A Mystery Glitch After Eight Years!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by The Grateful Griller, Oct 8, 2015.
  1. Oct 8, 2015 at 12:57 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe a fuel pump relay
  2. Oct 8, 2015 at 1:03 PM
    The Grateful Griller [OP] Member
    2008 Tacoma TRD Ext. Cab 4 Door Canadian Model
    Possibly, but not sure, thanks for chiming in on this one.
  3. Oct 8, 2015 at 1:17 PM
    Gatordog
    Gatordog Well-Known Member
    Florida
    18 TRD SPORT DCLB4x4
    wifes suv had similar problem. No check engine light but would stall for no reason then not re-fire/ then like a switch was thrown would be fine for days... then same thing. Replaced MAF sensor, TPS, Crank sensor, fuel relays, fuel pump and on and on and every time they opened the engine of course the timing belt just because they were in there. Finally gave up 3,500 dollars later in various repair tries and mechanics saying "drive it to Alaska your fixed" only to have it die again. My vote now is when the ghosts show up, try and figure it but cut your losses at some point.
  4. Oct 8, 2015 at 1:23 PM
    bacollier90
    bacollier90 Well-Known Member
    Bryce
    Springfield, MO
    19 DCSB 4x4 Cement
    Sounds like your mechanic won.
  5. Oct 8, 2015 at 1:26 PM
    Gatordog
    Florida
    nope, never took it to the same one twice since that would be my first guess too. Three stealerships and two "great" good ole boy shops local.
  6. Oct 8, 2015 at 1:59 PM
    Thanks for the truth BUT I'm determined there has to be an answer somewhere under that hood, lol! Fingers crossed and much appreciate the detailed story.
  7. Oct 8, 2015 at 6:37 PM
    Jason J
    Jason J Well-Known Member
    oregon
    08 tacoma 4x4
    When you say it starts and dies does it run for a second, seconds, or die as soon as you release the key switch? Hot or cold engine or both first start of the day or after running awhile?
  8. Oct 8, 2015 at 8:34 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    PCV Valve
    Positive Crankcase Ventilation Valve. Easy cheap to replace. Replace it or you will begin to burn and or leak oil.
  9. Oct 9, 2015 at 5:02 AM
    Thanks kindly for the advice, on the list of to do's.
  10. Oct 9, 2015 at 5:19 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Had a jeep back in 89 do exactly what you described, turned out to be a cracked coil
  11. Oct 9, 2015 at 5:22 AM
    Thanks for the advice, have not heard that one as of yet. On the list it goes and much appreciated!
  12. Oct 9, 2015 at 5:33 AM
    car78412
    car78412 Well-Known Member
    Hudson Valley NY
    13 Tacoma reg cab 4x4
    Sell it.
  13. Oct 9, 2015 at 5:37 AM
    tomwil
    tomwil Well-Known Member
    East Coast USA
    2014 Reg Cab 4x4
  14. Oct 9, 2015 at 6:51 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Why has no one asked the mileage of the vehicle yet?
  15. Oct 9, 2015 at 6:53 AM
    #35
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
  16. Oct 9, 2015 at 7:05 AM
    #36
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    maybe because OP put it in post 1 you think ?
    do you even read ?
  17. Oct 9, 2015 at 7:08 AM
    #37
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Clearly not as clear as I think I should. Lol.
    Technically my question is correct though. No one asked the question. Obviously because it was answered prior needing to be asked.....
    I should grab another cup of coffee before I start asking anymore questions.....lol.
  18. Oct 9, 2015 at 7:15 AM
    #38
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Still all in on the fuel filter/pump combo. 8 years and 172k miles on the same filter....it's well to the point of saturation of contaminants. 15 - 20k miles will show copius amounts of contaminants depending on where the fuel is purchased.
  19. Oct 9, 2015 at 7:16 AM
    #39
    DT08sr5
    DT08sr5 Member
    Dean
    2021 TRD Sport 4x4 6MT Cement
    265/75r16 Duratracs, Back Rack
    Hey i have a 2008 in canada as well and i have a similar problem, not sure if its the same as yours. The problem for me started when i would leave the key in the ignition for a couple hours with the truck unlocked. It would start fine and run for 5 seconds then die and would not restart until i got out of the truck, locked it, then unlocked and tried to start it again. Then it would start up just fine and wouldn't happen to me for a couple weeks. I believe its a security thing because a month ago i switched to using my spare key which i never used before and the problem hasn't come up again. Hope this might help!
  20. Oct 9, 2015 at 7:31 AM
    #40
    R0dzilla75
    R0dzilla75 Well-Known Member
    Rodney
    Virginia
    05 Sport
    HID fog light 265-70-17 Firestone destination ATs Led interiors lights TRD seat covers
    A vacuum leak would throw a code. Clean the mass air flow sensor and disconnect the battery for 30 minutes or so. I would also think throttle position sensor would also have a code. I know on my blue driver I can check various systems including throttle position so hook up a scan tool and go to work. Could get lucky.
