A few questions on the bilstein 6112
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Dansly56, Jun 23, 2020.
  1. Jun 23, 2020 at 10:20 PM
    Dansly56
    Dansly56 [OP] Well-Known Member
    Dan
    Valencia, California
    2013 Toyota Tacoma Baja Edition 4WD
    Light bars, electronic side steps, bed cover, light bars, grills, roof rack, falken tires, method racing rims
    Looking to buy the bilstein 6112 to replace my stock Baja series front coilovers as my right strut is leaking and they’re not rebuildable or serviceable at bilstein. Can I use my stock spring? or is the bilstein 6112 spring a better spring then the red spring on my baja shock? I also have a 1” toyotec spacer that I want to add to the bilstein 6112’s is that doable and if so will I need to add a different uca or move anything else around to make it all fit like my current shocks? Thanks in advance
  2. Jun 24, 2020 at 3:48 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    No you cannot use the stock spring too small dia. You can use the spacer but that would be in lieu of setting the preload on the spring and using the adjustment on the 6112 for height.
  3. Jun 24, 2020 at 11:54 AM
    Dansly56
    Dan
    Sma
    I thought The diameters were the same 2.5?
  4. Jun 24, 2020 at 12:01 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    No the stock Baja shocks are more like the 5100s
  5. Jun 27, 2020 at 9:06 PM
    TacoFergie
    TacoFergie Well-Known Member
    Iowa
    I believe you are correct. The TRD Pro and Baja suspensions are essentially a 6112, just not height adjustable. I would assume those springs would fit. I believe the Baja and Pro springs are 600lb springs and the valving was the difference between those two, that is what differentiated them. I don't know that there would be any advantage to running the Pro or Baja springs over the springs that come with them. The 2 factors that would make a difference are the spring rate and coil length. For instance if you had 2 coils with the same spring rate but one spring was 12" and the other was 14" then you would gain more height from the 14" spring. Only way you would likely know that is setting the 2 springs unmounted side by side. But I think the red spring would look nicer on some trucks even if the springs were essentially the same.
    I am also curious about the Toytec strut tops. I have a set of Toytec Ultimates that have about 3/4" tops that I wouldn't mind adding to 6112's when I get them in a week or 2.
    I know @crashnburn80 has done extensive research on the differences in the Baja and Pro setups. He may be of more assistance as well.
    parel likes this.
  6. Jun 27, 2020 at 10:01 PM
    Dansly56
    Dan
    I have been doing a little research on the springs and my stock baja springs seem to be 650 pounds and I’m still looking into the black 6112 springs. So are you saying that if my red springs are taller by 2” then I would gain 2” in ride height? Like adding a extra 2” lift? My toyotec 1” spacer are actually on the bottom of the spring not the top so I wonder if I can put my same spacer on the bottom
  7. Jun 27, 2020 at 10:11 PM
    TacoFergie
    Iowa
    I don't know what the spring heights are, I was just giving an example. But.....I know Bilstein makes heavier springs for the 6112. I think 650lb and 700lb springs. Also some dealers offer king or eibach springs for added weight. Assuming the spring is the same length and the baja springs are 650lb springs then you could essentially run 1 clip lower than advertised lift vavlues from the research I have done as well. I have been trying to find the differences between the 3rd gen and 2nd gen 6112's.
  8. Jun 27, 2020 at 11:58 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    The Baja shocks are based on the 6112 body just like the 2nd Gen Pro. The Baja springs are 650lb vs the Pro 600lb, the Baja shocks are also valved more firm than the Pro. I cannot say where the non-TRD 6112 falls in valving, but I doubt it is valved as firmly as the Baja shocks. I personally prefer the firmer setup, which is why I went with the Baja out of the three. You should be able to reuse your stock Baja spring on a 6112 body, however the anti-Taco lean is done by offset spring perches on the TRD versions of the 6112. The standard 6112 does not have the offset perches and instead has 4 height adjustable clips that are the same on both sides. You will want to factor correcting your Taco lean with a spacer of otherwise if going to the standard 6112.
    parel, TacoFergie and Monkeybutt2000 like this.
  9. Jun 28, 2020 at 7:03 AM
    Dansly56
    Dan
    when you say taco lean is that a lean on drivers or passenger side? Would I be able adjust on strut at let’s say 4 and the other 3 to correct the lean or are spacers a must to correct the lean. I currently run toyotec 1” spacers on my baja but they’re not too spacers they’re bottom spacers and I’m wondering if I can use the same spacers the same way with the 6112. According to a article by These guys https://www.popularmechanics.com/ca...tacoma-trd-tx-baja-series-test-drive-7455307/ they say the Baja coilovers are the bilstein 9100’s IDK.
