A Question for the Experts!
Discussion in 'Suspension' started by Tacorriendo, Jul 19, 2015.
  1. Jul 19, 2015 at 6:23 PM
    Tacorriendo
    Tacorriendo [OP] Well-Known Member
    Fred
    Texas
    2009 DCSB 4x4 Off-Road
    Front lift, ride rite air bags, side steps, rear camera switch.
    After about a year, I feel that finally my lift has settled. I have a 2009 Tacoma DCSB 4x4 Off-Road TRD SR5 with 16" original wheels and Toyo Open Country H/T 265/70/16. The only extra weight I have right now, is a brush guard and a "Back Rack". My lift setup, is: EMU 885's with Bilsteins 5100's up front @ 0, and a 1/2" spacer on the drivers side. On the back, I'm running Bilsteins 5100XL's, Skyjacker leaf packs with no blocks and air ride bags with my own version of "daystar craddles" for the bags. As of right now, these are my measurements from mid-hub to fender edge:
    Front Left(driver side)= 22 1/4"
    Front Right(pass side)= 22 3/4"
    Rear Left = 23 7/8"
    Rear Right = 24 1/4"
    According to my calculations, to bring it back to a 3" lift on the front, I have two options:
    1.- I put a 1" spacer on the driver side and a 1/2" spacer on the passenger side for the front.
    2.- I set the struts on the second setting.
    There are two reasons that deter me from setting the struts on the second ring. the fact that it is NOT recomended, and the fear to get a stiff ride (right now it drives smoother than stock).
    The question is: What is the best route to take on this?
  2. Nov 17, 2015 at 8:13 AM
    BDF Yoda
    BDF Yoda Member
    Brian
    Richmond, Virginia
    2011 TRD Sport, Double Cab, Long bed
    Bilstein 5100's x4 w/fronts set at .85", LoPro QT Tonneau cover, Weather Tech floor mats
    Sorry I don't have a reply for you, but I do have a question. How do you like your lift set up? I'm looking at almost that exact same set up. How do those Skyjacker leaf packs ride with the 5100's?
  3. Nov 17, 2015 at 9:18 AM
    Tacorriendo
    Fred
    Texas
    I like the smooth but sturdy ride that it offers. I will be honest though the XL5100's I believe it limits down travel due to the longer shock, since I ended up not putting the blocks. Those shocks are recommended for 3-4in lift. I ended up putting longer studs on the driver side and going with a 3/4" plate. I ended with exactly 3" lift on the driver side and 3 1/4" on the passenger side with no plate at all.
  4. Nov 17, 2015 at 11:21 AM
    BDF Yoda
    BDF Yoda Member
    Brian
    Richmond, Virginia
    On the rear leafs, that's exactly what I'm looking for. I already have the regular 5100's on the rear, so I would plan to stick with them (I think they are good for up to 2" of lift, I hope so, b/c I really don't feel like buying new rear shocks).
    Is that the front you're referring to? I only want about 2" of lift on the rear, which is what those leaf packs are advertised as.
  5. Nov 17, 2015 at 11:22 AM
    BDF Yoda
    BDF Yoda Member
    Brian
    Richmond, Virginia
    Also, thanks a lot for your reply. Much appreciated.
  6. Nov 21, 2015 at 6:39 AM
    Tacorriendo
    Fred
    Texas
    on the rear, It measures 24" from center hub to fender after settling. So with 23" infront and 24" on the back, there is a still little bit of rack, but not noticeable; it looks pretty leveled.
  7. Nov 22, 2015 at 9:15 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    Well you def. don't want to bump the adjustment clip up a groove, waaay too much preload & it will ride like shit, no fan of any kind of spacer but I guess you could do it without too much complaining from suspension, or maybe new coils....that's all I got for ya dude...
