A little more lift
Discussion in 'Suspension' started by bowzerdoo77, May 31, 2011.
  1. May 31, 2011 at 10:57 AM
    bowzerdoo77
    bowzerdoo77 [OP] U.S.M.C.
    OCEANSIDE, CA
    2016 DBL CAB 4x4TRD OFF ROAD
    6 inch Pro comp Stage 1 lift 305/70/18 MasterCraft MXT 18x9 Monster wheels,
    Ok I looked for this so ill ask. I have a pro comp 6 in ch lift on my truck and my tires are 295/70/18's and at full turn they rub a little. I hav trimmed the plastic a bit and they are rubbing on the backs not the front. So my question is, are there any other options to get a little more lift in the front? should i have went with the stage II lift and if so whats the difference? any help is appreciated thanks.
  2. May 31, 2011 at 11:00 AM
    Jester243
    Jester243 rabble rabble rabble
    Dan
    Spokane, WA
    2016 Trail Premium 4Runner w/ KDSS
    You are doing it all wrong, you need smaller tires, like this:
  3. May 31, 2011 at 11:03 AM
    bowzerdoo77
    OCEANSIDE, CA
    thats a great idea ill just try that ha ha
  4. May 31, 2011 at 11:03 AM
    NetMonkey
    NetMonkey Well-Known Member
    Geogetown, TX
    2010, 4x4, DC, off-road, shortbed, automatic
    Toytec Ultimate Lift @ 3", Mickey Thompson MTZ's 285/75/16, Moto Metal 955b, rear 2" ALL, Marlin Crawler sliders
    i would trim until you dont have anymore rubbing. thats the easiest and cheapest solution.
  5. May 31, 2011 at 11:05 AM
    bowzerdoo77
    OCEANSIDE, CA
    I know but i dont want it to look like shit. you know.. I should have gotten a little smaller tire.
  6. May 31, 2011 at 11:05 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    this^
    are you really wanting more lift or to just not rub anymore?
  7. May 31, 2011 at 11:09 AM
    NetMonkey
    Geogetown, TX
  8. May 31, 2011 at 11:14 AM
    bowzerdoo77
    OCEANSIDE, CA
  9. May 31, 2011 at 11:14 AM
    macgyver
    macgyver Well-Known Member
    Brad
    Canton, GA
    '13 Tundra double cab SR5 4x4
    At least he actually used new leaf springs instead of lift blocks like most of the domestic guys do.
    All the Jacked up domestic trucks around here are running around on a DB lift up front with double stacked 4" blocks in the back on stock leaf springs.
  10. May 31, 2011 at 11:49 AM
    KPT
    KPT sees what you did there.
    09 Prerunner
    You can add a suspension lift on top of the lift you already have, since it's just a drop bracket lift. It doesn't change the angle of your CV's at all.
    TW member TacoRidinHigh has 9" of total lift accomplished this way. Several other have 7 or 8" of lift by using this method.
  11. May 31, 2011 at 11:51 AM
    97yota4wd
    97yota4wd Well-Known Member
    Eric
    Mesa, AZ
    alot of metal, small engine, decent travel.
    caged, camburg long travel, 50t leafpack (soon to be installed) light rack over cab, 5pt harnesses etc
    x2. or do they have like a 1/4 inch body lift?
  12. May 31, 2011 at 11:53 AM
    mxnborder
    mxnborder Well-Known Member
    Santa Barbara
    05 4x4 sport - black on black on black
    DR coilovers AAl 285 kelly safaris lightbar/skidplate need more!
    You could probably stick a small spacer ontop of your coilovers or the big spacer you have whichever is on top lol
