A Locker idea/request thread
Discussion in '1st Gen. Tacomas (1995-2004)' started by MowTaco, Apr 22, 2011.
  1. Apr 22, 2011 at 2:29 PM
    MowTaco
    MowTaco [OP] Well-Known Member
    Kansas
    16 Chevrolet Silverado
    So I've been getting that locker bug again (for my pussy 5 lug yes) and I need your help. I have access to a factory e-locker fully assembled 3rd member from my shop teacher at school. He bought it for his 4 runner and then sold the car before putting it in. We can easily handle the fabrication if it will fit. That's where you come in. I need to know the specs of the TRD rear axle... here's a table to help
    THIS CHART IS FOR '95.5-04 MODELS ONLY!
    The axle code for your rig can be found on the manufacture's sticker located on the driver's side door jamb as follows:
    First digit:
    A = 7.5" ring gear
    B = 8" ring gear
    Next two digits:
    01 = 3:42
    02 = 3:58
    03 = 4:10
    04 = 4:56
    05 = 3:15
    06 = 3:91
    07 = 4.30
    Last digit:
    A = 2 Pinion, Open
    B = 4 Pinion, Open
    C = 2 Pinion OEM Limited Slip
    some '98-00 models have shown a BO code of "???" on the door plate; so far this turns out to be a 3.91 gear ratio, at least for the 5sp. RZN171L-CRPDKAB with factory 31s/265s should be 4.56 with the AT.
    Edit by Ed Quinones on 10-7-05: I used to own a 99 Prerunner ext cab 2.7L with auto tranny and gear code of B07A. It came from the factory with a 4.56 gear ratio.
    Mine is A02A, which is a 7.5" ring gear. I believe the TRD have the 8" ring gear so I may be SOL. Would the 8" ring gear fit in my 7.5" housing? I really hope so because I think I'll get a pretty good deal on it and I'd get 4.10 gears out of the deal too. Thanks in advance for anyone who can help!
  2. Apr 22, 2011 at 6:39 PM
    DanglingFury
    DanglingFury Creeper
    Keith
    Bowling Green, KY/Lake Cumberland, KY
    2006 4Runner 4x4
    Daystar 2.5"/1" lift-level BFGoodrich KO2's
    I think that the only way to get the 3rd member under your truck is to have the whole rear differential and housing from a trd truck. . . then you're stuck with 6 lug in the back and 5 lug in the front . . My advice is get a mechanical locker, that's what i plan on doing. Probably a powertrax or something like that.
  3. Apr 22, 2011 at 6:47 PM
    jeff b
    jeff b Well-Known Member
    detroit truetrac....it works and you wont even know it's there
  4. Apr 22, 2011 at 6:48 PM
    DanglingFury
    Keith
    2006 4Runner 4x4
    jeff b- how much was your tru trac?
  5. Apr 22, 2011 at 7:02 PM
    TacoTaro
    TacoTaro Well-Known Member
    Los Angeles
    04 DC 4x4
    King Coilovers, Light Racing UCA, OME Dakar leafs w/ extra leaf and SB10" Bilstein 7100's and a U-bolt flip. 4.56's, eLocker rear, ARB front, Marlin rear bumper, ARB Bull Bar w/ Warn M8000. BAMF Sliders. Manual hub conversion with functioning ABS. Tundra front brakes. Manual hub conversion with functioning ABS. SCS F-5's w/ 255/85 Toyo MT's
    None of your options are cheap.
    You can get an Limited Slip, I pretty sure you can look at 7.5" LSD's for Supra's etc.
    or
    You can get an ARB. The same part number that fits the front IFS will work for the rear 7.5
    Another possibility. Run a TRD rear with either 1) custom 5 lug axles, or 2) Re-drill the 6 lug axles for 5 lugs. I once got a set of axles redrilled for a hot rod to change bolt patterns.
  6. Apr 22, 2011 at 7:13 PM
    Blue
    Blue You're my boy blue
    Dylan
    Sierras
    ex 99 current 04 TRD
  7. Apr 22, 2011 at 8:11 PM
    jeff b
    I got it from Randys ring and pinion honestly don't remember how much I paid (2001)?? It's the first mod I did because getting stuck in 1 inch of snow sucked.
