A little help with shudder....
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ETaco23, Jul 2, 2011.
  1. Jul 2, 2011 at 5:13 PM
    ETaco23
    ETaco23 [OP] Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    I have this shudder at 45-50 and Ive been trying to pin point it for awhile, but am at a loss...
    Part of me thinks its the tires but I also suspect it to be the drive line, bc it was there when I had my stock tires...
    I just checked my driveline and u-joints, and when I twist it it feels sloppy, It feels like I have a 1/4" of play either way before I spin the whole shaft....
    That cant be normal right? :confused:
  2. Jul 2, 2011 at 5:36 PM
    Hunter500ky
    Hunter500ky Well-Known Member
    E-Town Ky
    06 Tacoma 4x4 SR5
    Weathertech Mats, Toolbox, 6k HID fogs, Hardwire Escort 8500 x50,
    Did you just lift it? Have tires balanced if it presist do a carrier drop or a shim.
    Mu drive shaft has a little play in it, I think its normal.
    Dont forget to grease your u joints!
  3. Jul 2, 2011 at 5:42 PM
    OZ-T
    OZ-T I hate my neighbour
    Peter North
    British Columbia
    I have the same thing at the same speed .
    Still trying to figure it out , I'm hoping it's tires but it was there but not as pronounced before I lifted .
  4. Jul 2, 2011 at 9:55 PM
    ETaco23
    Evan
    PNW
    ^^ Exactly... Ive tryed both CB Drop and shims and both didnt cure it.
    Im ganna try tires next, bc I need them. If that doesnt cure it, it has to be my ujoints...
  5. Jul 3, 2011 at 6:28 PM
    Asgard
    Asgard Well-Known Member
    06 PreRunner DC SR5 w/LSD
    I hope it's not your u-joints cause Toyota doesn't sell the 4x4 u-joint as a seperate part, you have to replace the whole shaft. You could carry it to a driveline shop and get aftermarket u-joints fitted though.
  6. Jul 3, 2011 at 6:35 PM
    08pretaco
    08pretaco Well-Known Member
    az
    2014 Tundra 4x4 CM 5.7L SR5
    What I am going to suggest helped out another fellow member with the same issues.
    Look at the weights on your wheel, do you have 1 set of weights either in the middle of the rim or right behind the spokes OR do you have 2 sets of weights placed on the rim? A lot of the time with aftermarket wheels that use tape weights the tire shops will use just one set of weights (static) when most factory wheels use dynamic (weights on both sides of the rim). I would suggest going back to the tire store and asking them to do a dynamic tire balance with the correct hub adaptor on the balance machine.
    Hope that helps!
  7. Jul 3, 2011 at 6:49 PM
    ETaco23
    Evan
    PNW
    ^Thanks! I will be getting new tires soon so I will have them road force balance them and see if that helps...
    If not, its going to toyota and hopefully they will fix the problem.... It should be covered under the drivetrain warrenty right?
    I almost want to go put my shims back in to see if it makes a difference....
    What you think?
  8. Jul 4, 2011 at 3:20 AM
    808hiker
    808hiker Taco addict
    Justin
    Big Island, Hawaii
    Might as well put the shims back on and see what happens.
    I just lifted mine and used the axle shims and carrier bearing drop and no vibes but I have a barely noticeable shudder when accelerating from a stop (only under 10mph). Doesn't bother me...and anyone who has never driven my truck before the lift probably wouldn't notice it.
    I don't know if our different cab styles make a difference in this situation though.
  9. Jul 4, 2011 at 8:20 PM
    ETaco23
    Evan
    PNW
    Im pretty sure its my Tires. There cheap, old, crappy tires.
    Its been hard to save for new tires, but Im hoping to get tires this month sometime...
