A Little Help Here....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Fitz235, Jul 8, 2016.
  1. Jul 8, 2016 at 2:44 PM
    Fitz235
    Fitz235 [OP] Well-Known Member
    Rob
    New Hampshire
    Black '22 DCSB TRD Offroad 4WD
    - TRD T4R Pro Wheels - TRD Lift Kit - TRD Skid Plate - 265/70/17 Toyo Open Country 3's - OEM Bed Lights - OEM Bed mat - Alpharex Tail Lights - TacomaBeast LED Interior Lights - Green Lane Offroad Aluminum Sliders - Place Holder for More Bad Financial Decisions...
    So I'm trying to get my original factory tube steps off after 10 years, and surprise, surprise, I'm having an issue with one of the bolts. Rather than rusted solid, one of them is spinning loose in the body (They mount to the threaded holes in the body by the pinch weld). I'm pretty sure the only thing I can do at this point is to drill out the bolt head to allow me to get the tubes off. The only problem is that now the bolt will be stuck in the body, and I'm trying to pull the old ones off to replace them with new ones. I could just leave that one bolt out, there are enough other bolts to support the new tubes, but ideally I would like to repair/replace that thread/bolt.
    I figured I would check with the hive mind to see if anyone has another idea.
  2. Jul 8, 2016 at 2:54 PM
    3coma
    3coma my kid says my truck is "Boss"
    rob
    19 dcsb sport cement 4x4
    Grab the bolt with vice grips and back it out while pulling.
    Fitz235[OP] likes this.
  3. Jul 8, 2016 at 3:03 PM
    Fitz235
    Rob
    New Hampshire
    Yeah, I tried something similar. It's in a tight spot, so I got a pick like device, and wedged it behind the bolt head, so I could pull on it while turning. No bueno.
  4. Jul 8, 2016 at 3:04 PM
    14 Tacoma
    14 Tacoma ColeMcMathisaDouche
    Clinton
    IL
    2014 TRD Sport
    Cheap ebay bumper, plus others
    If you can spin it freely with your fingers spin it while pulling down. See if you can feel it drop slightly and catch. Sometimes you can get them to seat back down into their spot welded position and have a bit more support to hold the loose nut.
    If so find a way to pry downward for more friction and back the bolt out. A heavy dose of PB blaster or a good penetrating oil with about 20-30 minutes soak will go a long way as well.
