A different approach to rear shock relocation
Discussion in 'Suspension' started by Rattletrap66, Nov 20, 2016.
  1. Dec 28, 2018 at 7:10 AM
    #161
    Jerneyman
    Jerneyman Well-Known Member
    Wes
    Huntsville, AL
    2011 Tacoma TRD OffRoad 4x4
    **Armor** Home Fabbed Hybrid Front Bumper Home Fabbed Rock Sliders Home Fabbed IFS Skid Plate Home Fabbed Mid Skid Plate Home Fabbed Transfer Case Skid Home Fabbed High Clearance Rear Bumper **Suspension** ADS Front Coilovers (Extended Travel, 700lb coils, Remote Resi) Total Chaos UCAs Chevy 63 Swap w/ custom shock hoops 14" Bilstein 7100s **Wheels/ Tires** Spidertrax 1.25" Wheel Spacers Front/Rear TRD Rock Warrior Wheels 285/75/16 BFG KO2s **Electrical** Pelfreybilt Auxiliary Fuse/Relay Panel Blue Sea Fuse Box Bussman 100 AMP Breaker **Recovery** Smittybilt 9.5k Winch **Lights** 20 Inch Single Row LED Bar Rigid Side Shooters (Flood/Pair) w/ CBI Offroad Ditch Light Brackets Rigid Duallys, Amber for fog lights **Miscelaneous Mods** Rear Diff Breather Relocation RAM Mount A-Pillar Mod w/ Garmin Power Cable DRT Fabrication Cab Mount Relocation Pinch Weld Mod (Mini Sledge Special) Short Rise Bed Bar for Tire Storage/ Hi-Lift Mount
    My current wheels have a slight positive offset of 10mm. I was just going to put on a set of wheel spacers to account for the rubbing if I needed to. What offset are you running with your wheels to avoid the rubbing?
  2. Dec 28, 2018 at 8:04 AM
    #162
    Timbo's Customs
    Timbo's Customs Well-Known Member
    Timothy
    Lakeland FL
    2019 f250 6”lift 37s deleted 1997 T4r, tons and 4ds
    1997 t4r has super duty axles, 5.13s locked front and rear. 3 link front with 14" kings. Rear 63s.
    I’m running scs sr8s. 17x8.5 and 1.25” spacers in the back still slightly rub on a hard stuff
  3. Mar 26, 2019 at 12:24 PM
    #163
    Timbo's Customs
    Timothy
    Lakeland FL
  4. Mar 26, 2019 at 12:29 PM
    #164
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Ah, great, thank you for that.
  5. Apr 18, 2019 at 6:56 AM
    #165
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    I've been sitting on the towers and shocks for a while, bought them from someone who was going to do the swap and backed out, I'm planning on doing the 63's and this before long. Question is will my clutch go before I've got all the swap parts...
    But what's this about a 70 WMS axle you're putting in? Disc brakes? What's your new rear suspension plan?
    Ver curious! :D
  6. Apr 18, 2019 at 8:50 AM
    #166
    Timbo's Customs
    Timothy
    Lakeland FL
    Plan is a 3rs gen 4 runner with 06 f250 axles with 40s and a 3 link in the front, taking out the rear suspension and running leafs in the back
  7. Apr 18, 2019 at 7:14 PM
    #167
    mcharfauros
    mcharfauros IG: mcharfauros
    MO
    2017 Black TRD OR DC
    Dumb Truck Thangs
    :thumbsup:
  8. Aug 24, 2019 at 3:06 AM
    #168
    Mynameisbrandin
    Mynameisbrandin @4lofab
    Brandin
    New Braunfels
    2013 SR5 dcab short box
    2013 4dr Tacoma 4wd basically stock 2014 crewmax Tundra. DK long travel. 4Lo Fab goodies
    After reading they this thread I’ve decided to tackle this awesome idea. Got my shock towers in, ruffstuff axle mount tabs and fox 2.0 14” stroke shocks on the way. Will post up results when I get it done probably next week.
    Only concern will be tire rub on the shock, I’ll take plenty of measurements and all that of course. I have 4.5bs -12 offset wheels on 315s. Anyone by chance running that particular setup with this relocate done? If not, I can always do as mentioned above, cut the shock towers to be located more inward and weld over the cut. Just seeing if I have my work cutout for me or not :anonymous:
    mcharfauros likes this.
