A. R. B. Front bumper brackets???
Discussion in '2nd Gen. Tacomas (2005-2015)' started by BOSSHOSS, Jan 11, 2020.
  1. Jan 11, 2020 at 8:21 PM
    Millerfish
    Millerfish Well-Known Member
    Southern Ca
    14 DC SB OR
    I've installed these bumpers and there is a lot of parts and pieces between the bumper and the frame.
  2. Jan 11, 2020 at 8:30 PM
    gravyboat
    gravyboat Well-Known Member
    Jon
    Olympia
    These are the @Baja Designs Squadron Sports in amber, but not the newly released DOT versions so I only run these when I am on my road by myself. Paired up with a @paranoid56 bracket to mount in the bumper housing. :thumbsup:
    llamasmurf and paranoid56 like this.
  3. Jan 11, 2020 at 8:46 PM
    4xdog
    4xdog Well-Known Member
    Santa Fe, NM
    03 DC TRD OR, 15 DC TRD OR, 08 RX350, 62 TR3B
    Thanks, @PugetSoundTaco.
    ARB in April 2019 released LED conversions for their bullbar-mounted foglights, both small and large sizes. The color temperature of them is 6000K though, and were I to make a change I’d rather go amber not stongly blue-white.
    https://arbusa.com/led-fog-light/
  4. Jan 11, 2020 at 8:49 PM
    gravyboat
    Jon
    Olympia
    Oh neat, I didn’t know they went LED with the fogs, I know they have an LED signal and DTR combo. I do really like my Baja’s tho. Haven’t had any issues with them. Pipe dream would be either a pair of LP9’s or 6’s on the bumper. Not a need tho.
  5. Jan 12, 2020 at 4:44 AM
    BOSSHOSS
    BOSSHOSS [OP] Active Member
    Yes. But what knowledge do you have for that price range? Have you needed the mounting kit?
  6. Jan 12, 2020 at 6:38 AM
    4xdog
    Santa Fe, NM
    I'm not sure ARB's mounting kit will include the big brackets, and for sure it won't include the splash shield (if you want to use one). The mounting kits I've had have been a bag full of nuts, bolts, washers, and winch/license plate brackets.
    You'll need to check on the essential bits your install will need. It's going to cost something, yes, but you'll probably still be OK vs new if you got into the original bullbar reasonably enough.
    BOSSHOSS[OP] likes this.
  7. Jan 12, 2020 at 1:10 PM
    Crikeymike
    Crikeymike ExitOffroad.com Vendor
    Jax Beach, Florida
    They get about $400-500 for a full mounting kit. What you're missing isn't cheap.
    Why didn't it come with all the parts? There's one box that comes with it that includes everything
    llamasmurf and Grey 2015 like this.
  8. Jan 13, 2020 at 2:59 PM
    BOSSHOSS
    You're spot on buddy. $447 for the kit according to ARB U. S. A. I'm sitting right. All hardware, bracket, bumpers, lights in that kit. Quick search online found it for 419. Very happy so far.
    Also discovered there is a piece of steel welded on the left downtube, inside the bumper. It is stamped with the actual model number. I got lucky cause this one is for my 09 Tacoma.
  9. Jan 18, 2020 at 4:14 AM
    TacoVic90
    TacoVic90 Member
    15 Taco/03 Crown Vic
    SOS sliders and a hand made wooden canoe rack
    Has anyone tried these out yet? in another post @crashnburn80 has made some good points against their projected function as fogs. Any hands on experience yet?
    llamasmurf likes this.
  10. Jan 19, 2020 at 7:32 PM
    SpeedwayTaco160
    SpeedwayTaco160 Well-Known Member
    Killeen TX
    10 Sport SWB DCSB
    Wish I would have seen your post. I literally gave an extra mounting bracket I had away. My bracket was slightly bent from ARB so they sent me another one.
  11. Jan 20, 2020 at 6:01 AM
    BOSSHOSS
    Yeah I wish you would have too! Lol. Did you order the kit or the entire bumper?
  12. Jan 20, 2020 at 9:29 AM
    SpeedwayTaco160
    Killeen TX
    10 Sport SWB DCSB
    I ordered the entire bumper
    BOSSHOSS[QUOTED][OP] likes this.
  13. Jan 20, 2020 at 9:38 AM
    BOSSHOSS
    I ordered the kit today for just a little more than $400. I'm sitting right and saved some jack, but got lucky
  14. Oct 2, 2020 at 11:16 AM
    Mack83
    Mack83 Well-Known Member
    Orlando
    2014 TRD OR DCSB Silver Streak Mica
    OP, can you tell where you ended up kitting your kit? I might be in the same situation soon.
