A/F sensor (b1 s1) acting up?
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, Sep 13, 2022.
  1. Sep 13, 2022 at 12:13 PM
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    My A/F sensor is fluctuating back & forth every 10 seconds or so, from 3.295v to 3.3v key in on position.
    Truck has not been running today.
    Should it be doing this?
    Nothing else is active.
    Might be worth noting though, that ltft is reading 1.6.
    Timing advance 5
    Other than that just temps (although intake is higher than coolant) & throttle position. These I would expect. All others at 0
  2. Sep 13, 2022 at 5:37 PM
    Rastopher
    Rastopher Well-Known Member
    Ras
    Sacramento, Ca
    2002 2.7 4x4 reg cab automatic
    Utility Shell, Ultra 062 wheels, bilstein 5100, OME880 coils, wheelers progressive AAL, Whiteline LCA bushings, poly sway bar and steering rack bushings, led dash cluster, shifter bushings, 4runner mirrors.
    Not an expert but seems pretty negligible. It probably isn’t even heated up. No real data to be found if the truck isn’t on imo
    edit:fyi that sensor belongs in that voltage range.
  3. Sep 14, 2022 at 6:40 AM
    Kristi with a K
    Western MA
    Right. I was more questioning if it should even be active (the fluctuation) when the truck isn't on.
    I'll see if there's an option to change the data output on the scanner.
