A.D.D. is not working?!?
Discussion in '1st Gen. Tacomas (1995-2004)' started by rg.hill, Apr 24, 2013.
  1. Apr 24, 2013 at 6:43 AM
    rg.hill
    rg.hill [OP] New Member
    Tulsa, OK
    02 4x4 SR5
    Hello All! I am new to TW, but not new to Tacomas. I bought a 2002 Taco without testing the 4x4... Stupid me!!! After attempting to go offroad with it I discover that the 4WD is not working. I have narrowed it down to the Automatic Disconnecting Differential. I can tell that the actuator has been replaced, so before I pull that off and test it, I want to test the relay and/or the solenoid first. The problem is, I can't find either!!! The Haynes book is not very helpful with the location of these items, and I have crawled all over/under my Taco looking for them. Any help or suggestions would be greatly appreciated.
  2. Apr 24, 2013 at 3:19 PM
    camt10
    camt10 Well-Known Member
    03 ext cab sr5 trd 4x4
    There is actually a great 4wd diag chart that is used ,the ecu looks at various inputs ie voltage inputs to determine position that is key in diag anyways let me know exactly what u need when I get back to work tomorrow ill hook u up I'll send info via PDF .
  3. Apr 24, 2013 at 7:52 PM
    rg.hill
    Tulsa, OK
    02 4x4 SR5
    Well, according to the Haynes Repair Manual, the problem could be the actuator, relay, solenoid, or switch(not necessarily in that order). My truck does not have the switch on the shift lever, it comes out of the top right side of the transfer case, which I have not tested yet. I cannot find the solenoid or the relay. As for the actuator, I can tell that it has been replaced, so I'm guessing...that the previous owner replaced it and when that didn't fix the 4WD they traded it in. Haynes does not show an exact location of these items(keep in mind that Haynes covers years '95 thru '04).
    So, a diagram showing any of these items would be a big help... that or any other suggestions.
    Thanks!
  4. Apr 25, 2013 at 8:25 PM
    98Tacoma13
    98Tacoma13 Active Member
    mine was behind the passenger kick panel. 98 tacoma.
  5. Apr 25, 2013 at 10:57 PM
    bellassaiw10
    bellassaiw10 Formally afroman5015
    Currituck NC
    09 LMM 2500HD Duramax
    I lied... haha didnt read your post, I have a pdf to test the actuator at the plug though
  6. Apr 26, 2013 at 9:44 AM
    camt10
    Sorry took day off pm me your email ill send PDF
  7. Apr 26, 2013 at 12:03 PM
    Jkohler
    Jkohler HUH?
    Justin
    UT
    02 4DR Taco TDR Supercharged SR5 6in lift
    12" Icon 2.5 coilovers, 6" Drop Bracket, Tuff Country 5" lift knuckles, Icon 4''-8'' Extended Coilovers, Light Racing upper control arms, 7" Alcan leafs, 13" icon 2.0 smooth bodies in the rear. 2.5" exhaust with Magnaflow cats and Thrush muffler. 295x75x16 AT's (34.4") Superchargers Other shit like rear breather mod relocate, gray wire mod, intake elbow removed, led's, toolbox, etc
    One way to test it is get under there and undo the clip where the wires connect to the ADD, wait a few minutes, and then connect it back in. If the ADD makes a noise, It is good. If not, then you know that the ADD went out! This diagnose method worked for me when mine went out, not sure if its 100% accurate tho. Good luck!
  8. Apr 27, 2013 at 5:51 PM
    rg.hill
    Tulsa, OK
    02 4x4 SR5
    I did find a relay up behind the glove box, but it was a 4 prong relay, and according to Haynes, it is a 5 prong relay that I'm looking for. I did a part number search on that relay that I found, and the part number matched the part number for a headlight relay?!?!? I know that the fuse/relay box in the engine compartment behind the battery also has a headlight relay... But there was not a relay behind the pass. kicker panel.
  9. Apr 27, 2013 at 5:54 PM
    rg.hill
    Tulsa, OK
    02 4x4 SR5
    I'm assuming this is done with power to the unit???
  10. Apr 28, 2013 at 1:15 PM
    Jkohler
    Jkohler HUH?
    Justin
    UT
    Yeah. If you have a new ADD or one that you know works and you hook it up and it doesn't make a noise then you'll know that you have a bad solenoid or relay. If it makes a noise like its moving the forks, you'll know the ADD was bad. Heres a pic of the new one I picked up when mine went out.
  11. Apr 28, 2013 at 1:19 PM
    FreidTaco
    FreidTaco boost
    jeff
    Panhandle of Wyoming
    06 Tacoma TRD OffRoad SR5
    URD Stage 3 SC. 35" duratracs LT