  8. Apr 22, 2011 at 8:19 PM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    Richmond Gears makes a couple nice options. Lockright or a no-slip. I have a No-slip in mine and i dont have any complaints so far.
  9. Apr 23, 2011 at 4:50 AM
    DanglingFury
    Keith
    2006 4Runner 4x4
    Getting stuck in one inch of snow . . . Yea. . . makes ya feel silly.
  10. Apr 23, 2011 at 7:07 AM
    jeff b
    I have a lockright in my jeep it works pretty much the same but for daily driving? Truetrack all the way.
  11. Apr 23, 2011 at 7:20 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    I wouldnt recommend Lockright for a daily driver either, but the road manners of the No-slip are alot better.
  12. Apr 23, 2011 at 8:42 AM
    jeff b
    I've had a Lockright on my daily driver since 2001 with know problems and I drive it like I stole it. Please enlighten us why you wouldn't recommend?
  13. Apr 23, 2011 at 8:48 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    I dont necessarily think it would cause any problems for a daily driver, i just think for IIRC $100 more you can get the no-slip. From what i have heard (ive never ran a lockright) it has better street manners. Does your lockright chirp the back tires when you make a tight turn?
  14. Apr 23, 2011 at 10:47 AM
    jeff b
    No chirping at all. It engages when one wheel spins and traction is lost. It's brilliant really. Sometimes on ice I have to let off and get back on the gas but it keeps me movin forward.
  15. Apr 23, 2011 at 10:59 AM
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    Hmm they sounds pretty similar then if you ask me. This is what i found that differs between the two.
    Edit: I didnt truly know the difference sorry.
    No-slip
    These Powertrax no-slip traction systems are the latest design in traction-adding differential technology. They combine the smooth operation of a limited-slip differential with the traction performance of a locking differential. A precise synchronization mechanism eliminates the ratcheting sounds typical of other locking differentials. Special gear and spring designs reduce the backlash and, therefore, the driveline windup. Only ultra-strength material that is 67 percent stronger than titanium is used. Installation is simple because no ring and pinion setup is required. In addition, no special tools or oils are needed. Step-by-step, model-specific instructions are provided with every kit.
    Lock-right
    The Powertrax Lock-Right and Performance Lockers' straight-line performance is equal to a solid spool axle, yet automatically unlocks to allow full differentiation in turns. The lockers also reduce the excessive noise, tire wear, and drivetrain damage associated with other lockers. Made in the U.S.A., Powertrax lockers replace the spider gears in your differential carrier without affecting your ring and pinion settings. The whole job can be done in your driveway with common hand tools in a couple of hours. A carrier is not included.
  16. Apr 23, 2011 at 11:21 AM
    jeff b
    Looks about right except the easy install part on LSD. I did the powertrax on my jeep myself easy no problem. I let a professional do the LSD, waay to much involved for the average joe.
  17. Apr 23, 2011 at 3:42 PM
    MowTaco
    Kansas
    Did any other vehicle come with an E-locker on a 7.5" ring gear? Like maybe a 4 runner? I don't know what it came out of for sure.
  18. Apr 24, 2011 at 9:52 AM
    DanglingFury
    Keith
    2006 4Runner 4x4
    What about directly swapping the rear axle from a Ranger? (it would be treason, i know.) I'm not sure about how well it would fit etc etc but at least you could use the wheels you already have?
  19. Apr 24, 2011 at 9:59 AM
    DanglingFury
    Keith
    2006 4Runner 4x4
    The Ranger GTs that were made around 1986 had a "Traction-Lok" limited-slip differential with 3.73 gears.
    And the newer FX4 level II has a 31-spline 8.8-inch rear axle with a Zexel-Torsen limited-slip differential. They started that package around 2009.
  20. Apr 24, 2011 at 2:14 PM
    MowTaco
    Kansas
    Well I guess I'll stick with the lunchbox locker then if I want to lock it up. The 3rd is for sale now... if anyone's interested I can ask the owner for you.