  9. Aug 29, 2019 at 9:32 AM
    #169
    Mynameisbrandin
    Brandin
    New Braunfels
    Well finally got it done and it works great. The stock mounts are kind of a pain in the arse to get off lol. I did modify the ford mounts to where they were almost touching the bed. Have my bumps setup to perfectly weld the shock tabs to the front middle of the axle housing. (Rebuilding the bumps while they’re out) Did a little articulating and I do need wheel spacers after all. Not a big deal. Great mod and glad I did and saved some coin. Here’s a few pics893B7760-AC46-483E-9CA5-ED5A25AE3D9F.jpgF423CF44-DA88-4C14-AA42-50B7C0922DE5.jpg 4C721C32-20FA-4179-811E-144CBCAF3350.jpg4CFDBA50-E40F-43D0-A765-62451E9BA6D6.jpg
    Crom, whatstcp, rlx02 and 7 others like this.
  10. Aug 29, 2019 at 11:30 AM
    #170
    Scott B.
    Scott B. Well-Known Member
    Scott
    Georgia
    2015 ACLB SR5 4x4 Expo
    Great idea on moding the Ford mounts.
    Crom and Mynameisbrandin like this.
  11. Aug 29, 2019 at 11:34 AM
    #171
    Jerneyman
    Wes
    Huntsville, AL
    I built some shop hoops that tuck up as high as I could make them (probably could've pushed up a bit higher, but reasonably, this is what I got). I didn't like how the Ford towers oriented the shock eye perpendicular to the bottom eye so this was my solution. The top plate will have 2 more bolts going up in to the bed that at some point will tie in to a crossmember from one shock hoop to the other.
    TacoEspecial and Stryker420 like this.
  12. Aug 29, 2019 at 11:34 AM
    #172
    Ariyan
    Ariyan Well-Known Member
    NM
    4x4 TRD Sport
    SAS, 40s, and some armor.
    I did the same thing except I added a plate on both sides to reinforce the mount. works good.
  13. Aug 29, 2019 at 11:50 AM
    #173
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Pics of said reinforcement?
    mcharfauros and Mynameisbrandin like this.
  14. Aug 29, 2019 at 11:53 AM
    #174
    SearArtist
    SearArtist GX poor
    NC
    GX470 & GX460
    Things
    Curious as to your reasoning to mount the top of the shock perpendicular instead of parallel?
  15. Aug 29, 2019 at 12:01 PM
    #175
    Jerneyman
    Wes
    Huntsville, AL
    When building suspension systems with spherical bushed rod ends like on coilovers or high dollar smooth body shocks, it’s best the run the bushings in the same orientation to prevent binding. I’m upgrading to Bilstein 7100s soon which have spherical bushings. I don’t think it’s as necessary with rubber bushed shocks like I have pictured. Most, if not all shock relocations for Tacomas do it this way except for the Ford mounts.
    With Ford’s original design where these were used, they too had the shock mounts oriented the same way albeit perpendicular to the frame instead of parallel how Tacomas have it but nonetheless with matching orientation.
    Hope that makes sense.
  16. Aug 29, 2019 at 1:29 PM
    #176
    Ariyan
    NM
    4x4 TRD Sport
    not a good picture but its the only one I have right now. Its literally just plates on both outer sides of the ford mount making it a little more than double the thickness.
    mcharfauros and Stryker420 like this.
  17. Sep 23, 2020 at 9:09 AM
    #177
    Mynameisbrandin
    Brandin
    New Braunfels
    Little update to my mounts as I didn’t want to run wheel spacers anymore. I moved them more inboard and added a brace across the bed. The cross brace made a world of difference on the ride.. I think the forces going into the shock mount were actually multiplying being the shock mount has sideways leverage on the frame. Truck feels more planted on bumps and doesn’t seem to move the vibrations thru the frame. 070963B6-DB87-4BA9-A93C-AB209BA30740.jpg9341AC95-BAB5-4BE0-A957-C18B2D29BDBD.jpg90502408-0AB5-4FD0-B304-74947E9048DF.jpg
  18. Sep 23, 2020 at 9:31 AM
    #178
    Mynameisbrandin
    Brandin
    New Braunfels
    Also forgot to add.. I moved up to 37s recently and a recent wheeling trip saw wheels in the air and only have the slightest dirt/mud rub on the shock body. Telling me it got close, but nothing to be worried about
    whatstcp likes this.
  19. Sep 23, 2020 at 3:44 PM
    #179
    2000prerunner23
    2000prerunner23 Well-Known Member
    steve
    I don't know how fast you intend on going but the bilstein factory valving of "255/70" is going to ride bad. Also the shock shafts are 1/2" dia. Might bend them especially on a 14" length. I ran this same shock in the rear of my old ranger with 14" travel Deaver springs and the ride was shit. I get that you are trying to fit a 14" shock in there but I think a re-valveable shock is a must. Also I think the old BILSTEIN "weld top" 9100 series 2.5" remote resi shocks were a short collapsed length so that might also fit.
  20. Sep 23, 2020 at 3:47 PM
    #180
    2000prerunner23
    steve
    wait ... you cut into the bed anyways? Why not just build a low profile bed cage then:
    TacoEspecial likes this.
