A New Purchase Dilemma - Valve Problem
Discussion in '2nd Gen. Tacomas (2005-2015)' started by OpieC, Jan 3, 2015.
  1. Jan 4, 2015 at 9:10 AM
    SxSW
    SxSW Well-Known Member
    Joe
    NM
    14 Base
    I wouldn't want the truck, but since you will probably end up stuck with it I would get towing insurance and probably not drive very far from home the first year.
  2. Jan 4, 2015 at 9:59 AM
    Bucc5207
    Bucc5207 Well-Known Member
    Yrisarri, NM
    2014 V6 SR5 4x4
    They don't promise to make every single vehicle perfect. They provide a warranty to assure you they will make it right if it's not perfect off the line.
    I vote Take the new head, and Go for the extended warranty.
    When have you ever heard someone say, "I had my cylinder head replaced, and my truck has never been the same since?" A new head sounds like a complete (maybe even overkill) solution.
    In addition, after 200 miles, you have some data about whether the truck has any other issues. Why would you want to start over with a new vehicle?
  3. Jan 4, 2015 at 10:01 AM
    85GT 79FJ40
    85GT 79FJ40 Well-Known Member
    Ken
    New Hampshire
    19 TRD Sport DCSB 6M - 2017 Honda Africa Twin
    I would be upset if it were my truck too but Toyota will certainly stand behind it if they do the repair and the chances of further issues down the road are next to zero. Both the heads were off mine 25k miles ago and it's perfect.
    Oddly enough a coworker was asking me about a 2015 TRD pro or TX pro (can't remember which) that his brother was looking at semi-locally at a dealer in Massachusetts. Like 900 miles on it, 8 grand off sticker price. Carfax shows one cylinder head replaced at around 150 miles. Perhaps they had a bad batch of valves and built a bunch of trucks like this?
  4. Jan 4, 2015 at 10:29 AM
    toomanytoys84
    toomanytoys84 Well-Known Member
    Stock
    Have you ever replaced a head or head gasket on a car? I've thrown junk yard heads(after having them checked) on cars and never had a problem.
    Changing out the entire head is probably over kill as they could replace only the bad valve.
    I wonder how many people on this website actually work on their own vehicles instead of being an Internet mechanic
  5. Jan 4, 2015 at 10:48 AM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Pretty much every defect that customers identify and have repaired under warranty, and all those that Toyota identifies as TSB or recall issues, are the result of a design or manufacturing flaw. Those flaws all existed when we bought our trucks. The fact that your first issue surfaced after 200 miles instead of 20,000 miles isn't really relevant.
  6. Jan 4, 2015 at 11:14 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I can understand how they found it via a leak down test as with the valve too long it wouldn't seal properly when closed.
    How they came up with the 1/32 inch number... I think they pulled that out of their ass.
    OP. They only owe you a repair / replacement at no charge, Accept it and move on.
    You don't have to be "That Guy". Unless maybe you are That Guy. Hmmm [​IMG]
  7. Jan 4, 2015 at 11:50 AM
    glwood6
    glwood6 Well-Known Member
    Gary
    Albuquerque, NM
    03 XCab Prerunner
    Bilstein 4600 shocks.
    If that is the minimum you will accept, not sure what advice you want. Sounds like your mind is made up. Let us know how that works out with your dealer.
  8. Jan 4, 2015 at 12:13 PM
    Shelf Life
    Shelf Life Well-Known Member
    Rob
    Central Oregon
    '06 ACC CAB 4x4 TRD OFF ROAD
    Uh Oh. cue up the next recall from Toyota?
  9. Jan 4, 2015 at 2:21 PM
    asuchemist
    asuchemist My Hamstrings Hurt!
    South South Dirty Gilbert
    11' TRD Sport V6, 23' TRD Pro 4Runner, 23' Tacoma TRD Pro
    NONE
    this is on toyota not the dealership. talk to toyota to see if they can give u extended warranty for peace of mind.
  10. Jan 4, 2015 at 2:33 PM
    fixnfly
    fixnfly Well-Known Member
    S.W.PA
    05 Access cab 4.0 4WD
    No shit!
    How about telling us the whole story.
    Probably another bullshit thread that gets everyone all stirred up:rolleyes:
  11. Jan 4, 2015 at 2:44 PM
    Tommiet
    Tommiet Well-Known Member
    Tom
    Charlotte Area
    PreRunner
    +2
  12. Jan 4, 2015 at 3:03 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Assuming it's a 4L that's 31 thousands they are shimmed valves it should have run for Sh%^ right out the factory door. Sounds fishy to me.
  13. Jan 4, 2015 at 4:52 PM
    OpieC
    OpieC [OP] Member
    Your first sentence seems accurate compared to how it was described to me.
  14. Jan 4, 2015 at 4:53 PM
    OpieC
    OpieC [OP] Member
  15. Jan 4, 2015 at 4:56 PM
    #35
    OpieC
    OpieC [OP] Member
    Sorry. No BS. 50 miles into driving it, the check engine light came on simultaneously with the "Trac Off" light. The code was one the delear service dept. had not seen before, thus they contacted Toyota Tech. for assistance.
  16. Jan 4, 2015 at 10:07 PM
    #36
    Jimmyh
    SC
    2012 Prerunner SR5
    OP. A head replacement performed as a unit is an easy and fast fix for this issue. They should be able to complete this in one day.
    IMO they are not going to give you a truck replacement for this simple repair. Regardless of what you demand or tell them you are not going to accept anything less.
    You will catch more flies with honey...
  17. Jan 4, 2015 at 10:23 PM
    #37
    TrdSurgie
    TrdSurgie revised
    Oahu
    Woohoo free extended warranty :)
  18. Jan 4, 2015 at 10:36 PM
    #38
    DJB1
    DJB1 Well-Known Member
    Dave
    SLC, UT
    2003 Regular Cab 4X4 5MT
    A defective valve does not warrant 4200 lbs. of replacement truck. It will be a minor inconvenience while your new truck is in the shop, but you will probably get a free extended warranty. First world problems...
  19. Jan 5, 2015 at 2:47 PM
    #39
    maineah
    Tim
    Maine
    4X4 SR5 V6 6spd
    With out the valve in their hand it would be impossible to measure the length. Just what was the code? P0623 valve too long?
  20. Jan 5, 2015 at 3:37 PM
    #40
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    OP, is the truck now at the dealer's shop? Did they say when it will be fixed?