  10. Jun 28, 2020 at 9:55 AM
    TacoFergie
    Iowa
    You are correct about the taco lean. It is on the drivers side due to the battery being on that side and having the driver as constant weight.
    As for the link you posted...They are absolutely 6112 based struts. The 9100 series is custom for every application. Their "shortest"coilover has like 10" of travel! The 6112 is something around 7" travel I believe. Also the 9100 coilovers are made to have the spring mounted to the lower perch, without any lower perch extension.
    https://www.4wheelparts.com/p/bilst...sorber-f4-boa-0000400/_/R-BBGL-F4-BOA-0000400
    crashnburn80 likes this.
  11. Jun 28, 2020 at 12:41 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Bottom spacers cause pre-loading of the suspension, if using spacers top plate spacers would be the better option. But to answer your question, yes you should be able to use the same spacers, though I wouldn't recommend it. I have a 1/4" top plate spacer on passenger and 1/2" top plate spacer on the top of my Baja setup. Spacer height x2 = lift height. So by using a 1/4" larger spacer on the driver side of my truck, it provides the extra 1/2" lift to counter the taco lean. Note that if using top plate spacers larger than 1/4", you will need longer mounting studs, as the OEM ones will be too short.
  12. Jun 28, 2020 at 12:54 PM
    joeydurango
    joeydurango Nightfall Overland
    SW Colorado
    Heavily modified 2015 TRD w/Drifter
    Whatever you do, DO NOT order your parts from 4wheelparts.com (which someone linked above)! You are likely to get burned, they're a terrible company. Highly recommend Headstrong Off Road or Down South Motorsports.
    HandOfGod and Dansly56[OP] like this.
  13. Jun 28, 2020 at 1:06 PM
    Dansly56
    Dan
    can you send me the link to the specific spacers you bought. I just bought some 6112 for my baja since my right strut has been leaking and couldn’t pass up on the deal I got. $240 for used bilsteins 6112 about 3k miles still under factory warranty. The more I read about 6112 the more I started to read about that lean
  14. Jun 28, 2020 at 1:07 PM
    Dansly56
    Dan
    how about wheelers offroad?
  15. Jun 28, 2020 at 1:09 PM
    Dansly56
    Dan
    yeah I didn’t believe they’re the 9100’s I’ve heard more people say they’re the 6112’s
  16. Jun 28, 2020 at 1:21 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    I purchased from Headstrong, I used 1/2" spacer for driver providing 1" lift and 1/4" spacer for passenger providing 1/2" lift.
    1/2" spacer: https://www.headstrongoffroad.com/store/p30/HS_1/2"_Top_Plate_Spacers_-_TT05512-TPS.html
    1/4" spacer: https://www.headstrongoffroad.com/store/p31/HS_1/4"_Top_Plate_Spacer_-_TT05514-TPS.html
  17. Jun 28, 2020 at 1:47 PM
    joeydurango
    SW Colorado
    I've dealt with Wheeler's before too. No problems. I do know they're a little behind on shipping right now due to COVID, but that's the case a lot of places. I just ordered from both Headstrong and Down South and both shipped my product within 48 hours.
  18. Jun 28, 2020 at 2:12 PM
    Dansly56
    Dan
  19. Jun 28, 2020 at 2:15 PM
    Dansly56
    Dan
    right on! I’ll look into them as well seeing that I need to order some AAL and some top spacers for the lean
  20. Jun 28, 2020 at 2:23 PM
    StrangeDuck
    StrangeDuck Well-Known Member
    San Diego
    07 Prerunner AC TRD Offroad; 4.0 6-speed
    265/75 Bridgestone Dueler ATs, 5100s all around, OME 883s front, EL095R Dakars rear (overload removed), custom sliders, Clazzio seat covers, Softopper, KB Voodoo URTC
    So I emailed Bilstein about the Taco Lean issue on 2nd Gens a while back. The official response I got via email was that they do not recommend a top spacer or offsetting the clips as is done on the 3rd Gen. I'm not saying that it can't be done without damage...but their policy is that either will void the warranty on the shocks. Keep this in mind if you ever have issues with them and have to deal with Bilstein customer service. Here is how the email was worded...sounds like a cut-and-paste response:
    "Though I understand why you are using the spacer, none of the products we make should be used with that spacer as it can potentially damage the shock and void the warranty. The spacer shouldn’t be used with the 5100, nor the 6112 and as far as the clip settings are concerned, we would recommend the installation of the snap rings be set as the instructions dictate (i.e. equal both sides.) Setting one side lower or higher than the other is not something we recommend, rather we would recommend following the instructions settings."
    I call shenanigans on offsetting the clips causing issues as the 3rd Gen 6112s don't have separate part numbers for left/right side (and people's experiences here on the board.)
