A Reason Not To Run LED Headlights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by hiPSI, Jan 31, 2018.
  1. Jan 31, 2018 at 4:21 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly a 1998 SR5 PU, 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
  2. Jan 31, 2018 at 4:22 PM
    Old n' slow
    Old n' slow Well-Known Member
    Oak Island, N.C.
    2000 Tacoma 2.4 5 speed flare side
    Just a thought......I wonder if silicone wax or something similar on the lens would help, since LED's run so cool it wouldn't burn it off.
  3. Jan 31, 2018 at 4:22 PM
    OnHartung'sRoad
    Drop one of those in your coolant bottle, that’ll do the frosty windshield too.
  4. Jan 31, 2018 at 4:24 PM
    brich999
    brich999 Well-Known Member
    Bryan
    16 Tacoma TRD Sport AC
    all tore up already
    Run yellow halogen fogs. If it's snowing to the point my headlights are icing, I'm probably running mostly on fogs anyways. Yellow Piaa are amazing for ice and snow
    OnHartung'sRoad likes this.
  5. Jan 31, 2018 at 4:35 PM
    OnHartung'sRoad
    That would probably work, a lot of people on other forums about LEDs icing up use Pam spray, wd40, etc., and say those work too.
  6. Jan 31, 2018 at 6:27 PM
    DES2009
    DES2009 Minister of Truth
    Southeast Louisiana
    2017 MGM Limited
    I'm a Millionaire! One Million Posts!!
    Fear the Frog!
    1bad2k[QUOTED] likes this.
  7. Jan 31, 2018 at 6:39 PM
    shr133
    shr133 Well-Known Member
    Muskego, WI
    2010 V6 Sport
    K & N filter, 275 70 17 Cooper AT3, OME Nitrocharger shocks, 884 Springs, Dakar leafs.
    Yeah you have to keep cleaning your headlights with LEDs.
    I also run covers on my rigid spotlights so they don't ice up and can be cleaned easier.
  8. Jan 31, 2018 at 7:10 PM
    1tacomaluvr
    1tacomaluvr Well-Known Member
    '17 Inferno OR DCSB
    good point! maybe "RainX" the headlight housings? Works on my windshield!
  9. Jan 31, 2018 at 7:11 PM
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Jeeps have the advantage of standardized interchangable headlight design. Like I mentiomed earlier, no such LED product exists for the Tacoma. You will have better lighting performance with HID or halogen anyway.
    1bad2k likes this.
  10. Jan 31, 2018 at 7:17 PM
    hiPSI
    hiPSI [OP] Laminar Flow
    South Carolina
    2024 Long Tundra
    I don't care what you put on it...ice will just freeze and bridge over it.
    Something like Pam might help for brief periods but nothing will help for a several hour drive in the heavy snow and ice.
    For the record my headlights were waxed a few weeks ago and the truck has only been sprayed off, not washed, since. It did no good lol.
    The hammer and shakerhood like this.
  11. Jan 31, 2018 at 7:19 PM
    hiPSI
    South Carolina
    2024 Long Tundra
    Speaking of ice -
    Anyone know how to make a polar bear mad?
    Kick him in the icehole!
  12. Jan 31, 2018 at 7:21 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    Thanks! Wow, I never thought of that.
    The hammer likes this.
  13. Jan 31, 2018 at 7:25 PM
    roger2chris
    roger2chris Well-Known Member
    Roger
    Pineville NC
    2018 Toyota Tacoma SR5 4x4 MGM DCSB
    Install some windows shield washer spray jet to the lights like bmw has on the bumper
  14. Jan 31, 2018 at 7:25 PM
    =JSG=
    =JSG= Well-Known Member
    Canada
    2006 OR to 2021 DC TRD OR 4x4 SB
    Morimoto 2 Stroke 3.0 lows, Squadron-R Sport , Method NVs, Bilstein 6112/5160
    This is why I only have lows as LED and highs are still halogen, Run them once in a while keeps the headlights warm
    Frankenstuff likes this.
  15. Jan 31, 2018 at 7:34 PM
    #35
    CaptainBart45
    Bart
    Work in progress...
    What am I missing here? Why, if you live or drive in winter weather would you go out of your way to use the LED? Believe it or not, I am not trying to be a smart ass. I would think is you could fix a serious life threatening problem as easy as changing a light bulb then why would you build a distillery or send your wife out in the cold every 40 miles or etc. I guess I am missing something.
  16. Jan 31, 2018 at 8:04 PM
    #36
    eurowner
    eurowner Duke Sky
    Scoty
    Truck Lights are one of the few companies that make a head light assembly that has heat filaments in the lens to melt snow/ice.
    Installing LED bulbs into any head light assemblies that are designed for halogen bulbs, will ice up.
    crashnburn80 likes this.
  17. Jan 31, 2018 at 8:32 PM
    #37
    hiPSI
    South Carolina
    2024 Long Tundra
    This thread was started to be a PSA for people who read about LEDs and think they are a great headlight solution. Maybe a new owner who does not know much about headlights but thinks that white light is cool.
    Education.
  18. Jan 31, 2018 at 8:43 PM
    #38
    bajatacoguy
    bajatacoguy Well-Known Member
    Johnny
    RI to NH
    Blk Taco
    OEM: Bed Mat Roof Rack Tri-Fold Tonneau Cover Door Sill Protectors KO2's Dobinson GTS Suspension TRD Beadlocks Timbren Bump Stops SPC UCA Rear SuperSpring SSO Slimline Winch Bumper SmittyBilt x20 Mobtown Sliders Mobtown Front Skid Avid Basket Bed Rack DECKED Draw Organizer Total Chaos Bed Stiffners Relentless Fab Bed Corner Tie Downs CBI Ditch Light Brackets ARB Dual Compressor Instant Air Tank Smittybilt RTT Road Shower II Indel-B Fridge/Freezer w/ Slide Ironman 4x4 Insulated Fridge Case Redline Tuning Hood QuickLIFT Yo_Hec - Center Console Molle Little Johnny III CB Radio KB Voodoo Flashlight Kit Switch Pro 8100 BlueSea Fuse Pelfreybilt Fuse Panel Mount Gecko - LED Bed Lights Gecko - LED Hood Lights Raptor Grill Lights Cali Raised - Bed Flag Pole Holder Center Console Tray & Organizer Weather Tech Floor Mats Weather Tech Hood Deflector TRAILER BUILD HAPPENING! Plate: Negan
    Pee on your neighbors headlights for this very reason!
  19. Jan 31, 2018 at 8:48 PM
    #39
    friendlywithbears
    friendlywithbears a tree falling in the woods
    B
    The Wild
    2016 TRD OR MT
    I dunno, if you live in new england, you're going to be out cleaning your headlights anyway from all the dirty slush.
  20. Jan 31, 2018 at 9:52 PM
    #40
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    Jesus effing christ the gullibility here lol.
    worthywads and bladsville like this.
