A little help with some tire questions
Discussion in '4 Cylinder' started by 4banger5spd, Mar 26, 2013.
  1. 4banger5spd
    4banger5spd [OP] Member
    rock wood ontario
    2.7l 5spd manual 4x4 cab and a half
    I was going to change my stock tires to 265,75,R16. So about a 32" tire how much is that gunna effect my power ?
    If it does effect it I was going to add a performance air filter and cold air intake. Should that cover the power loss ?
    Thanks again
  2. delltron
    delltron Member
    Redondo Beach
    2012 DB Cab 4cy Prerunner
    I just installed the same size tire today. I haven't notice a lot of power change so far. I'm sure there's a change but its minimal. Also may depend o. The type of tires.
  3. 4banger5spd
    rock wood ontario
    What tires did you install and what size rims? I plan on going with a 17" rim and BFFg all terrain t/a
  4. JayC06
    JayC06 Well-Known Member
    Jay
    fairhaven ma
    06 4cyl ac 4x4
    5100's front at 1.75, procomp light bar, kc lights, dynomax muffler
    You shouldn't notice much difference if any. I went with a p rated tire because its lighter.
