A question or two before I do my first 3rd gen oil change.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by aficianado, Nov 9, 2023.
  1. Nov 12, 2023 at 8:51 AM
    #41
    aficianado
    aficianado [OP] Well-Known Member
    bay area, california
    2006 access cab. 4x4, TRD-OR + 2023 TRD off-road.
    back to bone stock.
    I think a cut up quart bottle will thread into the filler neck. it does on my 2006. it wouldn't be me, if I didn't try it first before I went and bought something. I have an awesome funnel, I never use on my 2006. I pour the first quart and thread it down while it drains. then a quick swipe of a utility knife to knock off the top and poof. free funnel, threaded on. I gotta try.
    and I have a clear silicon hose that pushed over the crappy OEM things.
    rsimi72 likes this.
  2. Nov 14, 2023 at 5:38 AM
    #42
    aficianado
    back to bone stock.
    You all do anything with that retainer tab poking off the side if the housing cap?
  3. Nov 14, 2023 at 6:00 AM
    #43
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    In most videos they seem to just ignore it. I slide it off before removal and back on after, but I don't think you have to.
    kahanabob likes this.
  4. Nov 14, 2023 at 6:20 AM
    #44
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Are you talking about this?
    This seems like it would need to be torqued more to get the clip touching the straight portion but MAN, was it a bear to twist off!
    Irons likes this.
  5. Nov 14, 2023 at 6:31 AM
    #45
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    I don't use a funnel anymore. I use a graduated dispenser. It helps for those 6 quart changes when you're buying 5 quart containers.
    Irons, shakerhood and axnjackson like this.
  6. Nov 14, 2023 at 8:48 AM
    #46
    aficianado
    back to bone stock.
    yup. that!
    at first glance I thought that was what held the housing in place when you torqued off the bottom cap. no so sure, especially after seeing your photos.
  7. Nov 14, 2023 at 8:50 AM
    #47
    aficianado
    back to bone stock.
    badass. I had one of those OG ones. the galvanized can with the flex hose coming off the bottom. I grabbed it when a gas station went tits-up. lost it in the move to CA.
    but genius, bud. genius.
    Ngneer likes this.
  8. Nov 14, 2023 at 10:55 AM
    #48
    faawrenchbndr
    faawrenchbndr Til Valhalla
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    so let me get this straight. You pour oil from a container, into a container that has a funnel spout, to avoid using a funnel?
  9. Nov 14, 2023 at 10:56 AM
    #49
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    I still haven’t been able to completely figure out what the damn little clip is supposed to do.
  10. Nov 14, 2023 at 11:02 AM
    #50
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    Not at all. I pour oil from two containers into a container that has a funnel spout.
    The funnel is ancillary, it mainly helps in measuring out a hair over 6 quarts.
    So for example, I have a 5 quart container that is sitting on my shelf, and it has three quarts remaining. Next oil change I'm going to buy another five quart container. I pour the entirety of the old container into the jug, and then I open the new container and keep adding until I reach my fill line. Boom. And then I can dump that all over my engine and not worry about it.
    Irons, shakerhood, Toyko Joe and 3 others like this.
  11. Nov 14, 2023 at 12:34 PM
    #51
    Barsoom
    Barsoom Well-Known Member
    NW GA OTP
    Toyota takes care of tire rotation every 5K miles, oil change once a year or every 10K miles. Toyota Care service is good for 2 years.
    In my case, dealer stripped and lost hex screw on the crash plate on the first oil change. And did not tell me about it. I caught because I always check the car over after service (on my other cars I've had dealers leave off air intake after doing transmission service, overfill oil by a full quart, leave off the engine covers). Dealer ended up order the whole crash plate install kit, with spacer and all bolts, to give me the missing oil door screw.
    Next week I am taking Taco for it second oil service and tire rotation (9K miles on the clock, drive 2 cars) to a different dealer, before Toyota care expires in December.
    Will replace plastic housing with aluminum one (did the same on wife's RAV4) on the 3rd oil change and install the Fumoto valve.
  12. Nov 14, 2023 at 12:41 PM
    #52
    Barsoom
    NW GA OTP
    On the RAV it interferes with filter housing being taken off (hits the rib) and I have to hold it back for a couple of turns. I think of it as a retainer clip.
    faawrenchbndr likes this.
  13. Nov 14, 2023 at 6:36 PM
    #53
    rsimi72
    rsimi72 Well-Known Member
    PNW
    2020 Tacoma SR5 Access Cab
    Good question. I guess I just ignore that little tab. Hasn’t seemed to make any difference. :notsure:
  14. Nov 15, 2023 at 7:31 AM
    #54
    faawrenchbndr
    Greg
    Denver, Indiana
    ‘23 Sport 4x4 DCSB
    Ok…….what ever works for you.
    :rofl:
  15. Nov 15, 2023 at 8:43 AM
    #55
    aficianado
    back to bone stock.
    its a sound plan. i like it. until they make a 6-quart jug, it will take 5 jugs to "Run out".
    i bought one jug and one $9 quart.
  16. Nov 15, 2023 at 9:45 AM
    #56
    Taco_mike73
    Taco_mike73 Well-Known Member
    York, PA
    2020 Cement SR5 DCSB 4x4
    Lomax tonneau cover, oem bed lights, AJT Design chrome delete, black out badges & tailgate letters, AVS hood deflector & vent visors, Solkie tech hood supports, interior LED lights, Tufskinz mud guards, RedArc TowPro Liberty, bed mat, kicker speaker upgrade, Hikari ultra H11 low beams, Diode Dynamics SS3 fogs in yellow, Meso customs total taillight stage 1. Coming soon: Compact powered sub install Future mods planned: bigger tires (265/75/16) BILLSTIEN 5100 lift
    The filter drain cap should come off easy. It's supposed to be less torque than the whole filter. mine will turn the entire filter cover since the last Toyota care service. the dealers often over tighten stuff. it took a 24" breaker bar to get my filter off. I had to just open it full of oil, it makes a bit of a mess but you do what you need to do.
    MotivX tools are good especially the cap wrench. I don't like the funnel too much. Its at a weird angle the way the oil filler is on the tacoma I find you have to be careful not to spill oil. I prefer a big funnel from harbor freight more
  17. Nov 15, 2023 at 10:39 AM
    #57
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    i don't know what it is for and don't pay attention to it. i just change the filter and move on.
    Taco_mike73 likes this.
  18. Nov 17, 2023 at 7:52 AM
    #58
    aficianado
    back to bone stock.
    gah...slow delivery!!
  19. Nov 17, 2023 at 1:54 PM
    #59
    Irons
    Irons Outlaw Prospector
    NW Michigan USA
    '22 TRD Sport AC MT Army Green
    TRD lift, Exhaust & CAI
    I use one too, I get the 12 quart boxes of 0w20 that have a bag in them. My OCD appreciates seeing the oil hit the 3 quart line before I pour it in. Twice.
    Barsoom and Rock Lobster[QUOTED] like this.
  20. Nov 17, 2023 at 2:31 PM
    #60
    4runnerToTacoma
    4runnerToTacoma Well-Known Member
    22 SR5 V6 Taco, 03 SR5 V6 4runner
    When are we going to get oil thread marked?
