A funny thing happened on my way to fix an AC Leak.
Discussion in '1st Gen. Tacomas (1995-2004)' started by prerunnerSD, Jan 5, 2020.
  1. Jan 5, 2020 at 3:02 PM
    prerunnerSD
    prerunnerSD [OP] Well-Known Member
    USA
    01 Tacoma Limited 6 cylinder 4X4
    Grill guard Front and rear Bilstein 5100's Front Coilovers Rear AAL "I Brake for Tailgaters" Firestone Destination A/T (P265/75/R16)
    A funny thing happened on my way to fix an AC Leak. Using a few different attempts at refilling with those Walmart store brand R134a refrigerant cans kept the system working for a few days but it always all leaked back out!
    So I began realizing I had a significant leak. So I purchased this product from O'reilly
    Interdynamics A/C System Dye;
    it was like around $15, least expensive dye system I could find - along with a UV Light. Well a month after using this product the system is still cold. I have a theory that the dye that was in this product might have plugged the hole somehow. Either way I am not complaining and its worth a shot since you'll have to find out where it leaks anyway.
    I have a 1st generation, 2001 Tacoma
    Thanks!
    Jon
  2. Jan 5, 2020 at 8:38 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Can you see any dye that leaked out?
    I wonder if maybe you had some dirt or something in the fill valve, and futzing with it enough times broke it loose enough to allow a proper seal.
    Glad you got a nice and cold a/c system in January, lol
  3. Jan 5, 2020 at 8:40 PM
    ppham444
    ppham444 Well-Known Member
    Phuong
    Portland, OR
    2023 White TRD Off-Road doublecab
    Will this product work for flat tires?
    Thatbassguy likes this.
  4. Jan 5, 2020 at 8:43 PM
    cruiserguy
    cruiserguy Well-Known Member
    Elijah
    SEKS
    2000 ext cab, 2.7L, auto, 4x4
    Yes
    Wyoming09 and Thatbassguy like this.
  5. Jan 5, 2020 at 8:49 PM
    jbrandt
    Justin
    It will find the leak, sure, but so will soapy water.
    No telling what this stuff does to rubber. I would not put this stuff in your tires.
  6. Jan 6, 2020 at 6:46 AM
    cruiserguy
    Elijah
    SEKS
    I'm sorry. I was being funny and thought it was a given that this wouldn't be for tire/air leaks. It is not for air leaks. It is for refrigerant leaks in you refrigerant system. As far as I know
    Muddycoinwash likes this.
  7. Jan 6, 2020 at 7:28 AM
    Old n' slow
    Old n' slow Well-Known Member
    Oak Island, N.C.
    2000 Tacoma 2.4 5 speed flare side
    I’ve never seen UV dye fix a leak....I’m also guessing it was leaking from the fill valve and you lubricated it and it resealed itself.
  8. Jan 6, 2020 at 9:01 AM
    jbrandt
    Justin
    I figured to were, but not everyone knows the depths of sarcasm this forum typically sees, so just wanted to reiterate.
    :cheers:
    cruiserguy[QUOTED] likes this.
  9. Jan 6, 2020 at 2:09 PM
    prerunnerSD
    USA
    Yes and I couldn't find the leak with the UV light after. This product also filled up faster than those cheaper cans. Its a small can with five dye shots but the can emptied in the system almost immediately.
    Its a warm day here in SOCAL in January so I'm happy with that also the fact that defrosting uses AC to dry out the moisture on your windows, a safety feature
  10. Jan 6, 2020 at 2:36 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    If you have a leak in you ac system it is always prudent to get it repaired. Air and moisture in your system is the last thing you want. Those quick fix solutions from your auto parts store will actually cost you more in the long run.
  11. Jan 6, 2020 at 2:40 PM
    prerunnerSD
    USA
    I thought the first step was to find the leak? I didn't want to spend a mechanic $95 an hour to find a phantom leak.
    jbrandt likes this.
  12. Jan 6, 2020 at 4:17 PM
    spitdog
    Your correct. Go to Walmart.
  13. Jan 6, 2020 at 4:20 PM
    prerunnerSD
    USA
    The context of my post clearly indicates that I have ALREADY proceeded with this solution by going to O'Reilly!
  14. Jan 7, 2020 at 7:58 PM
    ppham444
    Phuong
    Portland, OR
    Remember.....love means never having to say you're sorry......
