A couple problems engine and heat
Discussion in '2nd Gen. Tacomas (2005-2015)' started by airsoft_warrior, Dec 6, 2009.
  1. Dec 6, 2009 at 1:04 PM
    airsoft_warrior
    airsoft_warrior [OP] Batman
    Zack
    Edgewater, Maryland
    2015 Tacoma DCLB Limited
    TRD Performance Exhaust
    I drove 125 miles yesterday and while on the highway I noticed that the truck was shifting harshly and that the engine wasn't running any higher than 2000 Rpms. I have not experienced this problem yet and wanted some advice before just running to the mechanic. The other problem was with the heater. When only the heater is on ther is a whirring sound from the blower under the dash. I checked and there isn't anything under there. It only happens with the g
    heat on and very annoying. Any ideas?
  2. Dec 6, 2009 at 1:20 PM
    brian
    brian Another Traitor
    Elizabeth City, NC
    2017 F-250 Powerstroke
    sounds fucked? maybe its in safe mode? Any CEL?
  3. Dec 6, 2009 at 1:25 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    What is cel? I didn't do anything to put in safe mode ( at least that I know of)
  4. Dec 6, 2009 at 1:33 PM
    LEBM
    LEBM Thread Killer
    Eleanor, WV
    15 DCSB TRD Sport 4x4 - Pyrite Mica
    CEL = check engine light
  5. Dec 6, 2009 at 1:44 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    Nope the check engine light never came on. I had went hunting last week and had the truck in 4wd then when I unlocked them the truck jolted I dont know if that may have something to do with it or not.
  6. Dec 6, 2009 at 2:00 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    Thanks I will try that when it warms up some. There is still some snow outside and dont feel like getting soaked while doing this. The strange part it its only the heat not the A/C. I ran the A/C for a while and no noise at all. I also noticed that i might have blown a tweeteror speaker at some point, I dont put my music up loud so I dont know how that would happen. It is the troublesome time of the year.
  7. Dec 6, 2009 at 3:03 PM
    brian
    Elizabeth City, NC
    Well, does it feel like it still has power, its just not revving as high? I think safemode only reduces power, not sure about RPM control.
  8. Dec 6, 2009 at 3:07 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    It still feels like it has some power I was able to get up to 70mph but not much more. It felt like it was lagging. If that makes sense.:confused:
  9. Dec 6, 2009 at 3:13 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Kinda sounds like you have something blocking the airway......Pop the air filter housing and see if everything is OK...
  10. Dec 6, 2009 at 3:15 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    Yeah I havnt checked that yet. Will do that tomorrow
  11. Dec 15, 2009 at 8:46 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    How do I check to see if it is in safe mode? The battery was drained (oops!) right before i noticed it revving different.
  12. Dec 16, 2009 at 5:04 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    Disconnect your battery cable again for a few minutes, then see what happens.
  13. Jan 9, 2010 at 12:21 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    Did this. The filter was dirty but nothing blocking passage. Can I just remove the clamps on the battery? They are bolted down. I dont want to get shocked.
  14. Jan 9, 2010 at 12:42 PM
    vbibi
    vbibi Well-Known Member
    san fransisco bay area
    2009 4door long bed
    You are in for a rough ride my friend.... and you do not get shocked from disconnecting your battery. Just take them off one at the time, negative first.
    take care
    vbibi:(
  15. Jan 9, 2010 at 1:00 PM
    Taco-NB
    Taco-NB MMMMM Taco's
    New Brunswick
    '09 4X4 SR5 Access Cab V6 - Black Sand Pearl
    You have an '08 so it should still be under warranty?? Sounds like it's time for a trip to the shop.
    :cheers:
  16. Jan 9, 2010 at 6:03 PM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    Yeah I was thinking about that. I tinkered with the blower today i think it is okay for now. I dont feel like taking it to the shop because then i am out of the truck for 2 days.
  17. Jan 9, 2010 at 9:08 PM
    05sctaco
    05sctaco Well-Known Member
    Ken
    Santa Cruz
    check to see if you have any blown fuses. Also check your fluids that you can check. Are you shifting hard also, the engine might be fine but your tranny might be bad, I've read the stories of exploding transmissions.
  18. Jan 10, 2010 at 5:56 AM
    airsoft_warrior
    Zack
    Edgewater, Maryland
    It seems almost like the same problem with the 2010s except there is no TSB for mine.
