A conservative approach to high mileage transmission flush
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 911monty, May 2, 2023.
  1. May 2, 2023 at 8:24 PM
    911monty
    911monty [OP] Active Member
    Monty
    07 Tacoma TRD Sport
    Okay I have read the many threads on wether it is better to never touch or throw caution to the wind and everything in between that my head is spinning. So thought I'd throw an approach that I haven't seen mentioned out for comments.
    So background. I recently bought a 07 Tacoma SR5 TRD sport 4.0 with 5 speed auto trans and 207k on the odo. I am working on establishing a baseline on maintenance. I attempted to have a fluid flush on the trans at 2 dealers and they refused since there is no record of fluid ever being changed. Bummer.
    I'd like to know the condition of the current fluid before I make a decision on which way to go. So I am thinking of doing the following. Add 1/2 qt new fluid to the trans. Bring to temp and drain through the level check drain. This approach does 2 things. Make sure tranny is at proper level, and I should get back some dirty fluid to evaluate condition of the existing fluid and make a somewhat informed decision. This can be done for the cost of 1qt fluid and 2 sealing rings.
    Thoughts?
    Rick's 2012 likes this.
  2. May 2, 2023 at 8:32 PM
    Geeves77
    Geeves77 Well-Known Member
    Mark
    Northeast
    2011 Tacoma DCSB
    3 inch Icon lift with UCA’s
    Just saying here my first 2nd Gen 2005 DCSB 235,000 I dropped the pan and filter and changed out soon as I got the truck. Ran it till 258, then got totaled but had no issues at all tranny ran great. I don’t believe in the old tales. Living proof right here, and actually helped my shuttering a bit
  3. May 2, 2023 at 8:36 PM
    911monty
    Monty
    07 Tacoma TRD Sport
    So you're saying 25k miles later the truck quit moving at all? LOL
  4. May 2, 2023 at 8:44 PM
    Geeves77
    Mark
    Northeast
    2011 Tacoma DCSB
    It could move, just needed a nose, but INS paid me 10K
    911monty[OP] likes this.
  5. May 2, 2023 at 8:59 PM
    BluberryBCtaco
    BluberryBCtaco Making the magic happen
    BC Canada
    2007 Tacoma Sport DCLB
    3in lift, Tow package, Any time 400w inverter, in cab outlet, vinyl floor, roof rack
    I just had it changed today on my truck by Toyota.
    Reason being there is no record from the previous owner when they changed it.
    So, that is a massive question mark and I too wanted a baseline records.
    But I do see evidence it has been changed at some point in its life.
    So far, since the auto trans fluid change no shuddering, no grinding etc.
    I did the same for my auto Mini Cooper but that was forced onto me, when a plastic drain plug broke. Still no issues after 3 years from that incident.
  6. May 2, 2023 at 9:04 PM
    911monty
    Monty
    07 Tacoma TRD Sport
    Did they do the flush or drain and fill?
  7. May 2, 2023 at 9:13 PM
    BluberryBCtaco
    BC Canada
    I requested a Drain and Fill for now.
    As in my mind/hypothesis at least I can keep some of the “old” fluid in there for now to mix with the new stuff.
    I wanted to be as minimally invasive as possible. At least for now.
    In a 1-2 years time I will ask them to drop the pan, clean up the filter, flush and reinstall. That way both the old and the new fluid has a chance to “break in” and “mix”.
    I have no evidence to support my hypothesis/ plan. But it makes sense in my mind.
    edit: changing the fluid at least in my experience is a good thing.
  8. May 2, 2023 at 9:28 PM
    911monty
    Monty
    07 Tacoma TRD Sport
    I understand your plan. I am actually happy the dealer did not do the drain and fill on mine. Once I do my test I will at a minimum drop the pan and change the filter. I want to personally see the condition of pan and contents.
  9. May 2, 2023 at 9:32 PM
    BluberryBCtaco
    BC Canada
    I did ask the actual mechanic about the auto filter, he said “Unless there is a lot of metal particles, we just clean it and throw it back in there.”
    Make of that what you will.
  10. May 2, 2023 at 9:40 PM
    911monty
    Monty
    07 Tacoma TRD Sport
    I don't have much experience with automatics, almost all my cars have been manuals.
    But here is my experience FWIW. My son worked at a Ford dealer. They took an AMC Pacer as a trade in. Desperate to just get it off the lot they gave it to my son. Awesome right? We drained the trans and what came out looked like mud. Poor car. We dropped pan cleaned and installed new filter 4 times over the next week. Fluid looked like new on final drain. If any high mileage trans was going to fail that one would get my vote. No problem at all with the transmission until it burned to the ground.
