A REAL Bumper (come at me, Bro!)
Discussion in 'Armor' started by Mavigogun, May 18, 2023.
  1. May 30, 2023 at 8:34 AM
    Mavigogun
    Mavigogun [OP] Well-Known Member
    1998 Tacoma X-Cab SR 5 2.4L L4 SOHC 16V
    That's the plan- I very much want the plank to UV bleach and grain to become more pronounced; my first impulse was to employ a surplus rail-road tie. As for water, the plank will receive periodic refreshment of tongue oil.
    wayupnort and mic_sierra like this.
  2. May 30, 2023 at 8:35 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    6011 is similar to 6010 in that it would be used as a root pass.
    7018 is not only easier to lay down, but also stronger. You would've had that nice bead profile with 7018 as well.
    Fortunately your lacrosse balls would absorb whatever impact you receive from the neighbor's Huffy, but that 6011 is brittle compared to 7018.
  3. May 30, 2023 at 8:40 AM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    K
    Freshness applies to ability. The more you practice the better your welds, and based on the boogers on that bumper I'd have to make a pretty educated guess.
    Idk if you know what physics are, but a big heavy cantilever on two very small pieces of stamped steel doesn't make for a very good base for a receiver hitch.
    Didn't you say you got hit several times in the rear end? What happened to the factory frame horns? Oh that's right, they became the hinge in your fulcrum. But previously you didn't have a massive block of aluminum hanging off them. You slam on the brakes with a loaded down trailer behind you and it's going to be the same situation. Brake Biased is towards the front, so the ass is going to hike up, meaning all the momentum is transferred non-linearly into your big bumper, folding those little frame horns right up. But what do I know. :notsure: I wouldn't trailer anything behind that more than 2k lbs total. It's practically bumper tow rated.
    CygnusX191 likes this.
  4. May 30, 2023 at 8:44 AM
    Mavigogun
    The bumper brackets are necessarily designed to fail before the vehicle's body frame. Regarding the bracket mounts to the body frame, we see the bolt receptacles are slots- before the bracket is taxed to failure, the clamping force of those bolts must be overcome before the assembly is pushed back far enough to bear directly on the frame. The elastomer bumpers just add another layer of progressive compression to that sandwich. As with mitigating the damage of any impact, lengthening the rate of deceleration and targeted absorption is key.
  5. May 30, 2023 at 8:56 AM
    Slashaar
    Josh
    Kansas City, MO
    As you say, they are designed to crumple, not hold a dynamic load. You previously compare it to 'higher capacity models' but fail to realize that the class III receiver hitch on those are attached to the frame, not those brackets.
  6. May 30, 2023 at 8:57 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Waiting for his argument that his bumper and hitch are one integral piece :rofl:
    Those welds tho :bananadead:
    CassND, TS4x4, AllTacosFloat and 2 others like this.
  7. May 30, 2023 at 9:01 AM
    Slashaar
    Josh
    Kansas City, MO
    All he'd have to do is add some thicker brackets to the frame where the factory receiver bolts in and I'd walk away. Don't want this guy folding his truck up pulling more than those brackets can handle and flipping on the interstate and killing someone.
    I also don't think I'd trust aluminum over steel personally for a receiver. Though I'm not sure if there are aftermarket hitch bumpers in aluminum flavor. So I can't argue that point without knowing. EDIT: Looks like Coastal offers the 2" receiver on their aluminum kit. :notsure:
  8. May 30, 2023 at 9:07 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    I completely missed the part about aluminum being used; my eyes were elsewhere :anonymous:
  9. May 30, 2023 at 9:09 AM
    fellow_expert
    fellow_expert Well-Known Member
    2019 Midnight Black SR5 4x4
    Looks like metal termites got to it. Idk how I'd feel about running a bumper like this personally...
  10. May 30, 2023 at 9:21 AM
    Mavigogun
    Hummm... starting with another provocation. This bodes well. Let's see-
    The drop and moment arm from the trailer wheel base to the bumper brackets is the same as the stock bumper.
    "Aluminum"? You're confused- there was no mention of "aluminum". Maybe my typo of "6011" instead of "7011" for the stick put that in your head.
