a little bit of water killed my taco
Discussion in '1st Gen. Tacomas (1995-2004)' started by DaytonLax14, Feb 2, 2011.
  1. Feb 2, 2011 at 7:28 PM
    DaytonLax14
    DaytonLax14 [OP] Well-Known Member
    Corey
    Ohio
    98 extended cab TRD Off Road
    when i drove my tacoma through a decent sized puddle (probably 8" deep or so) the water splashed up into my engine and killed the motor. Had to let it sit for about 20 min until all the water drained out before i could start it up again. I see guys taking tacomas through rivers with no problems, but mine dies from a puddle? What's going on here?
  2. Feb 2, 2011 at 7:30 PM
    The1youluv2hate
    The1youluv2hate Well-Known Member
    Peps
    SAnta Paula CA
    18 TRD sPort 4x4 (11mgmsport)
    oem pro grill 17” pro rep wheels Fox dsc shocks
    Time for snorkel
  3. Feb 2, 2011 at 7:32 PM
    Monkeysuncle
    Monkeysuncle My Cat's breath Smells like Cat Food
    Kevin
    Florida
    99 Tacoma SR5 4x4 5 speed Manual Hubs
    Diff Breather,CB thingy,GPS,Cop Shocks,Cop Brakes, old Man Emu 881's Dakar Leaf Springs and Nitro sport shocks. Deck Plate mod
    How fast were you going? KIlled the alternator? And remember, it's not a boat
  4. Feb 2, 2011 at 7:33 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    I drove through a river at the dunes that was probly 20" deep, and nothing happened
  5. Feb 2, 2011 at 7:33 PM
    DaytonLax14
    Corey
    Ohio
    i was probably going 20-25...fast enough to get the water up to the engine i guess
  6. Feb 2, 2011 at 7:35 PM
    sir1123
    sir1123 Tacomas FTMFW!!!!
    Charleston
    99 SR5 Prerunner, Black,3.4L
    3"Ebaich with 5100 Bilstiens, K&N cai, 5% 3M Tint, Magnaflow 18", Hella 500s with 35w 3000k hid retro, 33x9.5x15 BFG A/T
    only probelem water cause for me was bad starter bearings
  7. Feb 2, 2011 at 7:38 PM
    DaytonLax14
    Corey
    Ohio
    see i was thinking the same thing. I did the elbow mod a long time ago so when my engine died i automatically thought that was the reason. I popped the hood and there was no water on the air box and none inside of it....?
  8. Feb 2, 2011 at 7:43 PM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    prolly just hit a sensor just right, thats honestly what it seems
  9. Feb 2, 2011 at 7:45 PM
    S.B.
    S.B. Well-Known Member
    Sean
    San Diego
    15 Taco
    LT, Glass, CBI Front bumper, NWTI Rear bumper, 35s
    Do those tacos have ditributer caps? If so then water go in there and thats what caused it. What happens is water gets in the cap and then there is no spark.
  10. Feb 2, 2011 at 7:45 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    no caps i dont think, it uses coils IIRC
  11. Feb 2, 2011 at 7:47 PM
    jgwheeler17
    jgwheeler17 I'm a zit. Get it?
    NC
    07 Double Cab TRD Off-Road 4x4
    neglect, mostly.
    agreed. pretty much the same thing happened to a jeep i had a few years ago.
  12. Feb 2, 2011 at 7:47 PM
    TacoNut
    TacoNut IgnoringChrisWatchingEdLi veVicariouslyThroughMJP2
    Adam
    Denver, Co
    16 TRD OR DCSB Quicksand
    into the engine??? :confused:
    Since you said the airbox was dry (and other than that and exhaust it's sealed) probably got a sensor or the alternator wet...
    And these engines have distrubuterless ignition
  13. Feb 2, 2011 at 7:48 PM
    TacoNut
    Adam
    Denver, Co
    ohh, and next time it stalls in a water crossing....
    DON'T TURN THE KEY AGAIN until you know there's no water in the cyl's
  14. Feb 2, 2011 at 7:49 PM
    DaytonLax14
    Corey
    Ohio
    the cel was flashing if that helps at all. but yeah i bet the water hit a sensor or the alt
  15. Feb 2, 2011 at 7:50 PM
    fireturk41
    Kevin
    High Point, NC
    280k miles
    get the code read at advance auto or similar store and post up here. a flashing CEL indicates something that can affect the CAT or emissions causing the cat to fail
  16. Feb 2, 2011 at 7:52 PM
    shaniac
    shaniac Well-Known Member
    Charleston, SC
    2014 Double-Cab Tacoma SR5 V6 4x4
    No, they have a coil over wire system...
    Three ignition coils sit on the 1, 3 and 5 cylinders.
  17. Feb 2, 2011 at 7:53 PM
    S.B.
    Sean
    San Diego
    15 Taco
    I can't see that getting the alternator wet doing anything, since the battery will still supply your voltage.
    For the distributor, thanks for clearing that up for me. I know my brother's TJ and my friend's 90' 3.0 V6 4Runner has them and water likes to get in there and stall the engine.
  18. Feb 2, 2011 at 7:54 PM
    TacoNut
    Adam
    Denver, Co
    The code will still be stored. Go to a auto parts store and get it read. post what it is.
  19. Feb 2, 2011 at 7:59 PM
    4x4Runner
    4x4Runner Sam’s gone, man. Moderator
    Drunken Sailor
    Not north, not south, not west, mostly east
    1WD
    nuttin fancy
    What he says below.
    Probably soaked the alternator. I've run through numerous puddles with my Tacoma and haven't had an issue!
  20. Feb 2, 2011 at 8:03 PM
    1337Taco
    1337Taco Well-Known Member
    Kevin
    NorCal
    2015 4X4 Manual
    Especially seems like a problem with first gens. My friends went out while wheeling on Saturday. Tapped it with a hammer, some mud and water fell out and it started right back up. I've heard of other first gens having similar problems.
