A.R.E. DCU 29” Camper build
Discussion in 'Tonneau Covers, Caps and Shells' started by Joeyourbro, Dec 14, 2021.
  1. Dec 18, 2022 at 2:15 PM
    #41
    Joeyourbro
    Joeyourbro [OP] Well-Known Member
    Joe
    Vegas
    2015 2.7 5MT
    Camper is for sale for anyone interested. Looking into getting a cheap van and possibly selling the Tacoma. Located in Las Vegas
  2. Jan 1, 2023 at 7:43 AM
    #42
    Brex69
    Brex69 Well-Known Member
    2023 Lunar Rock DC LB Off Road
    Are those side mounted tool boxes/shelves that come with these DCU caps welded in or bolted? Are they easily removed?
  3. Jan 11, 2023 at 10:23 PM
    #43
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    On my ARE DCU cap -- on a 2014 Tacoma Access Cab -- ordered/installed in mid 2022, the tool box/shelf unit is bolted (or rather screwed) in. It's pretty thin sheet metal, mostly, and is held together with copious amts of self-tapping screws.
    Brex69[QUOTED] likes this.
  4. Jan 11, 2023 at 10:41 PM
    #44
    Brex69
    The one on mine was all rivets, drilled them all and had it out in 30 min.
  5. Jan 11, 2023 at 10:44 PM
    #45
    GilbertOz
    GilbertOz Driver
    CA
    Right, I stand corrected, on second thought it's a combination of self-tappers and rivets.
  6. Jan 12, 2023 at 2:33 PM
    #46
    Joeyourbro
    Joe
    Vegas
    2015 2.7 5MT
    Mine is also a combination of rivets and self tappers. The rivets up top are covered by trim and paneling now on mine.. Considering removing the last section of lower shelf on mine if it doesn’t sell.
    Brex69 likes this.
  7. Jan 14, 2023 at 12:29 PM
    #47
    Bajatacoma
    Bajatacoma Well-Known Member
    SC
    05 TRD Off-Road, SR5, 6 speed
    The ones we had on our rescue trucks would start getting loose and the maintenance shop tried larger screws or replacing rivets but eventually went to rewelding (and often adding a reinforcing plate) and replacing the screws with Rivnuts and bolts with washers. Make sure the rear door seals are maintained- as they wear they allow the doors to rattle more and the hinges start getting loose.
    I like the DCUs but they are not well built in my experience, especially if you load them up with heavier stuff and/or use them on rough roads.
    Brex69 likes this.
  8. Jan 14, 2023 at 4:39 PM
    #48
    Joeyourbro
    Joe
    Vegas
    2015 2.7 5MT
    So far so good. I have all new seals on the doors so that’s nice and tight. Any future wear isn’t anything I don’t think an aluminum welder could fix for me :thumbsup:
  9. Jan 14, 2023 at 4:48 PM
    #49
    GilbertOz
    GilbertOz Driver
    CA
    I think aluminum welding has probably gotten considerably more available/accessible w/ more modern mig welding equipment. Esp. w/ the latest pulsed-spray mode MiG, which is now widely available to small/local welding businesses in the form of inexpensive inverter-based welders.
    I had an ARE DCU on my '99 Taco RWD when I lived in the city; it was excellent there.
    I got a brand-new ARE DCU built for my '14 Taco 4WD OR. Good so far (no leaks in first winter rainy season,) but I haven't taken it off road much. I can see how frequent rough/off-road use might take a toll on it w/ all the flexing & bouncing.
    ARE does offer a new "diamond-plate aluminum" siding option, approx double the standard wall/roof metal gauge thickness. Probably holds up better to rough use but I took a pass on that to save up-front cost & of course weight.
    Joeyourbro[OP] likes this.
  10. Jan 17, 2023 at 5:03 PM
    #50
    Joeyourbro
    Joe
    Vegas
    2015 2.7 5MT
    Camper has been sold! Enjoyed building it and documenting it here.
    Planning on keeping the tacoma and getting a cheap van for a road trip rig.
    Ngneer likes this.
  11. Feb 26, 2023 at 7:44 AM
    #51
    Brex69
    I used those same panels in post #8 for my carpet headliner backing and they bowed and warped from humidity during this last rain storm. You have that problem when you had yours? I should have hit them with oil based paint before I installed.
  12. Feb 27, 2023 at 4:36 PM
    #52
    Joeyourbro
    Joe
    Vegas
    2015 2.7 5MT
    I had the doors open in the rain for a bit, which ruined them, but the two panels I kept were fine a whole NJ summer and up until I sold it
    Ngneer likes this.
