A Question for the Experts of TacomaWorld
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 06TacomaTRD, Jul 15, 2014.
  1. Jul 15, 2014 at 6:11 AM
    06TacomaTRD
    06TacomaTRD [OP] Well-Known Member
    Brett
    South Carolina
    2011 MGM TRD OR PreRunner
    See Link --->
    I currently have Bilstein 5100 all around with the front set at 1.75 with a 1" block in the rear. I have approximately 1.75" rake (the front is at 36.25" and the rear is 38")-- the truck has no lean as the measurement is the same all around with this set up.
    I have ran this set up for a little more than a year and I love it, but the rake is starting to bother me. I am thinking of adding a 1/4" spacer on top which seems to be a somewhat popular route for the members here. To my understanding, this will lift my front around 2.25", which is about edit: (thanks jhodge83 for the correction) 1/2" higher than what it is now.
    My question is would this be enough to eliminate the excessive rake (I do not want the front higher than the rear--I am okay with a slight rake) or should I remove the block from the rear to ensure the truck will be level/have a slight rake?
    I hope this is clear, if not--just let me know.
  2. Jul 15, 2014 at 6:16 AM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    a 1/4" top plate spacer will give you a total of 1/2" of lift. that paired with your 1.75 now would be about 2.25, or 1/2" taller than currently (not 1" taller). if going that route, why not lift the shock to the 2.5" setting or put on the 1.6" eibach coils at the 1.75 setting?
  3. Jul 15, 2014 at 6:21 AM
    Tacoma VT
    Tacoma VT Well-Known Member
    R. Kessler
    Vermont
    10 DCLB TRD sport
    OME 884s, Bilstein 5100 Shocks, Icon 3 leaf progressive AAL (with overload in), Rear leaf TSB, ImMrYo mirror relocater, ARE Z series cap, Hi Lift jack W/ DIY mount, trimmed Mud Flaps, Devil Horns by Andres, EGR In-Channel rain guards, LED bed lights, Weather Techs
    If you are going to come up to 2.25" you should just get 885s for 2.5'' total.
    You could do Eibachs and have the ability to go 1.6" or 2.5".
  4. Jul 15, 2014 at 6:26 AM
    06TacomaTRD
    Brett
    South Carolina
    See Link --->
    Like Homer would say, Doh! I don't know why I said 1". Anyway, I don't want to set the shocks at 2.5" mainly because I've heard it makes it a very stiff ride and the eibach coils combined with the 1.75 would mean a new UCAs, which will be $$ that I don't have right now to spend.
  5. Jul 15, 2014 at 6:27 AM
    The_Hodge
    SC
    or eibachs at .85 would be around 2.5"
  6. Jul 15, 2014 at 6:28 AM
    Tacoma VT
    R. Kessler
    Vermont
    10 DCLB TRD sport
    885s, billies at 0 you'll be around 2.25-2.5''. Although, yes there is a 50/50 chance of needing UCAs.
    Headstrong has a great price on LR UCAs.
  7. Jul 15, 2014 at 6:34 AM
    357sig
    357sig Donut king
    dough boy
    donut shop
    Gold digger
    Or take the block out of the rear
  8. Jul 15, 2014 at 6:38 AM
    The_Hodge
    SC
    or that...
  9. Jul 15, 2014 at 6:42 AM
    06TacomaTRD
    Brett
    South Carolina
    See Link --->
    I understand that--but TacomaVT said it's a hit or miss and I don't want to spend 5-700$ at this point. I guess I'm trying to take the cheapest fix for now. I didn't think to take the block out--that might actually fix the issue.
  10. Jul 15, 2014 at 6:46 AM
    The_Hodge
    SC
    cheapest to reduce the rake would be to remove the block. to raise the front to reduce the rake, the cheapest would be 2.5" setting on the billies.
  11. Jul 15, 2014 at 6:57 AM
    06TacomaTRD
    Brett
    South Carolina
    See Link --->
    Removing the block it is as I don't want to risk a stiff ride. I will keep this thread in mind when I go bigger (which is what I intend to do once the truck is paid off) as the eibach/bilstein combo seems to be the route I want to take.
    Appreciate your help guys. Y'all are awesome.
  12. Oct 8, 2014 at 12:01 PM
    06TacomaTRD
    Brett
    South Carolina
    See Link --->
    I thought I would give you guys an update on my suspension. I decided to buy two 1/4 spacers to give my front end a total of 2.25" lift. I went this route because I plan to go a full 3 inches once the truck is paid off and from what I've read, the 1/4" spacers come in handy in giving you the full 3" with the ~2.5" you get with the Bilstein/coil combo. It sits pretty level (front is about 1 1/4" lower than the rear).
    For reference:
