A couple of retrofit questions...
Discussion in 'Lighting' started by Erik37, Jan 26, 2014.
  1. Jan 26, 2014 at 12:20 PM
    Erik37
    Erik37 [OP] Well-Known Member
    Langley, BC, Canada
    2012 DCSB TRD Sport 6spd leather
    I want to order the mini h1 kit from TRS for the next group buy. Just wanted to know if I get the mini gatling gun shrouds what size halos do I get that will fit them? Or would I need one of the bigger shrouds to have halos?
  2. Jan 26, 2014 at 6:24 PM
    03is300ztk
    03is300ztk Well-Known Member
    Zach
    Somewhere in the hills NC
    07 Tacoma 4X4
    Grillcraft, with front and rear bumper/bed in the works.
    Email or call trs and ask they should have the measurements
  3. Jan 26, 2014 at 10:17 PM
    XXFattyHunterXX
    XXFattyHunterXX Well-Known Member
    Westminster, Colorado
    T4R
  4. Jan 27, 2014 at 4:31 PM
    A7xschecter6661
    A7xschecter6661 InSight Retrofits Official
    Pete
    13901, NY
    I recommend the few extra bucks for FXR. The install is just as easy. Better output and ability to run 55w.
    As for halos I say nay, another member on here installed his and in a week or so only 2/3 of a halo was lighting up on one side.
    I keep the retro's simple so there is less to fail. Would I like amber halos? HELL YEAH! I don't want to have to deal with parts going bad though
  5. Jan 27, 2014 at 5:05 PM
    03is300ztk
    Zach
    07 Tacoma 4X4
    I'm in love with the X lens.
    X is on the left O lens on right.
  6. Jan 28, 2014 at 1:15 PM
    Erik37
    Langley, BC, Canada
  7. Jan 28, 2014 at 1:23 PM
    Mainmoe02
    Mainmoe02 Well-Known Member
    Moe
    Austin, Texas
    01 Gold tacoma SR5 TRD
    3" lift EIBACH coils w/ 5100's front, OME/ Dakar leaf springs w/ toytec adjustable shackles at 1.5" and 5125's out back. 33x10.5x15 KM2's Relentless DIY steel bumper.
    70mm halo will fit on the smaller lip of the shroud. I have this one and I'm now going to the 80mm so it will sit on the outer lip. At night when both the halos and projectors are on, the 70mm looks good but if I would have gone with 80mm it gives the illusion that the projectors/ beam of light is bigger. When you look at them from far away they look small. I've seen some with 80mm and for whatever reason the 80 gives the bigger appearance. Since halos are basically for aesthetics I want them to look proportionate to the housing.
    Oops, forgot to ask if your mounting them on the outside or inside of the shrouds? If it the inside then I think 70mm is your choice. But if it's the outside of the shroud then you can choose between 70mm or 80mm
  8. Jan 28, 2014 at 6:56 PM
    Erik37
    Langley, BC, Canada
    I was going to mount them on the outside. I didn't know mounting them on the inside was even an option. Wouldn't the light output be blocked by the shroud and projector?? I already ordered the 70mm but I don't think the group buy is over yet. Maybe I should phone TRS to see what they say.
  9. Jan 29, 2014 at 9:51 AM
    Mainmoe02
    Moe
    Austin, Texas
    Yeah mounting them on the inside of the shroud would give it a cool effect because the shrouds have roughly 1" slits spaced out about 1" apart around the middle part of the shroud. So when you mount the halo inside the light peeks through giving the "glowing" effect. I'm gonna order a set of 80mm for the outside lip and keep my 70mm and mount it on the inside of the shroud.
  10. Jan 29, 2014 at 5:06 PM
    Erik37
    Langley, BC, Canada
    Interesting. I'll have to try that and see what it looks like. I'm thinking I might like it better on the inside.
  11. Jan 29, 2014 at 10:41 PM
    bluesteel731
    bluesteel731 Toy taco
    PNW Vancouver BC
    White TRD Tacoma DCLB
    FX-R III, Bestop, custom rock sliders, 2.5 ext RR kings 650/14, icon uca, AP expo, bilstein 5165 9.5" w/stem to eye, OBA ARB compressor and ARB rear locker, MR304 w/Cooper STT PRO 295/70/17, TAC WORX light bar mount behind the grill, Rock lights, OTRATTW switches, TAC WORX bed rack with hilift mount, TJM RTT w/annex, CMC
