A little nervous
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 0BlackTaco6, Oct 7, 2010.
  1. Oct 7, 2010 at 1:08 PM
    0BlackTaco6
    0BlackTaco6 [OP] Ive got tiger blood
    New Hampshire
    06 BSP DC SR5 4x4 6 speed
    Color matched and satoshi grille, hella 500ff behind, bhlm, sockmonkey bedsides, 17" sports 265/70 grabber at2's.
    So I finally decided on a suspension set up for myself after doing a ton of reading and asking what others are running for a similar driving set up as i would use my truck for. Now my issue is im worried about screwing the truck up after install. Myself and my father are mechanically inclined. More so him, he has been in the buisness for 40 years. Ive read some horror stories about the diff bearing and different vibes. I just bought my taco as a certified used from a yota dealer. It only has 25000 miles. its a 06 dbl cb 4x4. I have a warranty. I guess my question is can someone give me some advice as to what they would do? I dont want to throw my lift in and have stuff start to screw up and and my warranty not cover it. Im not doing a ridiculous lift. I was planning on just putting 5100's all around, front set at 1.75 with an AAL. Then down the road upgrade the springs. And making it a better set up all around as time goes on. (i.e uca's, ect)
  2. Oct 7, 2010 at 1:10 PM
    Tacoma831
    Tacoma831 Member
    Santa Cruz, CA
    08 Tacoma Sport 4x4
    OME 886 Coils, OME Shocks, OME Dakars, Snug Top, De-Badged, ARB Bullbar, XRC8 Winch
    Don't be, the install is basic. I did mine myself with no outside help and I have put 25K on it since the lift with no issues.
  3. Oct 7, 2010 at 1:17 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    You should be pretty safe adding 1.75 in the front and AAL in the back.
    That should not create any vibes or the extreme CV angles that lead to wear.
    And your truck deosn't even have VSC, right? - so you don't need to worry about that.
    I recommend DIY. That way, you know everything's done to your satisfaction. And, you have the confidence to take care of any issues that come up.
  4. Oct 7, 2010 at 1:22 PM
    SplitDecision
    SplitDecision Phones Ringin Dude
    Haywood Jablowme
    NY
    Silver TRD OR
    Bilstein 5100x4, Truxedo lo pro QT,Hid Retro,2011 painted grill,Alpine head unit,Foglight mod,NFAB steps
    That's no extreme lift OP. I have the same thing with no vibration. Don't sweat it. Install and enjoy.:)
  5. Oct 7, 2010 at 1:22 PM
    tacobell007
    tacobell007 Does that have the v6?
    Drew
    Westfield, MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, Walker Evans remote resi coilovers with adjustable dampening, Icon tubular uniball UCAs, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Alpine 250 watt amp, stickers, Rigid 32" gang box, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 35x12.5x17 Mastercraft Courser MXT's, Fuel Off-Road Trophy d551 in 17x8.5, Retros, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro5R drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear high clearance plate with swing out and full size spare, SOS bolt-on sliders with kickout, 22" LED bar, flush mount pods in rear plate bumper for aux reverse lights, Rigid Industries dually's on SOS ditch light brackets
    buy a diff drop kit and i think they are shims? you should be good to go
  6. Oct 7, 2010 at 1:37 PM
    0BlackTaco6
    New Hampshire
    thanks for the quick responses. Yea i know its not an extreme lift. thats not what im looking for anyway. I have just read stories about people with a similar set up that started to develop issues shortly after the install. Im not worried about the install at all. As me and my dad have lifted or lowered tons of vehicles in the past. I was just more worried about developing problems, and problems that would screw me out of getting them fixed under warranty.
  7. Oct 7, 2010 at 1:38 PM
    0BlackTaco6
    New Hampshire
    Is the diff drop a good idea to put in even though im only going 1.75? Most of the stuff ive read its only an issue with 2.5 or higher. I suppose it couldnt hurt regardless of the height.
  8. Oct 7, 2010 at 2:15 PM
    SplitDecision
    Haywood Jablowme
    NY
    Silver TRD OR
    I personally would just install what you have and address problems IF they pop up. I really doubt you will have any major issues. Are you doing an AAL to TSB spring pack or the 3 leaf pack?
