A little more lift.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Foozer, Aug 9, 2017.
  1. Aug 9, 2017 at 2:05 AM
    Foozer
    Foozer [OP] Well-Known Member
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Hey all. Right now on my 2012 trd sport i am running bilstien 5100s all the way around, fronts set at .85 and the rear tsb.
    I am wanting a little more lift but worry that the 1.75 setting on the billies will be nose high.
    I have been looking at the OME 883s (1.25"?) and the Eibachs (1.6" of lift) and thought about running them with the bilstiens set at 0. I have also just considered adding a 1/4" spacer to give me another 1/2" of lift.
    What are your guys thoughts? OME, Eibachs (will these be too high?) or add the spacer?
    Also, if doing the OME or the Eibachs I will need to get a spacer for drivers side lean right?
    Comments and pictures are very much appreciated. Thanks.
  2. Aug 9, 2017 at 2:17 AM
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport 4x4
    Stock
    Just do 885s with your existing 5100s set at 0 and grab add a leafs.
    :thumbsup:
    greeneggsnspam likes this.
  3. Aug 9, 2017 at 4:18 AM
    boogie3478
    boogie3478 Well-Known Member
    14 TRD Off-Road V6
    All the mods
    How much more do you want? Top plate spacers would be a simple and inexpensive solution for a little bit more lift (without ruining the ride quality).
  4. Aug 9, 2017 at 9:51 AM
    Just Dandee
    Just Dandee Well-Known Member
    Dan
    Southwest Idaho
    2015 TRD OR
    Supercharged-2.5 lift-255/85/16
    Another option- Body lift of 1". Just throwing out all the options. The 1/4 spacer sure would be the easiest- you can see my link on my spacer lift-I have been running a add a leaf I sourced from S-10 leaf pack from the rear- so you can do this real cheap. I have the TRD OR package so I like keeping my progressive front coil that already has the design for the lean. If you have the means $$ I think getting the OME spring would best.
    Foozer[OP] likes this.
  5. Aug 9, 2017 at 10:15 AM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Yea I'm thinking I'll just do that. I'm lookin for a more level look, at .85 it's still significantly lower in front than back, but I've heard 1.75 can make it nose high. I am looking for the front to sit at 1.5ish
  6. Aug 9, 2017 at 10:16 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    @HeadStrong Off-Road has a good selection of the top plate spacers ... plus free shipping. ;)
  7. Aug 9, 2017 at 10:31 AM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    Would 883s be nose high?
  8. Aug 9, 2017 at 10:34 AM
    boogie3478
    14 TRD Off-Road V6
    All the mods
    887 might but I doubt 883 would.
  9. Aug 9, 2017 at 2:32 PM
    Foozer
    Utah
    2021 TRD Pro - MGM
    265/75/16 BFG KO2
    How would 884s with the billies at 0 and am AAL 1.5" look? Anyone know?
