on the fire wall. Will blowing compressed air INTO the drain tube. Push the debris back up into the drainage bowl.
  8. Jun 18, 2011 at 6:03 PM
    kd8awe
    kd8awe Well-Known Member
    Rocky
    Ohio
    4x4 TRD Off Road
    Fog mod, 3" lift, ShoMe stobes, MicroLight LED Strobes, HiLift Jack, RCI 2950, Yaesu 8900r, 20% Tint, ScanGauge II, Weathertech Side Window Deflectors, *** New Mod's (parts on the way) *** U-Bolt flip kit. Tom Woods 1 Piece Double Cardan Drive Shaft. 3* Axel Shims
  9. Jun 19, 2011 at 12:29 AM
    808StateTacoma
    808StateTacoma SEARCH button is my BEST FRIEND
    Honolulu, Hawaii
    Magnetic Grey 2010 TRD Sport Access Cab
    Weathertech Floor Mats Wet Okole Seat Covers Ultragauge Flowmaster Original 40 Series Rear Suspension TSB SlimbCubby 4300K HID Hi/Lo
    Was wondering the same thing. Now i know what i can do.
  10. Jun 19, 2011 at 12:38 AM
    MountainEarth
    Bryan
    CO
    2010 TRD OR Access
    I'd really be surprised if your consensation tube was clogged given it's a 2010.
