A little puzzeled here.. maybe you can figure it out
Discussion in '2nd Gen. Tacomas (2005-2015)' started by prerunner05, Nov 13, 2009.
  1. Nov 13, 2009 at 8:44 AM
    prerunner05
    prerunner05 [OP] Well-Known Member
    David
    middlesex,va
    05 prerunnerSR5 5spd
    265/65/r17 . fog lights. secondary air filter removal,AFE Pro S dry drop in. double din navigation HU 6.5" componet speakers in the back
    I get in my truck this morning to run and get me my cup of coffee from 7-11. and i go to turn my heat on but no air is blowing through the vents. Now i can feel a little bit of air but not much, also i can still switch from vents to floor to defrost.etc... and change from hot to cold just. As i said i could feel a little bit of air but its only when i get up to about 60mph seems to come thru a bit but when i stop no air at all is blowing through. So damn confused. Any suggestions? :confused:
  2. Nov 13, 2009 at 8:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Sounds like you have something stuck in the vent control.....
  3. Nov 13, 2009 at 8:47 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Is the fan blowing?
  4. Nov 13, 2009 at 8:54 AM
    prerunner05
    David
    middlesex,va
    possibility since i went out playing in the the storm from that wicked nor-easter over my way. had to get sum mud on the tires:D.
    and by the fan blowing you are talking about? and where is the vent control located? thanks
  5. Nov 13, 2009 at 8:56 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Can you hear your Fan blowing harder when you turn the fan control knob??
  6. Nov 13, 2009 at 8:56 AM
    98tacoma27
    98tacoma27 is going full "Ben" Moderator
    Ben
    Beech Creek
    05 Tundra SR5 (+265k AND COUNTING), 88 SR5 PU (SOLD), 98 TRD OR (CRUSHED)
    5100's all on fours
    The blower for the heat/ac.
  7. Nov 13, 2009 at 8:59 AM
    prerunner05
    David
    middlesex,va
    nope dont really hear nothing out of it
  8. Nov 13, 2009 at 9:01 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    No sound or flow on any speed setting. correct?
  9. Nov 13, 2009 at 9:04 AM
    prerunner05
    David
    middlesex,va
    correct nothing what so ever.
  10. Nov 13, 2009 at 9:05 AM
    prerunner05
    David
    middlesex,va
    any of you know where i can find the fuse diagrams for these trucks. think it might be a fuse??
  11. Nov 13, 2009 at 9:06 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
  12. Nov 13, 2009 at 9:06 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Left hand side of dash, fuse box will tell you what everything is, same with fuse box under hood.
  13. Nov 13, 2009 at 9:33 AM
    prerunner05
    David
    middlesex,va
    yep just realized that tool the fuse out and put it back in now everthing is working fine. dont understand that but hey im not complaining:rolleyes: it works! thanks guys
  14. Nov 13, 2009 at 9:39 AM
    Coreyjon
    Coreyjon Northern Alliance: Airlift Div
    Upstate, Ny
    08 DCab 4X4 SR5 TRD Sport
    iPod Adapter, Bilstein 5100's @ 1.75" front, Wheelers 3-leaf 1.5" + overload rear (2"), custom carrier bearing drop spacers.
    Sometimes thats all it takes, maybe the fuse was installed backwards??:D:D
  15. Nov 13, 2009 at 9:48 AM
    BakoTruck
    BakoTruck Well-Known Member
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    Mostly stock for now, I have added a cb radio, various cheap mods and I plan on adding aftermarket wheels and other items in the future.
    It could be something simple, do you have your air recirculation button off? When you have it off it doesn't blow air as fast, it is located on the bottom right between the temp nob and the nob to control where the air will go. It has a image of a car on the button and an arrow inside the image of the car, this location is for 2nd gen. A little light will light up when it's on or pushed in.
    I don't really know just thought I would throw that out there, I haven't used the heat in a long time so I don't know if it blows out faster with the button pushed in, but I know it does with the a/c on.
  16. Nov 13, 2009 at 9:59 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    :facepalm:
  17. Nov 13, 2009 at 10:04 AM
    BakoTruck
    Herbie Hancock
    Bakersfield, CA
    05 PreRunner TRD
    98tacoma27
    Relax!
    I don't do that, that often!
  18. Nov 13, 2009 at 10:19 AM
    98tacoma27
    Ben
    Beech Creek
    5100's all on fours
    Haha, was just joking man. Forgot the J/K at the end.............:D :eek:
  19. Nov 13, 2009 at 10:21 AM
    nasty ned
    nasty ned Well-Known Member
    mass
    05v6trd access
    nerf bars ventvisor kit nose & windows
    did you try the recirc.button or a/c botton ?
  20. Nov 13, 2009 at 10:23 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Issue is fixed...Read all the posts. :)
