a little bit of water killed my taco
Discussion in '1st Gen. Tacomas (1995-2004)' started by DaytonLax14, Feb 2, 2011.
  1. Feb 2, 2011 at 8:07 PM
    awoit
    awoit Well-Known Member
    CA
    08 TRD, SR5
    How do you check for this??:D
  2. Feb 2, 2011 at 10:38 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    If the engine is running OK now, you were very fortunate indeed. The reason the engine quit and the reason you got the misfire CEL is because you did suck up water through the elbow opening.
    It doesn't take much to hydro-lock a cylinder. Next time you might not be so lucky.
  3. Feb 3, 2011 at 4:05 AM
    fireturk41
    fireturk41 I like to break shit!
    Kevin
    High Point, NC
    280k miles
    SAS, Locked front rear, Ufab sliders and bumpers, air compressor, 35" BFG KM2 on steelies and 36" TSLs
    i really dont think he sucked water.
    another way to check is to take out a spark plug wait a lil bit and fire her up
  4. Feb 3, 2011 at 4:36 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    That is really doubtful. For an engine to suck enough water to cause issues the air intake would have to be completely submerged. Which isnt possible in 8" of water. You have to think of an air intake like a straw in Coke. If there is a hole in the straw you will only suck air. If that hole is fixed or the hole also gets submerged then you will suck the liquid.
    If a splash of water could stop an engine mine would quit every time I drove in the rain with my deck plate open.
    I would say it was water spashed in the alt, or possibly some water down the spark plug tubes.
