A/C wont turn off
Discussion in 'Technical Chat' started by Hilts, Sep 28, 2012.
  1. Sep 28, 2012 at 11:24 PM
    Hilts
    Hilts [OP] New Member
    i'm just joined here so go easy. i own a 2004 TRD Tacoma
    my a/c, heat, defroster works great but when i turn it off i noticed I put my hand on the vents and I still feel it blowing cold air and then when I swtich it to heat i can feel it get hot. even with the temp control off
    does this seem like a common problem or something different? thx for any help
  2. Sep 28, 2012 at 11:42 PM
    kirkofwimbo
    kirkofwimbo Well-Known Member
    Clayton
    Wimberley, TX
    ‘21 Tundra SR 4x4
    Turning your recirc. on will keep that from happening
  3. Sep 29, 2012 at 7:42 AM
    iroh
    iroh Well-Known Member
    michigander
    07 AC SR5 2.7 5MT 4x4
    tonneau
    Since the hvac inlet is under the windshield, a high pressure area when driving, it'll naturally force air through the system when you're going down the road.
    It was actually strong enough on my Civic that I always just shut the fan off when going 70.
    As captain kirk said the recirc will divert the system's inlet to one inside the cab and block that flow.
    Some systems (most Fords for sure) will shut a flapper so off really means off.
  4. Sep 29, 2012 at 7:44 PM
    Hilts
    cool, that seemed to fix it. thanks Tacoma World
