A question about 4wd and turning.
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Newtacoowner2016, May 30, 2017.
  1. May 30, 2017 at 9:27 PM
    Newtacoowner2016
    Newtacoowner2016 [OP] Member
    Good day fellow taco owners! Long story short I purchased my very first vehicle late last year (2013 TSS 4wd tacoma). I do my best to take care of my truck and one of the things I was suggested to do was to drive in 4wd for 10 miles a month to keep everything down there lubicrated. From home to work is pretty much a straight shot except for one hard right turn (basically a right angle turn if that makes sense). When I do this hard right turn, I notice that the farther into the hard right turn, the harder the turn gets. Now let me clarify that I have driven a vehicle without power steering and it isnt anything like that. I can just feel the difference in that turn when I have 4wd on and off. So wall of text aside, is this normal? Do all 4wds do this when turning? Am I going too fast into the turn? Thx for your time and answers guys!
  2. May 30, 2017 at 9:37 PM
    silvytaco19
    silvytaco19 Member
    14 Barcelona Red Sport DCSB
    Yes it's normal, in 4WD it puts the front wheels in a "bind" while turning because it's trying to turn both wheels at the same time. Obviously it's noticed more on pavement compared to snow or mud
  3. May 30, 2017 at 9:39 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    Yeah don't drive on pavement in 4WD...
    But while you're in 4WD, it is a tad harder to turn.
  4. May 30, 2017 at 9:41 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It's not advised to make hard turns in 4x4 unless the tires can slip, i.e. dirt, snow, or even when it's raining.
    I understand the manual states to drive 10 miles a month in 4x4, but here's my take on it. I think they put that in there so when Billy Bob who's owned his truck since new and never used 4x4 and all of a sudden decides to use it 100k miles later and something breaks, Toyota isn't held responsible.
    silvytaco19 likes this.
  5. May 31, 2017 at 12:49 AM
    Backt
    Backt Well-Known Member
    Oregon
    2012 Tacoma DCSB Off Road Pryrite Mica
    I bought a 2012 off road a little over 2 years ago. The first time I was on a dirt road I engaged the 4wd, 4lo, and the differential lock. The diff was difficult to get in and just as difficult to get out. After about 8 tries over a month the diff lock started to engage much easier. I drive on a dirt road or can about 4 times a year at a minimum so I do it then.
    At a minimum I would engage it 2x a year while on dirt road and go through all the drive modes and drive the 10 miles. If that is all you can do I would also engage the 4wd a time or two while stopped just to engage it and then go back to 2wd.
  6. May 31, 2017 at 12:50 AM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    Just disengage 4hi before the turn and reenagage it afterwards.
    tomwil and TacomaMike37 like this.
  7. May 31, 2017 at 4:36 AM
    TacomaMike37
    TacomaMike37 Well-Known Member
    13' DCLB MGM
    ^What he said.
    Engage on straight line and disengage on the turn.
  8. May 31, 2017 at 5:04 AM
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    Close enough for government work.
    *The front is an open differential so they are not trying to turn at the same time(rate/speed). No center differential is the key.
  9. May 31, 2017 at 5:09 AM
    JayRolla
    JayRolla Well-Known Member
    Colorado Springs
    Wife's 2012 DCSB Tacoma Sr5
    Trd stickers for 10whp 32s on MK6 17s
    Like stated above don't drive in 4x4 on pavement. Find a good dirt road and do it a few times a year.
  10. May 31, 2017 at 5:11 AM
    Sandman614
    Tim
    '06 SR5 Off Road
  11. May 31, 2017 at 7:59 AM
    TacomaMike37
    13' DCLB MGM
    You can drive on pavement as long as you are going straight.
  12. May 31, 2017 at 8:14 AM
    JayRolla
    Colorado Springs
    Its not worth it. Where I live most roads have turns. Drivetrain damage from dry road is a lot worse than the damage you get from not using it.
    DustStorm4x4 and azreb like this.
  13. May 31, 2017 at 12:04 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    You can get away with it for short distances occasionally. The damage is cumulative. You can drive quite a few miles on pavement in 4X4 with no apparent damage. But you are damaging components that will break sooner than they should. The more cornering you do, and the sharper the corners the quicker the damage and it is possible to have a complete failure "right now".
    My advice is not to operate in 4X4 at any time traction is good. Even in many off road situations the traction is too good to be in 4X4.
  14. May 31, 2017 at 12:10 PM
    TacomaMike37
    13' DCLB MGM
    There is a stretch by me, down near the ocean , perfectly straight for a solid 5 miles. Ill engage then to get the miles on the 4X4 components.
  15. May 31, 2017 at 12:11 PM
    Doublecross
    Doublecross Well-Known Member
    Robbie
    New york
    Work in progress
    ARE cap, wade inchannel vent visors, weathertec floor mats, ranch hand grill guard, tuffy security boxes in bed, lockable tailgate handle. Still have stuff that needs to be installed and still have stuff ordered lol.
    wide turns in 4wd
    TacomaMike37 likes this.
  16. May 31, 2017 at 1:42 PM
    Newtacoowner2016
    Thanks for all the answers! I'll just take the truck out on a back road Instead of doing it on the way to work.
    EatSleepTacos likes this.
