A couple issues...
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rreed1900, Sep 11, 2019.
  1. Sep 11, 2019 at 8:48 AM
    rreed1900
    rreed1900 [OP] Member
    Bob
    Westminster, MD
    2015 Toyota Tacoma
    Hi,
    I have a 2015 Tacoma (TRD Off Road) and there are a couple issues I'd like to get fixed and I'm seeking advice on how to fix them:
    1. The passenger side rear mud flap is losing the white paint on it. Is there a way to reapply it without it looking like some schlub (me) just slapped some paint on it and called it a day?
    2. The inside sides of the bed are scratched from hauling mulch (and me not being as careful as I should have been). I've tried Mr. Clean pads and they did nothing. I think the scratches are too large to remove. Is there a way to fix these?
    Any advice you could offer would be much appreciated.
    Bob
  2. Sep 11, 2019 at 9:23 AM
    Oreo Cat
    Oreo Cat Worst Member
    Coeur d’Alene, Idaho
    Take off the mudflaps and throw in a bed mat
  3. Sep 11, 2019 at 10:20 AM
    rreed1900
    Bob
    Westminster, MD
    2015 Toyota Tacoma
    No dice. The mudflaps stay. I just want to redo the "4x4" thing on them in a way that doesn't look like a rank amateur (me) has done it. And I already have a bed mat in it. I was referring to scratches on the interior sides of the bed. But thanks for the ideas.
  4. Sep 11, 2019 at 10:24 AM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    You could look for someone willing to sell you their mudflaps. Many people remove them and may have some laying around. As far as the scratched on the bed sides, your bed is made of composite material so you should be able to use a fine sandpaper to smooth out the scratches. Aside from that, I don't think there is anything you can do. Another option would be to get a BedRug (https://bedrug.com/bedrug-classic-bedliners/2017/toyota/tacoma?ref=buildprint) and line the entire bed.
  5. Sep 11, 2019 at 10:26 AM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    Paint pen for the mudflaps,nothing you can do about the scratch's in the bed,except coat it with a bedliner.
    Wattapunk likes this.
  6. Sep 11, 2019 at 10:43 AM
    Oreo Cat
    Maybe for the mudflaps one of those tire markers
  7. Sep 11, 2019 at 10:48 AM
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    1. Paint pen
    2. No
    Most important, it's a truck the bed will have scratches. Little gouges cant be buffed out since its composite. If it drives you nuts then have a nice bedliner of your choice installed
  8. Sep 11, 2019 at 10:55 AM
    JeffP213
    JeffP213 I used to do mods. I still do, but I used to, too
    Jeff
    Central, VA
    15 TRD OR
    I’ll sell you my mudflaps off my ‘15. Haven’t had them on the truck since about 8,000 miles (at 50k now) Pm if you’re interested.
    sdsurfer likes this.
  9. Sep 11, 2019 at 11:01 AM
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    @rreed1900 ... Here's a good solution for your mudflaps.
  10. Sep 11, 2019 at 11:38 AM
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    For the mud flaps, tape is your friend. You can redo taping off the "4X4" as many times as you like until you get it perfect then using some "flexible" paint have a go at it. If it doesn't turn out well clean it off and try again. As for the bed, stick a tonneau cover over it and no one will see any scratches. Or just run with them as a badge of honor.
  11. Sep 11, 2019 at 11:42 AM
    rreed1900
    Bob
    Westminster, MD
    2015 Toyota Tacoma
    I think the suggestion from @AECkraut is worth trying. I will take a shot at taping off the mudflaps and spraying them with plastic paint. If that doesn't work, I will buy used ones in decent shape. Thanks to everyone for the ideas.
    ACEkraut and JeffP213 like this.
  12. Sep 11, 2019 at 12:50 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    Get a little acetone and take the "white" off of the flaps.....the 4X4 will still be there as a "ghost" image, and you never have to worry about again.
    A bed rug will cover the unsightly scratches and they are tough as nails.
  13. Sep 11, 2019 at 12:56 PM
    road2cycle
    road2cycle Well-Known Member
    Sonoma County, CA
    2014 Tacoma DCLB 4x4 Limited
    Scratches in the bed add character to it. I used to care that my bed had scratches then realized those scratches mean it’s being used for its intended purpose.
    I did inquire at Line-x about getting the bed sprayed, since it’s freaking slippery when wet, but was told they won’t spray a composite bed. So I got a bed mat to resolve that.
  14. Sep 11, 2019 at 3:01 PM
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    the 4x4 comes off all of our flaps so replacing is just a temporary fix. Just ignore the fade and move on.
  15. Sep 11, 2019 at 3:07 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    I mean, it's a truck. If you use it, it won't stay mint forever. I guess you could figure out some sort of spray on bed liner and just replace the mud flap?
  16. Sep 11, 2019 at 3:52 PM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    As above, just clean the white off the mud flaps looks better anyway. Did that to mine years ago. Simple Green and a scrub sponge its done. Had a Toyota bed mat since 09 and it leaves black on some things and its in a camper shell so not a cure all but stuff does not slide too much.
  17. Sep 11, 2019 at 4:46 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    I think those aren’t your only issues. :annoyed:
