A question for all you manual tranmission Taco owners.
Discussion in '4 Cylinder' started by Voltare, Dec 21, 2008.
  1. Dec 21, 2008 at 5:05 PM
    Voltare
    Voltare [OP] New Member
    Hello All,
    I recently got a new job and I need a truck. My first choice is a 4-cyl manual Tacoma.
    I've been driving a VW Golf turbo diesel with a manual transmission. (44 mpg average! It gets better fuel economy than a Prius on the highway. Sorry I couldn't resist.)
    I test drove a 2009 Tacoma Access cab manual and the shifting feels clunky and stiff compared to my VW. Is this to be expected on a truck? Does this get better with age?
    Thanks for your help.
    P.S. Everyone should write an email to Toyota asking for a diesel option for the Tacoma. You get better mileage, more power at lower rpms and your engine is broken-in at 100,000 miles. Most of you already are aware of this, I'm sure.
  2. Dec 21, 2008 at 5:19 PM
    gavonder
    gavonder She's Kickass!
    Bethel, Ct
    08 TRD Sport Access Cab
    Sunroof, Leer Cap w/ Thule rack, Factory Running Boards, Fog Light Mod, Hood Struts, Scangauge, w/homemade mirror mount, AC/Defrost mod, Rear Spring TSB, TRD Center Caps
    I don't have a lot of experience with other trucks, but my earlier '99 Tacoma was definitely "clunky" compared to the sports car I came from. So, I'm assuming the new Tacomas are the same. And I doubt it gets better.
    It's not a sport sedan or car for that matter.
    GA
  3. Dec 22, 2008 at 6:36 AM
    PrezidentRedz
    PrezidentRedz Uncivilized Creations Prez
    Redz
    Owings, MD
    00 Taco 4x4 Xtra Cab, Locked and Lifted.
    Custom Everything! WHAT º¿º
    I drive a 00 Taco 4x4, I mean its no sports car trans with double snycros, but mine shifts well but does have a slight clunk. RedLine MT90 helped alot with shifting.
  4. Dec 22, 2008 at 8:21 AM
    EnolaGaia
    EnolaGaia Well-Known Member
    Midwest USA
    '01 & '04 S-Runners
    01 SR: Double Cab conversion, S/C, lowered.
    Well ... It's a pickup truck, and in my experience truck shifters have always felt heavier / stiffer / notchier than most passenger car shifters of the same time period.
  5. Dec 22, 2008 at 9:38 AM
    Roland
    Roland My other ride has sails
    Rhode Island
    06 Impulse Red I4 2WD Access Cab
    UnderCover Tonneau, Bed mat, Bug Deflector, aFe Pro Dry S, Secondary Air Filter removed, Synthetic 5W-30 oil, Scanguage II with blendmount, WeatherTech floorliners, Toyota seat covers, Installed OEM intermittent wipers, TacomaWorld sticker, Defrost without AC mod, Hidden Hitch
    Same here. It's far from the smoothest shifting transmission you'll ever drive but it gets the job done.
  6. Dec 22, 2008 at 11:25 AM
    Voltare
    Thanks, guys. Thats good to hear. I don't want to switch to automatic.
    I had a small 84' Mazda b2200 a long time ago and the shifting was clunky too. But that was my first vehicle so I had nothing to compare it to.
  7. Dec 27, 2008 at 4:32 AM
    Ry1984
    Ry1984 Well-Known Member
    From Texas, Now Miami FL
    01' ExtCab SR5 2.7 4x4
    K&N FIPK, Billy 5100 all around, 881's in the front, Toytec AAL
    damn, i thought everyone liked it rough?? :D
  8. Dec 27, 2008 at 9:07 AM
    Terrier
    Terrier Well-Known Member
    2008 SR5 Access Cab 4x4 2.7
    Mine is different from other manual vehicles I drive (old Isuzu Trooper and especially the wife's Rav4). My personal observation is that on my Tacoma there is a higher clutch engagement point than on other manuals that I drive. By the way, a Toyota Dealer mechanic who test drove my vehicle recently says the higher clutch engagment point is normal on my truck. I only have around 7,000 miles on it. My takeoff has become smoother; I think it is because I have gotten used to the higher engagment point and probably also attributable, to some degree, to break-in.
  9. Dec 27, 2008 at 9:26 AM
    tmantstud
    tmantstud High Mileage Work
    Kansas City, Kansas
    98 Tacoma high mileage
    Bed liner, Polk db651s speakers, JVC head unit, Coverking custom saddle blanket seat cover
    I agree with my 98 4cyl. there is a higher clutch engagement point, but once you find it shifting can become very smooth and almost unoticeable. I drove my brothers 99' Golf GTI and it took me awhile to get used to the lower engagement point. I found that once i was used to both vehicles the shifting was just as smooth for both of them.
  10. Dec 27, 2008 at 5:27 PM
    motoretro
    motoretro Well-Known Member
    Michigan
    09 Reg, Cab, 2.7 Four Cyl. manual trans
    I have a 09 w/ manual and definitly don't care for the high-point clutch engagement. I have not seen a service manual for 09's but I believe the 06 service manual specifies a take up point of just under 1" from floor boards with carpet removed......:confused:
    Motoretro
  11. Dec 28, 2008 at 7:11 PM
    wawireguy
    wawireguy Well-Known Member
    You just get used to it after a while. It will never be as awesome as shifting a Civic Si.
  12. Dec 29, 2008 at 9:11 PM
    darkturtleninja
    darkturtleninja 9th level dungeon master
    Illinois
    95 2.7 3rz turd
    cold air intake, body lift, suspension lift.
    i have a 95 and idk what to say...lol.... i only have to push the clutch down 2 inches to shift... it seems like the engagement point is too high... but i think my clutch is about worn out anyhow...lol... and my taco has rough written all over it...
  13. Dec 29, 2008 at 9:38 PM
    SC4333
    SC4333 Well-Known Member
    Grant
    San Antonio, TX
    2016 TRD Off-Road 4x4 DCSB - Super White
    I have not driven the golf, but did drive a VW Jetta TDI on a few occasions. I would say the 5spd in my 4cyl Tacoma is no where near as smooth as that Jetta. I would probably even use the word clunky like you did to describe it. Although with all the different manual trucks I have driven, this is pretty much expected for the most part. All and all i have been satisfied with this transmission, It just takes a little getting use to.
    EDIT: I am definitely feeling you on the diesel option. This would be killer for off roading, and towing. GM and Ford have already got with the game and are introducing them into their half-ton line ups post 2010. Dodge also said they would do the same. Or at least they were pre-recession. I wouldn't doubt if this doesn't happen being the sh*t has hit the fan for them.
  14. Jan 5, 2009 at 3:58 PM
    quicksilvertacoma
    quicksilvertacoma Well-Known Member
    Harlingen, TX.
    08 Reg. Cab Tacoma 4x4
    NA
    ive been driving a 4 banger for about 3 months now,,i definatly know what you mean about that clunk..but it seems like its normal and part of a manual truck. and a diesiel option would be awsome!
  15. Jan 5, 2009 at 4:04 PM
    Brunes
    Brunes abides.
    Rotorhead
    It's no sports car...but I dig the beefier feel.
  16. Jan 5, 2009 at 5:41 PM
    grumpchong
    grumpchong New Member
    spotswood nj
    09 access cab 4x2 5spd
    i just bought an 09 4x2 5 spd and it does feel clunkier than the dakota i've driven for the past 11 years. but nothing i can't get used to.
  17. Jan 9, 2009 at 7:24 AM
    z33tec
    z33tec Well-Known Member
    Rochester, NY
    09 4X4 Access Cab 4cyl
    I just got a 09 4x4 5 spd and for the first 200 miles or so everything felt real smooth. Now (I'm at around 325 or so) the 1st to 2nd shift seems to feel a bit notchy and clunky like it catches on something and doesn't shift into 2nd as smooth as it did before.
    Other than that it seems smooth.
  18. Jan 9, 2009 at 8:04 AM
    taconinja
    taconinja Well-Known Member
    Pittsburgh
    08 Base 4X4
    Shifting can't compare to my BMW 318ti or Mazda Miata, but it's OK. I have an '08 Regular Cab 4X4 and am happy with the mileage. I've only got 13k mi on mine but am averaging 23 mpg combined. I run AMS Oil 5W20 XL and removed the secondary air filter. I plan to get the AFE drop-in, possibly an exhaust and continue driving conservatively to maximize my mileage.
    I offset my truck with a Ninja 250 in the summer which gets 70 mpg (better than a Prius OR TDI - sorry, couldn't help myself :p).
  19. Jan 9, 2009 at 10:28 AM
    z33tec
    Rochester, NY
    Nice :) I just traded my 03 Ninja 250 in for an 08 Ninja 650 last season.
    Considering I ride my bike 8 months or so out of the year, I could have bought a truck that got 9mpg and still been better off than most :D
  20. Jan 12, 2009 at 7:39 PM
    Soundwave
    Soundwave Well-Known Member
    B.C. Canada
    2013 TRD sport Double Cab 4x4
    OEM Roof rack
    I just got my 09 4x4 Access Cab 2.7L less than a week ago. I also notice the slight notchy-ness from 1st-2nd gear. Sometimes its not there at all. But over all for a truck manual transmission its very smooth. The engagement is always higher on trucks than cars, but the Tacoma is better than most trucks ive driven with Manuals.(try a newer ranger or B-series and you will agree!) I have had 2 V6 4runners with 5 speeds befor my Tacoma and the shifting had a simular notchingness as well. Must be a Toyota Thing? I wonder if any V6 6speed Tacoma owners feel the same?
