A LITTLE HELP [2018 TRD SPORT}: Fenders off Airbag light on
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RJ's Hood Scoop, Dec 29, 2023.
  1. Dec 29, 2023 at 12:46 PM
    RJ's Hood Scoop
    RJ's Hood Scoop [OP] Member
    RJ
    A Marines Cement TRD Sport
    A Cement 2018 Tacoma TRD Sport - Unique in a way that I do not have a passengers seat. I remove it and build a bed area for my Service Animal a 3-year black female Labrador Retriever named CiCi.
    I took my stock fenders off to replace them. Got in truck and red lights were on.
    Drivers seat belt, Drivers airbag, Oil
    So I turned off let sit that started it again thinking they just need to reset.
    It worked accept for the DRIVERS AIRBAG LIGHT IS STILL ON...
    Little help guys
    Semper Fi
  2. Dec 29, 2023 at 12:48 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    you are just going to have to retrace your steps and see if you disconnected or damaged a wire.
    Or, you can see if someone has the wiring diagram and chase those wires.
  3. Dec 29, 2023 at 12:50 PM
    RJ's Hood Scoop
    RJ
    Got it..... I know I didn't visibly hit a sensor. But I did get physical at times, so I could of rattled something.
  4. Dec 29, 2023 at 12:56 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    I am not trying to scare you, but forewarned most any dealer I have heard of will NOT repair an airbag wire, rather want to replace that part of the harne$$.
    Maybe @caribe makaira can help with a wiring diagram to help you trace the wires?
  5. Dec 29, 2023 at 1:40 PM
    RJ's Hood Scoop
    RJ
    Thank you - as far as being scared 22 years in the Marine Corps, if thats my own worry bring it on [airbag] lol. THANK YOU for going out of your way to help out.....
    AmateurTaco1313 and Chew like this.
  6. Dec 29, 2023 at 2:22 PM
    AmateurTaco1313
    AmateurTaco1313 Dreaming of the next build
    ROK
    2018 TRD Sport 4WD DCSB
    Enough for now
    My guess is maybe while removing the front fenders a wire got knicked or sensor hit. Not alot in the rear near the fenders that's crucial except on the gas tank side. I've removed all four to trim and replaced without issue, and I totally understand you being physical with them, it's a bitch and a half at times.
    Did you mess with the fender liners at all? There is a pretty good size wire cluster near the cab mount on the drive side that may be the culprit.
    Hope that helps, Semper Fi.
