A.R.E. hard tonneau cover leak help
Discussion in 'Tonneau Covers, Caps and Shells' started by zeus7625, Jun 25, 2011.
  1. Jun 25, 2011 at 4:37 PM
    zeus7625
    zeus7625 [OP] Member
    Zeus
    Daphne, AL
    PreRunner TRD SR5
    A.R.E. LSII tonneau cover
    Had to drive 35 miles (one way) to the Authorized Dealer to order the cover. Again to install the cover, and then again to deal with leaks. The cover is only 6 months old and has been leaking since install.
    The leaks are at the very front corner on both sides. I can see where they were generous with the sealant (looks like RTV) but it still leaks.
    Can anybody help with an at home fix, instead of driving 35 miles and dropping 3 hours in a customer lounge?
    All I can get from the website is installation instructions.
  2. Jun 25, 2011 at 4:58 PM
    redezman
    redezman Well-Known Member
    Charles
    Raleigh N.C
    2012 4Runner SR5 4x4
    All Factory for now, LOVE it that way
    mine does same thing, tho mnot bad, BUT still i can notice it.
    first time it happened they pulled the cover off and put thicker rubber BUT still leaked.
    Most of ones i see have a little seepage to them.
  3. Jun 25, 2011 at 8:59 PM
    joes06tacoma
    Joe
    Central Coast, CA
    When I had my shell installed, the dealer used some kind of putty between the plastic bed rails and the front panel of the bed. The shell then sits directly on top of the putty. It leaked. What I finally had to do is apply rtv silicone to the leading edge of the plastic bed rails where they meet the bed sides. The water was traveling under the plastic rails and into the bed. No leaks since I added the silicone.
  4. Jun 26, 2011 at 3:56 AM
    zeus7625
    Zeus
    Daphne, AL
    PreRunner TRD SR5
    Thanks for the replies. I can see now that my problem is not uncommon.
    I'll try the rtv idea.
  5. Jun 26, 2011 at 3:59 AM
    zeus7625
    Zeus
    Daphne, AL
    PreRunner TRD SR5
    Where was the water entering the bed? Along the bed rails or at the front corners of the bed?
