A few suspension questions before I buy.
Discussion in '1st Gen. Tacomas (1995-2004)' started by wj32796, Dec 3, 2013.
  1. Dec 3, 2013 at 5:07 PM
    wj32796
    wj32796 [OP] Member
    Titusville,Florida
    2017 TRD Offroad
    Stocker
    I have a 1996 ext. cab 4x4 with a 2.7. Pretty much all stock with the exception of 16" newer Tacoma rims with new 32" tires and a newer factory style header that replaced the troublesome cracked manifold.
    My rear leafs have no arch left in them so now is the time to upgrade. After about three days of searching this site on this topic and learning a lot I thought I would get your thoughts on what I have in my cart from Toy Tech from you guys that have done this before just to make sure I'm not over looking something.
    I do want to lift the truck during this upgrade and don't really want to spend more than a grand. So here is what I have.
    For the shocks I plan on using my current coil springs for these.
    http://toyteclifts.3dcartstores.com...ont-shocks-and-matching-rear-shocks_p_94.html
    I also have the bushing kit in my cart as well.
    For the leafs:
    http://toyteclifts.3dcartstores.com/OME-CS019R-Dakar-Leaf-Pack-955-97-Tacoma_p_207.html
    I also have the 7.5" U-bolts and the exhaust bracket in my cart as well.
    If this all looks good do I need to replace the rear brake line for a longer one, and I have the "Load Control Valve" on my brake system in the rear will this lift effect the function of that valve?
    Also, the rear shocks in that package are they suitable for the lift. Its not to clear if they are the extended 5125 ( I think that's the part number on them).
    All input, opinions and suggestions are welcome. I just want to make sure before I purchase.
    Thanks.
  2. Dec 3, 2013 at 6:06 PM
    00yotasr5
    00yotasr5 Well-Known Member
    lee
    merced, ca
    00 SR5 4X4 RED DEVIL
    Icon ext travel expo leafs rear billies 5125 10'' travel bamf bpv relocate Brute Force Fab Sliders allpro ss brake lines f/r LR UCA 22in wetokled bar RAT Products ifs skid ARB rear locker Ultra gauge Redline Hood Struts Blue Sea Fuse box smittybilt xrc 9.5 w/TJM synthetic rope trail-gear rock assault low profile bumper LED bed strip 12v/usb charger in truck bed
    fronts are good but the rear it stats 3-3.25 lift with that leaf pack, the shocks for the rear are for 1-2 1/2 lift. I would suggest calling them to verified to make sure the rear shocks are long enough for the leafs. for that lift in the rear I would upgrade to longer brake lines.
  3. Dec 3, 2013 at 7:39 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Go for the u bolt flip when you do your leaves! It's only like $25 more
  4. Dec 3, 2013 at 8:19 PM
    wj32796
    wj32796 [OP] Member
    Titusville,Florida
    2017 TRD Offroad
    Stocker
    Would i need a shorter shock for that?
  5. Dec 3, 2013 at 8:23 PM
    wj32796
    wj32796 [OP] Member
    Titusville,Florida
    2017 TRD Offroad
    Stocker
    Never mind I see what they do now. Will that kit work for my set up? Anyone?
  6. Dec 3, 2013 at 9:03 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    you can't do a U bolt flip without welding on new shock mounts to the axle as the lower shock mounts are on the stock axle plate that the stock ubolts clamp on.
    So i fyou do u bolt flip, you should jsut relocate the shocks all together with a custom upper crossmember.
  7. Dec 3, 2013 at 9:38 PM
    wj32796
    wj32796 [OP] Member
    Titusville,Florida
    2017 TRD Offroad
    Stocker
    I didn't realize all that was involved. I think I will pass on the u-bolt flip.