    It's not intended to exceed the capacity of the stock bumper and brackets on this vehicle- the receiver tube was used not to increase the capacity, but to allow the bumper to present a uniform face for the plank, without a cut-out for an inset ball, when the drop is not in use.
    I have no interest in thicker brackets- I'd much rather the brackets fail as designed, as they are easy to replace, as opposed to the body frame, which is not.
    No aluminum here.
  11. May 30, 2023 at 9:27 AM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Focusing on structural integrity, without getting into the specifics of where supports are used or the overall layout of your bumper...you still used the wrong rod :burp:
    Even a crash course in AWS structural code will teach ya that
  12. May 30, 2023 at 9:33 AM
    Mavigogun
    I pumped too much heat in too short a period when attaching gussets to the opened tubing, causing the "webbing" between to warp; consequently, when re-attaching the quarter section of tubing to the back, there were progressive gaps. I wanted to see if I could bridge those gaps, rather than repair the deformation- again, familiarizing myself with what is possible with stick welding. Bridging the minor gap wasn't difficult, and I was able to hit it front and back, but attempting to produce a smooth transition with filler welding was a mistake, and proved to be more time consuming than I cared to dedicate, abandoning endless grinding and touch up spot welds for the sake of esthetics. I could have hid the ugly with a filler, but preferred to be reminded of what I learned.
  13. May 30, 2023 at 9:46 AM
    Mavigogun
    The wrong key, maybe- I typed "6011" instead of "7011" -and if you re-read, I wrote "almost exclusively": 7018 was used for the fill on critical elements, such as the receiver tube and the quarter inch gussets receiving the bumper brackets. That said, I wouldn't make a habit of using stick for welding that required heavy fillets, as the risk of incorporating glass into the weld is too high- for me, anyway; I'm sure there are pros for whom it ain't such an issue. It was fun to try my hand at MIG after all this stick- So. Very. Easy.
  14. May 30, 2023 at 9:50 AM
    Toyoda213
    Toyoda213 Well-Known Member
    Jimmy
    SoCal
    2003 V6 dlbc Prerunner 4x4 converted
    Im not sure what im looking at here but interesting
  15. May 30, 2023 at 9:51 AM
    #35
    Kwikvette
    Fresno County
    4 run, 2 don't
    Fair to say you've been a victim to some of these lacrosse balls that made their way outside the playing field? :rofl:
  16. May 30, 2023 at 11:54 AM
    #36
    Clearwater Bill
    Billy
    Largo Florida
    An option to draw a different level of attention would be to remove the wood. Grind and bed line the metal under structure.
    Put white LEDs across the bottom holes tied to the reverse circuit. Red LEDs in the rest of the holes tied to the brake circuit. Cover the face with a thin layer of smoked plexi to obscure the lights when not in use.
  17. May 30, 2023 at 11:58 AM
    #37
    PiryongS
    PiryongS Well-Known Member
    Jeff Foxworthy enters the chat :D
    ToyoTaco25, TS4x4, CygnusX191 and 2 others like this.
  18. May 30, 2023 at 12:04 PM
    #38
    AllTacosFloat
    AllTacosFloat If yours sank you’re entitled to compensation
    Boston ish
    Has lockers a skewp and a bit of droop
    Nope, that was before our meeting. Post meeting we agree we have seen some shit…truth is yours qualifies as shit, it’s a hack job from start to finish. It doesn’t fit the bill for form or function. Might help with birth control tho.
    Looks like something my 9 year old would make from Legos. Maybe add a spring and call it a diving board?
    Looking at a real tow hitch made for the truck you’re missing like 6 or 8 bolts. So yeah, unsafe at best.
    Don’t make a post “ come at me bro “ then get all butt hurt when we tell you what we think of your abortion clinic.
  19. May 30, 2023 at 12:05 PM
    #39
    LiquidArrogance
    LiquidArrogance Well-Known Member
    Streets of Bakersfield
    2021 SSM Sport 4x4
    But can we all stop arguing and take a moment to just appreciate this sentence?
    landphil, TS4x4, Slashaar and 2 others like this.
  20. May 30, 2023 at 12:06 PM
    #40
    OffroadToy
    OffroadToy kokanee smoker
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
