A question of power between 05 and later taco's
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Tgor, Aug 3, 2010.
  1. Aug 3, 2010 at 7:31 PM
    Tgor
    Tgor [OP] Well-Known Member
    Todd
    Florence,KY
    2011 TRD Double Cab L/B Mag Grey
    WeatherTech digi-fit floor mats, vent visiors, coming soon: Satoshi mod :-)
    Ok so I am looking to make a purchase soon on a 05 or newer tacoma with the 4.0L. I was doing some model research at edmunds.com when I read that...
    "What's New for 2006 For 2006, a tire-pressure monitor is now standard on all Tacomas. Revised SAE testing procedures have dropped horsepower and torque ratings."
    So I looked back at the 05' and is says it has 245hp and 283lb-ft or torque. The 06' and later show 236hp and 266lb-ft of torque.
    My question is: Was Toyota generous with the numbers they gave? or is there a significant power change between model years?
    Also has anyone used one of those 'bully dog' or the like; chips for their Toyota? I hear they make 'em for Gas engines but has anyone tried it out?
    BTW I am hoping to get an extended cab 6cyl with 6-speed manual.
    Thanks.:)
  2. Aug 3, 2010 at 7:33 PM
    tacomaman06
    Will
    York,South Carolina
    '16 Tundra TRD Pro
    getting there....
    welcome to tw. toyota didnt change anything horsepower wise with the 4.0.......i think it had to do with tests with different fuels and such.
  3. Aug 3, 2010 at 7:36 PM
    MxRacer190
    MxRacer190 Well-Known Member
    Georgia
    06 SR5 4x4 Indigo
    W/e the horsepower and torque... These 4.0's are fast a hell.
  4. Aug 3, 2010 at 7:38 PM
    tacobell007
    tacobell007 Does that have the v6?
    Drew
    Westfield, MA
    06 Regular Cab Lifted
    Eibach springs, OME Dakars, adjustable Bilstien 5100's up front, Icon ext travel rear shocks, Kenwood in-dash nav receiver, Kicker 10 inch sub in a ported truck box, Kenwood 350 watt amp, stickers, Better Built toolbox, LED tool box lights, 35% tint, Flowmaster Super 44 muffler, 33x12.5x17 General Grabber AT2, Fuel Off-Road Trophy d551 in 17x8.5, BHLM, white corner marker bulbs, color matched front grille, custom satoshi grille mod with matching Toyota badge, aFe Pro Dry-S drop in filter, diff breather mod, new frame from recall, SOS concepts front plate, SOS concepts rear plate with swing out and full size spare, SOS bolt-on sliders with kickout, 20" LED bar on main hoop, flush mount pods in rear plate bumper for aux reverse lights
    x2
  5. Aug 3, 2010 at 7:45 PM
    NMG
    NMG Well-Known Member
    Ottawa
    09 Double Cab TRD Sport
    x3 :D
  6. Aug 3, 2010 at 8:00 PM
    jandrews
    jandrews Carolina Alliance Southwest Region Ambassador
    '09 FourDubDee TRD OR
    There is no power difference between the 05 and newer models. The SAE changed the way engines were tested and rated, resulting in a drop in numbers. The engine did not change.
    FWIW, on 91 octane or higher the 1GR-FE is rated at 239hp and 278ft/lb of torque.
    The 4.0L is an adequate engine for these trucks. It is not "fast as hell" but it is exceptionally pleasant to drive with torque down low for hauling, towing, and crawling.
    Please do not waste your money on some Chinese-made engine chip scam on ebay. They do nothing except put your expensive and exceptionally well-engineered motor at risk.
  7. Aug 3, 2010 at 8:07 PM
    Clelsdah
    Clelsdah Western Alliance: Yeehaw Division
    No California Foothills
    08 SR5 4x4
    Bed mat, tube steps, Ipod interface, Ride-rite air springs
    I have a 05 4Runner and an 08 Tacoma both have the 4.0. They are equally responsive when I put my foot into them. Only difference is the 4 runner gets 4-5 more miles per gallon.
  8. Aug 3, 2010 at 8:27 PM
    MontanaTaco
    MontanaTaco Well-Known Member
    Colter
    Relocated to Albany, NY
    14 DCLB Sport
    OME lift
    I wouldn't chip your truck.
  9. Aug 4, 2010 at 9:17 AM
    Tgor
    Todd
    Florence,KY
    Thanks for your responses. I was hoping that I didn't have to scout out a 05' I am wanting something newer.
    As far as the chips though I am familiar with those cheap ebay units that connect to your air temp sensor and nothing like that would end up on any of my vehicles.
    the reason I asked was that I had watched something the other day on Speed TV called Truck U where they were using a chip on Gas engine. It had a LCD screen where you would enter numbers into different prompts to change things like the rev limiter/ speed limiter / speedo ratio for different tire size and such.
    Hey Thanks again
  10. Aug 4, 2010 at 10:08 AM
    spenny
    spenny Mmm... Beer
    BC, Canada
    '06 TRD Acc. Cab
    Stock
    Dont chip; tune. Tuning devices/software is pretty expensive, but well worth it if you're looking for power and reliability.
    The only device I've ever found is this: http://www.aprpower.com/ECU_mainpage.html
    Buy that and go to a reputable tuner near you, and get a custom tune for your elevation/octane/performance parts/etc..
  11. Aug 4, 2010 at 11:02 AM
    ktmrider
    ktmrider Senior Member
    07 DCLB 4x4 Sport S/C
    Junk
    ^ thats good or you can buy japanese made superchargers that will make everything better.
  12. Aug 4, 2010 at 2:42 PM
    Tgor
    Todd
    Florence,KY
    ah yes the supercharger...Definitely on my to do list.
  13. Aug 4, 2010 at 2:47 PM
    achirdo
    achirdo I Weld!
    Adam
    North DFW
    06 dodge ram 3500 5.9 cummins
    x4. raced my friends 09 dodge ram(new body style) 5.7l v8 hemi. i was just as fast as he was. we where dead even for a 1/4 mi. these tacos can run:D
