A camper top that can handle a load?
Discussion in '1st Gen. Tacomas (1995-2004)' started by vegetopia, Aug 16, 2010.
  1. Aug 16, 2010 at 3:47 PM
    vegetopia
    vegetopia [OP] newbie
    Jamie
    Houston
    08 DCSB TRDOR 4x4 MANUAL
    2008 Toyota Tacoma 4x4 TRD Off Road SR5 Double Cab 6.0L 6MT
    Hey all, I'm thinking of getting a camper top for my '03 extended cab pre-runner, but wanted some advice.
    My primary use for the truck will be hauling lumber for framing houses, etc. so I'm imagining going to grab a few 2x12x20s, 2x4s, etc. I won't be hauling a lot at any given time, but I am assuming it will be fairly heavy.
    so, I would like to have a camper that I can put a rack on and be able to carry a good amount of weight on top.
    Any suggestions, or am I asking for the impossible? I know I can just make a lumber rack, which is what I will do if I have to, but I am also a photographer, so I would like to be able to put my lights, stands, gear, etc. in the camper and not worry about the elements getting to them while on assignment.
    TIA
    -Jamie
  2. Aug 16, 2010 at 3:58 PM
    Mush Mouse
    Mush Mouse Club Soda Not Seals
    mush
    where ever you want me to be
    2013 SR5
    its a Toyota truck and that's all the modifications needed
    ARE brand,I had a fiberglass shell on my Hi Lux 95 truck it was tough and the price was reasonable. I would try to find a used one lots of people try to sell them check out the 4 sale ads in your newspapers or online,
  3. Aug 16, 2010 at 6:33 PM
    vegetopia
    Jamie
    Houston
    I'll check it out, thanks.
    any other suggestions? What about fabbing up a steel "cage" that goes inside the camper to give it reinforcement? Although at that point, probably not worth it.
  4. Aug 16, 2010 at 6:54 PM
    Namyo
    Namyo -
    Fab a cage on the outside of the camper....custom or factory. I kno I've seen a lumber rack on the out side of a shell.
  5. Aug 16, 2010 at 7:01 PM
    Barnone
    Barnone Guest
    I never carried any 2x12x20's but a lot of shorter lengths on my aluminum topper. Twenty foot length's would require a rack on the front bumper.
    I have abused it for eight years. Can't remember the make or load capacity but I'm sure that I have exceeded it. Had a load of PVC pipe on it today. It sure is handy.
    Don't know if you can see the racks on top of the topper but they seem stout enough.
  6. Aug 16, 2010 at 7:04 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    I wouldn't trust a shell to carry the weight you are probably used to. They make lumber racks that fit around shells.
  7. Aug 16, 2010 at 7:08 PM
    vegetopia
    Jamie
    Houston
    does the same company that makes the shell, make the rack as well? thats not a bad idea at all. I would be worried about it looking a little bulky and awkward though.
  8. Aug 16, 2010 at 7:11 PM
    JoeyTacoma
    JoeyTacoma Well-Known Member
    Eagle, Colorado
    2017 TRD Off-Road Pro Cement
    285/75 R16 BF Goodrich All Terrain KO2
  9. Aug 16, 2010 at 7:38 PM
    Barnone
    Barnone Guest
    Take a look at some aluminum shells before you go with the outside rack. My shell's frame is made of 1" square aluminum tubing.
  10. Aug 16, 2010 at 7:43 PM
    whitebread
    whitebread Well-Known Member
    Raleigh, NC
    2011 4x4 DCSB TRD Off-Road
    Leer 100XL and a bunch of off-roading scars.
    If you order a shell, and think you might end up wanting the ladder rack, make sure you specify you don't want the shell to wrap around the bed rails.
  11. Aug 16, 2010 at 7:52 PM
    vegetopia
    Jamie
    Houston
    ladder rack's not a bad looking option. seems strange that that "flimsy" 1/4" plate steel sticking out from the bed rail under the shell is enough to support 1000lbs +
  12. Aug 16, 2010 at 7:53 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
  13. Aug 18, 2010 at 5:32 AM
    oliverlove
    oliverlove Well-Known Member
    Oliver
    Laguna Vista, TX
    01 SR5 Ext Cab
    My local fab shop is working on a internal support for my cap so I can mount a tent up top. They basically are going to run a support from the floor of the bed up to where the rook rack mount is on the cap. It is a ARE cap. It should be pretty simple when it is finished and carry more than it needs too.
  14. Aug 20, 2010 at 7:24 AM
    vegetopia
    Jamie
    Houston
    you definitely gotta post some pics of that when it's done. sounds like exactly what I'm interested in.
