a few questions about 5100's
Discussion in 'Suspension' started by tacosupreme54, Oct 25, 2010.
  1. Oct 25, 2010 at 8:52 PM
    tacosupreme54
    tacosupreme54 [OP] Well-Known Member
    NW GA
    Off-Road 4x4 SR-5
    OME 885's, 90000 and n182 shocks, CB drop, 295/75/16 Hankook Dynapro MT RT03's, 16"x8" Pro Comp 7089 wheels, Avid Off Road Light Bar, Magnaflow 12226-14'' Muffler dumped after axle, color matched grille, Team Realtree camo seat and steering wheel covers, Husky floor liners, towing hitch, bed extender, Tacoma bed mat, all black emblems, black sockmonkey decals, bedlined rear bumper.
    i plan on getting 5100's sometime to get rid of the 2.5'' spacers and have some questions.
    1)you basically just take out the old shocks, set the 5100's to 2.5'', and you have your lift, right?
    2)you don't have to get new coils or anything? i understand that new coils will provide a better ride, but i can't afford that for now.
    3)will ride quality decrease as the height setting of the 5100's is increased? or i guess i'm trying to say, will setting the 5100's higher, 2.5'' in my case, reduce ride quality compared to if they were set at 0''?
    4)one last one, will i lose the lift i get from these over time?
  2. Oct 25, 2010 at 8:55 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    maybe a little due to sagging on the coils
  3. Oct 25, 2010 at 9:01 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    ok, but that would be typical sagging that any truck would have over time, right?
  4. Oct 25, 2010 at 9:04 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    would 5100's set at 2.5'' be just as stiff and bumpy as the 2.5'' spacer i now have? because i have read from pretty much everyone on here that has them at 2.5'' that it's stiff. well my spacers are already stiff, so why waste my money on something that would ride the same? that's why i was wanting them, for a better ride quality
  5. Oct 25, 2010 at 9:13 PM
    08pretaco
    az
    Because 5100s are designed not to over extend on down travel. Some members have broken shock shafts because of improper lifting techniques. Going on billys website will explain it very well
  6. Oct 25, 2010 at 9:15 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    so even if 5100's at 2.5'' are still stiff, they will be better than the spacer because mechanically they work better for my suspension?
  7. Oct 25, 2010 at 9:18 PM
    08pretaco
    az
    Yes. The provide much better and much more controlled dampening over stock shocks and spacer lifts. They allow for different levels of lift for many applications. They will probably ride 100% better than your current spacer lift.
  8. Oct 25, 2010 at 9:20 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    alright man, thanks a ton for answering all of my questions
  9. Oct 25, 2010 at 9:22 PM
    08pretaco
    az
    NP :D someone else might chime in as well. Lots of people run spacer lifts and like then, id prefer to spend the little extra for piece of mind and a much better quality lift!
  10. Oct 25, 2010 at 9:36 PM
    Austin82
    Austin82 Active Member
    I'm in the same boat. Looks like I'm gonna order my 5100's for the front and the toytec AAL tomorrow, seems to be the best bet since I'm only a 4x2 and dont do a ton of off roading, correct?
  11. Oct 25, 2010 at 9:41 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    yes, don't mess up like me and get spacers, lol. also, if you have about $1000 to throw around, a spindle lift is pretty nice for the 2wds
  12. Oct 25, 2010 at 9:44 PM
    Austin82
    Not wanting spend quite that much right now. I don't do much dirt driving. Is it the 1.5" or 2" AAL for leveling with the billy's set at 2.5" in the front?
  13. Oct 25, 2010 at 9:49 PM
    numbah57
    numbah57 GIVE THE MALL A BREAK...WHEEL THAT SHIT
    kahai
    Maui, Hawaii
    09 tacoma 2.7 Beaten not Babied
    URD ARB G2 PELFREY BAMF LCE AFE
    Subscribed
  14. Oct 25, 2010 at 9:49 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    depends on if you have the tsb done for the rear leafs. if you do, the 1.5'' is made for that. if you haven't had the tsb done, 2''. i have the 2'' with 2.5'' up front and it's pretty level.
  15. Oct 25, 2010 at 9:55 PM
    Austin82
    I don't think I do. It's an '08 and I've had it about a yr and a half. I haven't had anything done. 2" it is.
  16. Oct 25, 2010 at 9:56 PM
    tacosupreme54
    NW GA
    Off-Road 4x4 SR-5
    2'' AAL and 2.5'' 5100's...sounds good to me
  17. Oct 25, 2010 at 10:11 PM
    Austin82
    Done deal. I'll post pics when I install.
  18. Oct 25, 2010 at 10:28 PM
    08pretaco
    az
    i think that will give it the stock front rake. a 1.5" aal in the rear would be the level look IIRC
  19. Oct 25, 2010 at 10:33 PM
    jr114
    jr114 Well-Known Member
    Jon
    SoCal
    Truck
    Icon Ext travel CO, Icon tubular uniball UCAs, Maxtrac Spindles, Icon RR rear w 2"aal.
    x2
    i think the 1.5 will provide a more level look
  20. Oct 25, 2010 at 10:41 PM
    numbah57
    kahai
    Maui, Hawaii
    Is that with the stock coils?^^
