A few questions about changing the power steering fluid.
Discussion in 'Technical Chat' started by SoCalBlack08, Dec 21, 2013.
  1. Dec 21, 2013 at 12:43 PM
    SoCalBlack08
    SoCalBlack08 [OP] Well-Known Member
    CA
    08 PreRunner DC
    This will be the first time I do this. I'm thinking of doing it the simple (but time consuming) way of using a turkey baster and sucking up all the fluid, refilling, driving for a bit, sucking out the fluid again...repeating until the fluid looks good.
    1. Should I warm up the car before doing this or does it not matter?
    2. What line should I fill to when I refill it?
    3. Which fluid should I use? Is synthetic beneficial in this case? Can I mix synthetic and regular fluid or do I have to do a whole system flush for synthetic?
  2. Dec 21, 2013 at 12:52 PM
    Spoonman
    Spoonman Granite Guru
    Jamie
    Alberta
    Use recommended fluid, I'm a stickler so I get Toyota fluid.
    Also there's a way more efficient way of doing it. If you have an extra long piece of 3/8s hose, attach that to one of the lines, plug the 3/8 return line at the reservoir, and direct that long hose into a bucket. All the fluid will puke out of that hose, and fill up the reservoir as it it runs for a few seconds, to prevent running it dry. That's a quick fluid flush. You'll only need about a litre of fluid if you're good. I'd get two to be safe. Put the hose back into the reservoir and fill it up...
  3. Dec 25, 2013 at 6:56 PM
    Hansel
    Hansel Well-Known Member
    Glenn
    Arizona
    base
    I'm assuming your vehicle calls for Dexron ATF
    I've done it just as you described. it works well.
    1 I do it after it is warmed up, the fluid flows a little more easily.
    2. I haven't done yet to my Tacoma, haven't owned it very long so I'm not sure where the line is on this one. Doesn't it have a 'dipstick' attached on the cap that is marked?
    3. I use synthetic and it is fine to mix it, no problem.
