A "Clunk" After Pushing the Brake
Discussion in '2nd Gen. Tacomas (2005-2015)' started by myname150, Feb 21, 2011.
  1. Feb 21, 2011 at 11:50 AM
    myname150
    myname150 [OP] Well-Known Member
    I finally was able to capture the clunk i hear from hitting the brakes, what i found on the search is that it could have something to do with the pads and callipers.
    It happens whenever ive been driving for a while and i approach a stop light, like a second or two after i depress the brake pedal. This is pretty random.
    I have noticed i can make it happen on demand as i move back and forth between Reverse and Drive, Which is what i did in this video, it can be clearly heard at about 0:38-0:39. And at about 0:37 you can hear me push the brake pedal. Watch it in HD.
    http://www.youtube.com/watch?v=ysaICw5FWOU?fs=1
    Sooo, does anyone mind clearing up what this could be and if anything needs to be repaired? As far as i can tell, the truck still drives perfectly fine.
    UglyBetty likes this.
  2. Feb 21, 2011 at 11:52 AM
    T-rev
    T-rev Resident Mall Crawler
    Tempe, AZ
    2017 TRD Offroad
    My truck has always done this, from what I've found this is normal.
  3. Feb 21, 2011 at 11:55 AM
    Costa09
    Costa09 Well-Known Member
    GA
    08 PreRunner
    I hear the same thing when stopping at a red light and switching back an forth between reverse and drive. I saw some where in the forums that is has to do with the brake pads on our trucks. They have a lot of play in them that causes that clunk you hear.
  4. Feb 21, 2011 at 12:03 PM
    RichardTRD
    RichardTRD Well-Known Member
    Richard
    Oregon City Oregon
    2017 Tacoma TRD OFF ROAD 4X4
    Ironman4x4 pro stage2 lift, 285/75/16 Nexen Roadian MXT tires, leer shell, Pro hood, Raceline 16x8 0mm offset wheels, prinsu cab and topper racks, FSR High country 55" RTT and Bedslide.
    Mine will do it slightly just after starting up and taking off in drive. The first slow stop I come to it makes that faint clunck noise, I can feel it in the pedal to... Then I really dont hear or feel anything after that.
  5. Feb 21, 2011 at 12:07 PM
    ACBWV91
    ACBWV91 Well-Known Member
    Adam
    Charleston/Motown WV
    08 Access Cab 4x4
    Any of you know of something called axle wrap? I could be wrong cause i havent heard it mentioned for a while and it may just be on the first gen... That sounds like it could be it though
  6. Feb 21, 2011 at 6:30 PM
    myname150
    Naaah because i have a 4x2 PreRunner, so no front Diff or Axle :).
  7. Feb 21, 2011 at 7:45 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Mine has been doing the same thing FOREVER. It even does it when I hit a bump/pothole. No clue what it is. Sounds like it's coming from the front left wheel area right?
  8. Feb 21, 2011 at 7:47 PM
    snowgod06
    snowgod06 UG legend wannabe
    Rob
    A farm field, OREGON
    06 Access Cab
    crap bolted and welded together....
    its normal, just the brakes doing their thing. There is a thread somewhere about it, but no worries man its all good.
  9. Feb 21, 2011 at 7:49 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Axle wrap comes from the rear diff and leaf spring setup.
    I had a loud clunk in the same circumstances as you. It turned out to be the the front suspension bolts were not tight. And also check your rear suspension bolts. Torque them all to spec, but be careful when tightening the front cam bolt in that you don't mess up your alignment.
    EDIT: I didn't watch the video, but if its a loud metal on metal clunk, and not a "ting" sounds like others are saying, then it could be what was with mine
  10. Feb 21, 2011 at 7:50 PM
    05Moose
    05Moose Middle-Aged Member
    Jim
    In the snow (NorCal)
    '05 4x4 DC LB SR5 #8 (LSD, Tow Pkg)
    '05 4x4 DC LB SR5 (LSD & Tow Pkg), Timbrens, AAL, 5100s (1.75), Owned: 12/3/04 Mods: Fog, Map/Dome Light, Illuminated 4wd Switch, Washable Cabin Air Filter
  11. Feb 21, 2011 at 7:51 PM
    Costa09
    GA
    08 PreRunner
    There a reason why there is so much play in them though? I remember reading a thread but never said why, just the way they are designed?
    OP-Do not mean to seem to still your thread man just a quick question.
  12. Feb 21, 2011 at 7:53 PM
    snowgod06
    Rob
    06 Access Cab
    Yea I don't remember why they do it, someone in another thread explained it. But really no need to me alarmed by it.
  13. Feb 21, 2011 at 8:00 PM
    El Tano
    El Tano i am the one who knocks
    Pasadena. CA
    10 Tacoma TRD sport
    Corvette homelink FRONT: 5100 Blinstein set at 0 Procomp 3" leveling kit Allpro UCA’s. REAR: Icon Multi Rate RXT Leaf Pack 5100 Blinstein. 17x9 kMC wheels 0 BS 285/70 17 Wildpeak A/T4W C range Amp research steps. and a bunch of TSB's
    Same problem here.. Another "Little oopsie from Toyota".
  14. Feb 21, 2011 at 8:10 PM
    esizzle777
    esizzle777 Son of Most High
    Laredo, TX
    16 TRD Sport
    i thought it was just mine!! norms by the looks of things now
  15. Feb 21, 2011 at 8:18 PM
    Costa09
    GA
    08 PreRunner
    Yep, also read somewhere were Chris4x4 said it could be the truck shifting down to 1st when it comes to a complete stop
  16. Feb 21, 2011 at 8:22 PM
    S.B.
    Sean
    San Diego
    15 Taco
    Same thing toyota says. When they actually try to give a reason.
  17. Feb 22, 2011 at 7:21 AM
    05Moose
    Jim
    If Toyota would have designed the pins, calipers, and brake pads to better tolerances, it wouldn't happen. But then you might have more difficulty sliding the pins through the calipers and pads. Still, there's too much space in between which allows them to shift. I've always worried that the pins would wear down when they're getting slammed back and forth over the years. But after almost 6 1/2 years, my front brakes have yet to fail. I'll be sure to let you know if they eventually brake and I crash as a result.:D
    FYI, I believe the solution in the TSB to reduce the noise was to add grease to the pins (so you don't hear the "Ting").
  18. Feb 22, 2011 at 10:45 AM
    Costa09
    GA
    08 PreRunner
    Yeah lets hope we don't here that result from you. I have done gotten used to it
  19. Mar 1, 2011 at 9:21 PM
    EEtaco
    EEtaco Well-Known Member
    North Carolina
    09 V6 Prerunner
    I've been hearing this for the past 6 months and thought I was crazy and looked everywhere for the source. The brakes seem to be the most plausible answer. A friend and I took turns trying to figure out where it came from and it sounded more from the tranny, but assuming both left/right brakes do it, it was probably tricking our ears to the middle of the front end.
  20. Jun 17, 2014 at 9:56 PM
    chadleeper
    chadleeper "She's a 'beaut Clark"
    Chad
    West Des Moines, IA
    Black 08 quad cab TRD Sport
    Anyone confirm the problem goes away after replacing pads with say aftermarket green pads??? Brakes seem fine but, kinda embarrassing leaving work sometimes...
