A loose wheel and hair raising experience
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Boyd44, Jun 16, 2021.
  1. Jun 16, 2021 at 4:33 PM
    Tango Bravo
    Tango Bravo Sailing the Seven Seas
    Thomas
    SoCal
    09 4x4, The Green Rubber Ducky
    Chaos 3.5" Race LT, RJ Fab Cantilever LT
    Brakes could have been if they pulled the pads off. They squeeze the brake caliper all the way open to make it easier. Takes a few pumps after reinstall to get proper braking pressure back.
  2. Jun 16, 2021 at 4:37 PM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    That's two levels of incompetence then - I've never seen someone not pump the brakes after pulling pads, and I've never heard of pulling pads for a 20k service.
    TRD-ED, Vlady, Chew and 6 others like this.
  3. Jun 16, 2021 at 4:41 PM
    GOTSAND?18
    GOTSAND?18 Well-Known Member
    2020 tacoma trd off road 4x4 Manual
    stock
    Personally I would have them do a full inspection of everything…replace all brake pads .
  4. Jun 16, 2021 at 4:42 PM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Wow, so much struggle here.
    Race car drivers with simple wet brakes frequently have to double pump their brake pedal because after a hard corner there is enough deflection in the wheel bearings to push the brake pads further back in the caliper. (Think more like old VW beetle sand rail/dirt track car.)
    If his tire was loose the brake rotor itself would have pushed the brake pad further in the caliper. Causing him to have a soft pedal on the first press. The brake rotor is held on with the wheel and lug nuts. If they are not tight it can shift side to side quite a bit.
    This is not rocket science.
  5. Jun 16, 2021 at 4:44 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe ABS prevented the wheels from locking up. Edit: 1955 Buick’s never had this problem
    CrufflerJJ likes this.
  6. Jun 16, 2021 at 4:45 PM
    Brianz1001
    Brianz1001 Well-Known Member
    Brian
    Retired on my couch with a cold beer in my hand
    too much to type
    That would be nice but never going to happen. At best they will check and replace items from the lose wheel, rotor, pad, studs and lug nuts. caliber if damaged.
  7. Jun 16, 2021 at 4:46 PM
    stevesnj
    stevesnj Well-Known Member
    South Jersey/Philly Area
    1996 Land Cruiser 80 Series
    Neither is tightening lug nuts.
    Gunshot-6A, gman2431, Skydvrr and 3 others like this.
  8. Jun 16, 2021 at 4:47 PM
    ZColorado
    13 DCSB OR 6MT
    It was targeted at the people who can't seem to understand why a loose wheel would cause braking issues.
    jmneill and stevesnj[QUOTED] like this.
  9. Jun 16, 2021 at 4:47 PM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    Holyshit!!!
    boston23 and Steves104x4 like this.
  10. Jun 16, 2021 at 4:48 PM
    stevesnj
    I know...I was targeting the dumb schmucks who failed to tighten lug nuts.
  11. Jun 16, 2021 at 4:49 PM
    eurowner
    eurowner Duke Sky
    Scoty
    Because drums :rockband::rimshot:
  12. Jun 16, 2021 at 4:50 PM
    RatDaddy
    RatDaddy Well-Known Member
    Roy
    2017 Tacoma TRD O/R Premium pkg
    None
    I can see someone doing that if they are close to the shop. The smart thing would have been to pull into a lot and call the dealer, have a tech come out.
  13. Jun 16, 2021 at 4:51 PM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Hang on.
    I've only done a couple of wheel jobs on a couple of vehicles, but on all of the ones I've done, tightening the lugs does not tighten down the spindle or the rotor. The castle nut does that.
  14. Jun 16, 2021 at 4:54 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    On the taco and my
    Old ranger the rotor is held in place by tightening the wheel lugs.
  15. Jun 16, 2021 at 4:55 PM
    #35
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Well then I learned. That's wild stuff.
    gman2431 and Junkhead[QUOTED] like this.
  16. Jun 16, 2021 at 4:57 PM
    #36
    MGMDesertTaco
    Not the first time of heard of this or seen this actually. A few years ago a newer 4runner barely made it off the dealer lot and around the corner. His wheel fell off too. Most likely the tech put the lugs back on all 4 tires and forgot to torque them when they were done.
    On a side note, if they inspected your rear brakes and had the rear drums off they might have been improperly adjusted. The star wheel needs to be turned an equal amount of clicks on each side to push the drum shoes close to the brake drums. (Too many clicks the shoes drag, too little and the brake pedal can go to the floor as the hydraulics are trying to make up the extra gap space between the brake pads and drums.)
    I'd also inspect that left front brake rotor for any scuffing or damage and also the rims for any damage as well. Then have the service department make a note in their records of exactly what happened in case of any future issues. You want it documented that the tech didn't tighten the lugs and the wheel fell off. You might be able to get a free car wash or Sirius xm radio subscription out of it. You can also call Toyota corporate and explain, but I'm not sure they'll do much. Glad you're okay.
    https://www.youtube.com/watch?v=Ii8rC6CPCvM
    Gunshot-6A, NEIPA27, jcmotr and 2 others like this.
  17. Jun 16, 2021 at 5:01 PM
    #37
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    They dont make’m like they usetah
    gman2431 likes this.
  18. Jun 16, 2021 at 5:20 PM
    #38
    Boyd44
    Boyd44 [OP] New Member
    Tacoma 2019 TRD Sport
    As I said in my original post, I eventually had some braking power. When I first hit the brakes, I had nothing but I quickly realized that I had to depress the pedal about half way before I got any grab.
    stevesnj and BSFord like this.
  19. Jun 16, 2021 at 5:20 PM
    #39
    gman2431
    gman2431 Well-Known Member
    The tech or the truck?
    CrufflerJJ, Junkhead and Skydvrr like this.
  20. Jun 16, 2021 at 5:23 PM
    #40
    eurowner
    eurowner Duke Sky
    Scoty
    What vehicles? That is not common.
    The rotors are squeezed against the hub and the wheel.
    The hub is held on by the spindle nut tightening against the spindle.
    Drums, for sure.
    Junkhead likes this.