  9. Oct 7, 2010 at 2:33 PM
    dirtytaco2010
    dirtytaco2010 Well-Known Member
    south lake tahoe, CA baby
    SR5 TRD Sport LB
    custom badging, Black Badges, tint, General AT/2's, nerf bars black, ultra-gauge,toytec AAL, removed mud flaps, Bilstein 5100's @ 2.75, AFE pro dry s air fliter, spidertrax, black rock 17'' wheels
    i have billies at 2.5 and aal no warranty issues shocks arent under warranty anyways ive had warranty work done since with no issues
  10. Oct 7, 2010 at 2:40 PM
    Andrew H
    Andrew H What is this "search" you speak of?
    Dirty Tucson
    2017SSMDCSBTRDS
    thats the exact set up that I have. No vibes or anything. You will enjoy it!
  11. Oct 7, 2010 at 2:44 PM
    raswank
    raswank Well-Known Member
    Rick
    Auburn,Ma
    2010 Tacoma Double Cab 4x4 6 speed
    Grillcraft, Rear leaf TSB, 5100's at .85, with Eibachs, 265/70/17 BF Goodrich AT/S Tires, Hella 500's behind Grill, Kenwood KDC X995 H/U all Boston Acoustic speakers, JL Audio subs, Kenwood XR5 S amp, ATX Chrome 17x8 wheels
    What set up do you have that you have them at 2.5? I heard you can't without issues. I have the TSB in mine. And I want to do 2.5 but see many people post you can't without issues. Do you have the diff drop kit? Do you have the TSB yet? Just want to lift it but don't want issues you know. And am just going to put 265/70/17 on it nothing more. Thanks for your time and sorry for all the questions. Just so many different stories to follow.
  12. Oct 7, 2010 at 2:48 PM
    dirtytaco2010
    SR5 TRD Sport LB
    I dont have TSB just the toytect 1.5'' AAL in the rear and the billies set at 2.5 or 2.75 whicever the highest is. no diff drop its unecessary with that height. I have no issues whatsoever. didnt even need an alignment. im running 265 70 17 as well do it youll love it
  13. Oct 7, 2010 at 3:23 PM
    0BlackTaco6
    New Hampshire
    im like 99% sure its just the 3 leaf pack. i looked at it when i bought it but cant quite remember. As for going the full 2.5 from what ive read (and im no expert just saying from my research on here) if you go the full 2.5 it may not be required but it is a damn safe bet to do the diff drop. You dont want anymore stress on the cv's than needed. It kinda seems like its all in what you think though. Some say its not needed others say its a must. Imo if i were going the full 2.5 or higher i would with no question put the diff drop in. Thats just my thought. But im no expert. i just read haha.
  14. Oct 7, 2010 at 3:31 PM
    raswank
    Rick
    Auburn,Ma
    So what would I add to the rear with the TSB already done? I don't want blocks.
  15. Oct 7, 2010 at 3:32 PM
    raswank
    Rick
    Auburn,Ma
    You say you have the same set up, but in your mods it states 1.75. So which is it?
  16. Oct 7, 2010 at 4:14 PM
    0BlackTaco6
    New Hampshire
    raswank i believe he was answering my original post question. thats what is was asking about. the 1.75 setting.
  17. Oct 7, 2010 at 4:20 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    Where do you want to put your stress? If you install the diff drop you ease the angle on the CVs but throw off the angle of the front driveshaft from the T-case to the front diff.
    CVs were made to flex with the suspension. Anything under 3 inches really shouldn't be terribly stressful for them.
    Even if they are stressed a leetle extra, replacing boots isn't horribly hard or expensive in the grand scheme of things.
    Personally, I would rather work my CVs a little harder than muck with T-case/differential orientations.
  18. Oct 7, 2010 at 4:21 PM
    0BlackTaco6
    New Hampshire
    makes sense man. thanks for shedding light on that. like i said im no expert. sorry if i led anybody wrong. guess i didnt really think of it that way. Thanks again!
  19. Oct 7, 2010 at 4:26 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    Yeah, do it. My dad and I are retards when it comes to vehicle mechanism. We put my billy's/ AAL on no problems, besides some bloody knuckels :D
  20. Oct 8, 2010 at 3:09 AM
    0BlackTaco6
    New Hampshire
    Good deal. ill have to get crackin on it. Thanks for all the input.
